On Oct 3, 8:09 pm, The Amaurotean Capitalist
wrote: On Tue, 02 Oct 2007 05:06:23 -0700, Eunometic wrote: P-51; the P-38 had sufficient range to cover untill the P-47M with a wett wing which actually could excede the range of the P-51. The P-47N wasn't available until nearly a year and a half after the P-51B; good luck trying to sell a long-range P-47 available in mid-1945 to Arnold when he demanded a long-range escort fighter for the ETO in mid-1943. Gavin Bailey Yes but the P-47B or P-47C didn't have the tail tank and therefor range yet. If pressed to find a solution to extra tankage it would have been possible to introduce a tanked wing earlier i feel. |
On Wed, 03 Oct 2007 06:10:50 -0700, Eunometic
wrote: Yes but the P-47B or P-47C didn't have the tail tank and therefor range yet. The D didn't get it until the tear-drop canopy version, IIRC. In any case, the N variant didn't turn up until the Merlin-engined P-51 - with rear fuselage fuel tanks - had been in action for more than a year. If pressed to find a solution to extra tankage it would have been possible to introduce a tanked wing earlier i feel. Possibly; but when know that despite extending fighter escort range being a critical priority for the USAAF, the P-47D with increased internal fuel capacity wasn't available until well into 1944. You might as well speculate what might have happened if the USAAF had actually increased the internal fuel capacity of the Spitfire VIIIs and IXs they had been using in the MTO for a full year before Giles and Arnold got another two Spit IXs from the UK to do the same. Or you could speculate about the USAAF overcoming institutional resistance to the P-51 before the RAF had to ram the initial test reports of the type down Arnold's throat. One of the critical factors overlooked in all this is the pressure for monthly production output to sustain combat operations. One reason that the USAAF could rely upon the Merlin-engined P-51 is that it didn't entail the reduction or cancellation of other types currently in production. Gavin Bailey -- Solution elegant. Yes. Minor problem, use 25000 CPU cycle for 1 instruction, this why all need overclock Pentium. Dumbass. - Bart Kwan En |
![]() Uzytkownik "Eunometic" napisal w wiadomosci ps.com... Soviet Union Essential Illushian Sturmovik, Pekelatov Pe2, Tupolev Tu 4, I-16 Obvious typos: Ilyushin Shturmovik, Petlyakov Pe-2, Tupolev Tu-2 (Tu-4 Bull's first flight: May 1947). Why do you think I-16 was essential? It was outdated at the time of 'Fall Barbarossa' and suffered great loses (both on the ground and in combat). Replaced by MiG-3, Yak-1/Yak-3 and Yak-7/Yak-9 series. Yak-3 entered in 1944 was most succesful of all 1/3/7/9 series. Yak-7/Yak-9 being parallel to Yak-1/Yak-3 could be marked 'dispensible'; on the other hand Yak-9 with 16769 built (all versions, 1942-48) was most produced Yakovlev's piston fighter. I would add La-5/La7 series. La-5 (without Gorbunov and Gudkov) entered production in 1942 and followed by its modification La-7 (1944) was the best Soviet fighter of WWII. I would add also Polikarpov Po-2 to the essentials. It was very usefull in supporting insurgents behind German lines which was more significant than on any other war theatre. Missed Ilyushin Il-4, the most important Soviet medium bomber. Unsure; Yakalove, LaGG, MiG series of fighters seemed to overlap in function. The MiG 3 only failing to secure production because its engine was needed. Typos again: Yakovlev. Yak fighters belong the essentials IMO. LaGG-1/LaGG-3 (Lavochkin, Gorbunov & Gudkov) was failure. It was replaced by La-5 (Lavochkin's own modification of LaGG-3). MiG-3 was essential at the beginning of German-Soviet war being the only operational fighter of contemporary design (Yak-1 was not yet operational and most aircraft were damaged on the ground and abandoned). It suffered losses due to lack of experienced pilots but the airframe was comparable to contemporary enemy's fighters. It played great role in defending Moscow in 1941, Leningrad and Stalingrad. Shifted to the Far East by 1943, where it saw no action. -- JasiekS Warsaw, Poland |
On Oct 4, 9:33 pm, "JasiekS"
wrote: Uzytkownik "Eunometic" napisal w wiadomoscinews:1191326783.161221.83770@w3g2000hsg. googlegroups.com... Soviet Union Essential Illushian Sturmovik, Pekelatov Pe2, Tupolev Tu 4, I-16 Obvious typos: Ilyushin Shturmovik, Petlyakov Pe-2, Tupolev Tu-2 (Tu-4 Bull's first flight: May 1947). Why do you think I-16 was essential? Maybe the VVS soviet airforce was better of without the rata since it cost many pilots lives without much benefit. Having said that late model I-16 were almost as fast as the Hawker Hurricane. The MiG 3 and Yak 1 was only just beginning delivery and the latter had quality problems. It was outdated at the time of 'Fall Barbarossa' and suffered great loses (both on the ground and in combat). Replaced by MiG-3, Yak-1/Yak-3 and Yak-7/Yak-9 series. Yak-3 entered in 1944 was most succesful of all 1/3/7/9 series. Yak-7/Yak-9 being parallel to Yak-1/Yak-3 could be marked 'dispensible'; on the other hand Yak-9 with 16769 built (all versions, 1942-48) was most produced Yakovlev's piston fighter. I would add La-5/La7 series. La-5 (without Gorbunov and Gudkov) entered production in 1942 and followed by its modification La-7 (1944) was the best Soviet fighter of WWII. I would add also Polikarpov Po-2 to the essentials. It was very usefull in supporting insurgents behind German lines which was more significant than on any other war theatre. Missed Ilyushin Il-4, the most important Soviet medium bomber. Unsure; Yakalove, LaGG, MiG series of fighters seemed to overlap in function. The MiG 3 only failing to secure production because its engine was needed. Typos again: Yakovlev. Yak fighters belong the essentials IMO. LaGG-1/LaGG-3 (Lavochkin, Gorbunov & Gudkov) was failure. It was replaced by La-5 (Lavochkin's own modification of LaGG-3). MiG-3 was essential at the beginning of German-Soviet war being the only operational fighter of contemporary design (Yak-1 was not yet operational and most aircraft were damaged on the ground and abandoned). It suffered losses due to lack of experienced pilots but the airframe was comparable to contemporary enemy's fighters. It played great role in defending Moscow in 1941, Leningrad and Stalingrad. Shifted to the Far East by 1943, where it saw no action. -- JasiekS Warsaw, Poland Thankyou. |
On 2 Oct, 13:06, Eunometic wrote:
Essential and Dispensible WW2 aircraft. *********************************************** I've created a list of aircraft of WW2 that were essential to that side and also others that were dispensible in the sense that their place could easily have been taken by other aircraft or that were so ineffective that they were not needed at all. A great deal of effort was spent on aircraft that did not perform and were 'war loosers' while there was also a great deal of duplication of effort on aircraft that added nothing special and detracted from gains in production. United Kingdom Essential: Hurricane; had to be avialable in numbers for battle of britain Spitfire; had to provide quality fighter throughout the war an amenable to all rolls. Mosquito; night bomber, night fighter, fast day bomber and most importanty reconaisance aircraft par excellance. Lancaster; easy to fly, devastating war load. Wellington: Britains Medium bomber and an important coastal command aircraft. Non Essential: Beaufighter; not a useless aircraft as it could take damage but its roll could have been taken by others. It kept bristol busy. Hampden; Halifax; a good aircraft but Lancaster was better. Stirling; a waste of time although a saluatory lesson. Tempest and Typhoon: These aicraft had very poor high altitude performance and the typhoon had handling difficulties, was not particularly fast due to its thick wing and its airframe tended to snap of at the tail By 1942 Supermarine was producing the Spitifre Mk XII which had a single stage Griffon engine and could outrun the Tempest. Although the mk XII also had poor altitude performance its handling was better. It would be early 1944 before the Mk XIX entered service which had a two stage Griffon. Germany: Since Germany lost the war I found it hard to determine what to put in non essential so I've added the column 'might have' Essential: Me 109: Hurricane vintage aircraft but remained competitive untill 1945 when Me 109K-4's were capable of 455mph and 48000ft service ceiling and even then there were versions such as the Me 109K-14 with a two stage supercharged DB603L engine starting production but not delivered as well as the DB603DSCM engine touching on 2000hp at 1.98 atm boost there were test of 2.3 and 2.4 atm going on at DB which suggests a power of 2400hp and speed of 470-480mph. The aircraft should have been replaced far earlier with something that had lighter contol forces and better speed. It would have performed better with superior fuel. Fw 190: this aircraft filled in many of the Me 109's weaknesses. ju 88: night fighter, high speed bomber, dive or slant bomber, maritime patrol etc. Ju 87: Devastating in combined arms breakthrough warfare and deadly accurate. When its days were over it lived on as a night bomber and ground attack aircraft with one of the lowest per mission loss rates of any Luftwaffe aircraft. He 111: early bombing workhorse Do 217 Only 1200 produced but still effective as a night bomber and guided missile carrier. Arado 234: the jet aircraft provided essential reconaisance: it was the first and only aircraft to survey the Normandy beach-head. Two prototypes flew about 36 missions with their engines being reliable during this process. They were both shot down by their own German FLAK. Fi 103 or V1. Extremely cheap to produce consumed massive allied resources. Non essential: Do 17 Me 110: its role as a night fighter could have been taken by the Ju 88, I am aware of its success in the Early Polish and Soviet Campaigns but I don't think these were decisive. Might Have Me 210/410 Quite a good aircraft that was to replace the Ju 88 and Me 110. Fast, advanced armament, bomb bay, efficient etc but simply too late due to programm mismanagment to survive in allied skies. Me 262; probably was effective in staving of defeat by a few weeks. He 219; succombed to political problems; an excellent night fighter and unlike the Me 110 and early Ju 88 it had the speed to chase down British bombers once diversionary raids and feints had been ascertained. He 177: engine problems were not tackled agressively. The B series with 4 seperate engines could have made up the bulk of production and provided the Luftwaffe with a reliable long range bomber of exceptional performance had courage preceded arse covering. USA: Essential: P-40 USAAF effective fighter of excellent quality; it was quite effective with appropriate tactics. P-38 Had the range and performance to protect US bombers. It prevented the German Airforce from fielding heavy aircraft firing rockets, or impunely attacking bombers under the protection of heavy armour. B-17 Hightly survivable high altitude bomber. B-24 Longer ranged then the B-17; its only virtue. B-29 Defeat of japan almost impossible B-25 Versatile and easy to fly in all theatres of war. Wildcat, Hellcat, dauntless, avenger P-47 Ready far earlier than the P-51. Non Essential B-26 not as versatile as the B-25 and for a medium bomber too demanding of runway conditions. Helldiver: too many handling problems. P-51; the P-38 had sufficient range to cover untill the P-47M with a wett wing which actually could excede the range of the P-51. Vought corsair: took to long to perfect for carrier opperations; Hellcat did a good enough job. Had the Ki 84 been available in numbers and supplied with 100/130 octane fuel the corsair would have been essential Japan: Essential: Mitsubishi A6M zero and Betty. Dinah, Ki 84 Non essential All army types apart from the dinah and Ki 84 Soviet Union Essential Illushian Sturmovik, Pekelatov Pe2, Tupolev Tu 4, I-16 Unsure; Yakalove, LaGG, MiG series of fighters seemed to overlap in function. The MiG 3 only failing to secure production because its engine was needed. I think the concept of essential and non essential is absurd to be honest - sorry, Guy |
On Oct 8, 9:33 am, guy wrote:
On 2 Oct, 13:06, Eunometic wrote: Essential and Dispensible WW2 aircraft. *********************************************** I've created a list of aircraft of WW2 that were essential to that side and also others that were dispensible in the sense that their place could easily have been taken by other aircraft or that were so ineffective that they were not needed at all. A great deal of effort was spent on aircraft that did not perform and were 'war loosers' while there was also a great deal of duplication of effort on aircraft that added nothing special and detracted from gains in production. United Kingdom Essential: Hurricane; had to be avialable in numbers for battle of britain Spitfire; had to provide quality fighter throughout the war an amenable to all rolls. Mosquito; night bomber, night fighter, fast day bomber and most importanty reconaisance aircraft par excellance. Lancaster; easy to fly, devastating war load. Wellington: Britains Medium bomber and an important coastal command aircraft. Non Essential: Beaufighter; not a useless aircraft as it could take damage but its roll could have been taken by others. It kept bristol busy. Hampden; Halifax; a good aircraft but Lancaster was better. Stirling; a waste of time although a saluatory lesson. Tempest and Typhoon: These aicraft had very poor high altitude performance and the typhoon had handling difficulties, was not particularly fast due to its thick wing and its airframe tended to snap of at the tail By 1942 Supermarine was producing the Spitifre Mk XII which had a single stage Griffon engine and could outrun the Tempest. Although the mk XII also had poor altitude performance its handling was better. It would be early 1944 before the Mk XIX entered service which had a two stage Griffon. Germany: Since Germany lost the war I found it hard to determine what to put in non essential so I've added the column 'might have' Essential: Me 109: Hurricane vintage aircraft but remained competitive untill 1945 when Me 109K-4's were capable of 455mph and 48000ft service ceiling and even then there were versions such as the Me 109K-14 with a two stage supercharged DB603L engine starting production but not delivered as well as the DB603DSCM engine touching on 2000hp at 1.98 atm boost there were test of 2.3 and 2.4 atm going on at DB which suggests a power of 2400hp and speed of 470-480mph. The aircraft should have been replaced far earlier with something that had lighter contol forces and better speed. It would have performed better with superior fuel. Fw 190: this aircraft filled in many of the Me 109's weaknesses. ju 88: night fighter, high speed bomber, dive or slant bomber, maritime patrol etc. Ju 87: Devastating in combined arms breakthrough warfare and deadly accurate. When its days were over it lived on as a night bomber and ground attack aircraft with one of the lowest per mission loss rates of any Luftwaffe aircraft. He 111: early bombing workhorse Do 217 Only 1200 produced but still effective as a night bomber and guided missile carrier. Arado 234: the jet aircraft provided essential reconaisance: it was the first and only aircraft to survey the Normandy beach-head. Two prototypes flew about 36 missions with their engines being reliable during this process. They were both shot down by their own German FLAK. Fi 103 or V1. Extremely cheap to produce consumed massive allied resources. Non essential: Do 17 Me 110: its role as a night fighter could have been taken by the Ju 88, I am aware of its success in the Early Polish and Soviet Campaigns but I don't think these were decisive. Might Have Me 210/410 Quite a good aircraft that was to replace the Ju 88 and Me 110. Fast, advanced armament, bomb bay, efficient etc but simply too late due to programm mismanagment to survive in allied skies. Me 262; probably was effective in staving of defeat by a few weeks. He 219; succombed to political problems; an excellent night fighter and unlike the Me 110 and early Ju 88 it had the speed to chase down British bombers once diversionary raids and feints had been ascertained. He 177: engine problems were not tackled agressively. The B series with 4 seperate engines could have made up the bulk of production and provided the Luftwaffe with a reliable long range bomber of exceptional performance had courage preceded arse covering. USA: Essential: P-40 USAAF effective fighter of excellent quality; it was quite effective with appropriate tactics. P-38 Had the range and performance to protect US bombers. It prevented the German Airforce from fielding heavy aircraft firing rockets, or impunely attacking bombers under the protection of heavy armour. B-17 Hightly survivable high altitude bomber. B-24 Longer ranged then the B-17; its only virtue. B-29 Defeat of japan almost impossible B-25 Versatile and easy to fly in all theatres of war. Wildcat, Hellcat, dauntless, avenger P-47 Ready far earlier than the P-51. Non Essential B-26 not as versatile as the B-25 and for a medium bomber too demanding of runway conditions. Helldiver: too many handling problems. P-51; the P-38 had sufficient range to cover untill the P-47M with a wett wing which actually could excede the range of the P-51. Vought corsair: took to long to perfect for carrier opperations; Hellcat did a good enough job. Had the Ki 84 been available in numbers and supplied with 100/130 octane fuel the corsair would have been essential Japan: Essential: Mitsubishi A6M zero and Betty. Dinah, Ki 84 Non essential All army types apart from the dinah and Ki 84 Soviet Union Essential Illushian Sturmovik, Pekelatov Pe2, Tupolev Tu 4, I-16 Unsure; Yakalove, LaGG, MiG series of fighters seemed to overlap in function. The MiG 3 only failing to secure production because its engine was needed. I think the concept of essential and non essential is absurd to be honest - sorry, Guy I don't disagree, but it has resulted in an interesting, on-topic thread. |
On 8 Oct, 15:23, " wrote:
On Oct 8, 9:33 am, guy wrote: On 2 Oct, 13:06, Eunometic wrote: Essential and Dispensible WW2 aircraft. *********************************************** I've created a list of aircraft of WW2 that were essential to that side and also others that were dispensible in the sense that their place could easily have been taken by other aircraft or that were so ineffective that they were not needed at all. A great deal of effort was spent on aircraft that did not perform and were 'war loosers' while there was also a great deal of duplication of effort on aircraft that added nothing special and detracted from gains in production. United Kingdom Essential: Hurricane; had to be avialable in numbers for battle of britain Spitfire; had to provide quality fighter throughout the war an amenable to all rolls. Mosquito; night bomber, night fighter, fast day bomber and most importanty reconaisance aircraft par excellance. Lancaster; easy to fly, devastating war load. Wellington: Britains Medium bomber and an important coastal command aircraft. Non Essential: Beaufighter; not a useless aircraft as it could take damage but its roll could have been taken by others. It kept bristol busy. Hampden; Halifax; a good aircraft but Lancaster was better. Stirling; a waste of time although a saluatory lesson. Tempest and Typhoon: These aicraft had very poor high altitude performance and the typhoon had handling difficulties, was not particularly fast due to its thick wing and its airframe tended to snap of at the tail By 1942 Supermarine was producing the Spitifre Mk XII which had a single stage Griffon engine and could outrun the Tempest. Although the mk XII also had poor altitude performance its handling was better. It would be early 1944 before the Mk XIX entered service which had a two stage Griffon. Germany: Since Germany lost the war I found it hard to determine what to put in non essential so I've added the column 'might have' Essential: Me 109: Hurricane vintage aircraft but remained competitive untill 1945 when Me 109K-4's were capable of 455mph and 48000ft service ceiling and even then there were versions such as the Me 109K-14 with a two stage supercharged DB603L engine starting production but not delivered as well as the DB603DSCM engine touching on 2000hp at 1.98 atm boost there were test of 2.3 and 2.4 atm going on at DB which suggests a power of 2400hp and speed of 470-480mph. The aircraft should have been replaced far earlier with something that had lighter contol forces and better speed. It would have performed better with superior fuel. Fw 190: this aircraft filled in many of the Me 109's weaknesses. ju 88: night fighter, high speed bomber, dive or slant bomber, maritime patrol etc. Ju 87: Devastating in combined arms breakthrough warfare and deadly accurate. When its days were over it lived on as a night bomber and ground attack aircraft with one of the lowest per mission loss rates of any Luftwaffe aircraft. He 111: early bombing workhorse Do 217 Only 1200 produced but still effective as a night bomber and guided missile carrier. Arado 234: the jet aircraft provided essential reconaisance: it was the first and only aircraft to survey the Normandy beach-head. Two prototypes flew about 36 missions with their engines being reliable during this process. They were both shot down by their own German FLAK. Fi 103 or V1. Extremely cheap to produce consumed massive allied resources. Non essential: Do 17 Me 110: its role as a night fighter could have been taken by the Ju 88, I am aware of its success in the Early Polish and Soviet Campaigns but I don't think these were decisive. Might Have Me 210/410 Quite a good aircraft that was to replace the Ju 88 and Me 110. Fast, advanced armament, bomb bay, efficient etc but simply too late due to programm mismanagment to survive in allied skies. Me 262; probably was effective in staving of defeat by a few weeks. He 219; succombed to political problems; an excellent night fighter and unlike the Me 110 and early Ju 88 it had the speed to chase down British bombers once diversionary raids and feints had been ascertained. He 177: engine problems were not tackled agressively. The B series with 4 seperate engines could have made up the bulk of production and provided the Luftwaffe with a reliable long range bomber of exceptional performance had courage preceded arse covering. USA: Essential: P-40 USAAF effective fighter of excellent quality; it was quite effective with appropriate tactics. P-38 Had the range and performance to protect US bombers. It prevented the German Airforce from fielding heavy aircraft firing rockets, or impunely attacking bombers under the protection of heavy armour. B-17 Hightly survivable high altitude bomber. B-24 Longer ranged then the B-17; its only virtue. B-29 Defeat of japan almost impossible B-25 Versatile and easy to fly in all theatres of war. Wildcat, Hellcat, dauntless, avenger P-47 Ready far earlier than the P-51. Non Essential B-26 not as versatile as the B-25 and for a medium bomber too demanding of runway conditions. Helldiver: too many handling problems. P-51; the P-38 had sufficient range to cover untill the P-47M with a wett wing which actually could excede the range of the P-51. Vought corsair: took to long to perfect for carrier opperations; Hellcat did a good enough job. Had the Ki 84 been available in numbers and supplied with 100/130 octane fuel the corsair would have been essential Japan: Essential: Mitsubishi A6M zero and Betty. Dinah, Ki 84 Non essential All army types apart from the dinah and Ki 84 Soviet Union Essential Illushian Sturmovik, Pekelatov Pe2, Tupolev Tu 4, I-16 Unsure; Yakalove, LaGG, MiG series of fighters seemed to overlap in function. The MiG 3 only failing to secure production because its engine was needed. I think the concept of essential and non essential is absurd to be honest - sorry, Guy I don't disagree, but it has resulted in an interesting, on-topic thread.- Hide quoted text - - Show quoted text - agreed guy |
Two essential items... | john smith | Piloting | 19 | December 26th 06 02:48 AM |
Delaware LLC Owned Aircraft California Based Aircraft | ChrisEllis | Piloting | 6 | January 17th 06 03:47 AM |
Commercial rating: complex aircraft required aircraft for practical test? | Marc J. Zeitlin | Piloting | 22 | November 24th 05 04:11 AM |
Exclusive Custom Home Plans, and Essential information about building your New Home | orange tree | Home Built | 4 | November 20th 05 04:37 PM |
Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? | Jack Allison | Owning | 12 | June 14th 04 08:01 PM |
