#41
Maxwell wrote:
For what it's worth. When I first checked out in an SP, the CFI told me Cessna had been sucessfully sued when a pilot argued the tanks could not be sumped correctly unless the aircraft was parked perfectly level. Now you can drain the lowest point in the tank, no mater how or where you park your SP. I would tend to doubt that version of events. The 13 drain points were introduced when Cessna restarted production on the redesigned 172R back in '96. The drains were in the new version from the start, so I doubt Cessna could have been sued. Also, we probably would have heard about it here. Previous versions of the 172 ('84/'85) had wing tanks with no obstructions in the bottoms. The new version had wet wings, which is what prompted the installation of drains outboard of each rib in the tank area. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200710/1 |
#42
"JGalban wrote Previous versions of the 172 ('84/'85) had wing tanks with no obstructions in the bottoms. The new version had wet wings, which is what prompted the installation of drains outboard of each rib in the tank area. And all of those extra drains could have easily been eliminated if the engineers would have done a hours worth of work redesigning the ribs to enlarge or add crossover points in the ribs, so all of the water could get to the lowest point in the tank. This has to be an example of why things are screwed up in the industry, don't you think? -- Jim in NC |
#43
On Thu, 4 Oct 2007 21:38:15 -0400, "Morgans"
wrote: "JGalban wrote Previous versions of the 172 ('84/'85) had wing tanks with no obstructions in the bottoms. The new version had wet wings, which is what prompted the installation of drains outboard of each rib in the tank area. And all of those extra drains could have easily been eliminated if the engineers would have done a hours worth of work redesigning the ribs to enlarge or add crossover points in the ribs, so all of the water could get to the lowest point in the tank. This has to be an example of why things are screwed up in the industry, don't you think? The newer (post-restart) aircraft are sealed bladders, not wet wing, therefore you can't just let the water seep through the ribs. |
#44
Peter Clark wrote:
The newer (post-restart) aircraft are sealed bladders, not wet wing, therefore you can't just let the water seep through the ribs. Peter, your information is incorrect. I'm looking at the Cessna Parts Catalog for the new 172R, and 182S models. They most definitely employ wet wing fuel bays, not bladders. Happy Flying! Scott Skylane |
#45
On Sat, 06 Oct 2007 12:04:50 -0800, Scott Skylane
wrote: Peter Clark wrote: The newer (post-restart) aircraft are sealed bladders, not wet wing, therefore you can't just let the water seep through the ribs. Peter, your information is incorrect. I'm looking at the Cessna Parts Catalog for the new 172R, and 182S models. They most definitely employ wet wing fuel bays, not bladders. Interesting. I don't have my maintenance manual handy, but a quick Google pulled this up from Cessna's website: "The 182E also featured electrically-operated “Para-Lift” flaps, neoprene rubber fuel bladders holding 65 gallons total, new stronger main landing gear/fuselage attachment and improved nose wheel steering." ( http://www.cessna.com/news/article.c...XLJEsBa4kfBxm4 ) I wonder why they would have gone back to sealed wet-wing when they had bladders in there years ago. I wonder where I got that the new ones still had bladders. |
#46
"Peter Clark" wrote "The 182E also featured electrically-operated "Para-Lift" flaps, neoprene rubber fuel bladders holding 65 gallons total, new stronger main landing gear/fuselage attachment and improved nose wheel steering." Looking at the 172R specs on the Cessna web pages, the wing tanks are listed as Integral fuel tanks, 53 gallons useable, 5 quick drains per wing. No fuel bladders in this model, it would appear. -- Jim in NC |
#47
Peter Clark wrote:
/snip/ I wonder why they would have gone back to sealed wet-wing when they had bladders in there years ago. I wonder where I got that the new ones still had bladders. Peter, They didn't "go back" to a wet wing, it was an engineering development first used in the Cessna singles in the early eighties. Originally, 172's had removable aluminum tanks in the wing bays, and 182's used bladders. Integral tanks ("wet wings") are lighter, easier to build/assemble, have greater fuel capacity, and if done properly, require less mainenance in the long run. Happy Flying! Scott Skylane |
| Thread Tools | |
| Display Modes | |
| "Bad pressure switches discovered in Ospreys" | Mike[_1_] | Naval Aviation | 0 | June 22nd 07 08:14 PM |
| How much do you trim? | Mxsmanic | Piloting | 89 | October 13th 06 06:14 AM |
| Gear Warning Switches on a Mosquito | scooter | Soaring | 6 | March 9th 05 02:15 PM |
| Fading Rocker Switches | O. Sami Saydjari | Owning | 2 | February 16th 04 04:54 PM |
| FS on EBAY, circuit breaker switches | flyer | Home Built | 0 | December 3rd 03 07:59 PM |
