Rotax RPMs
Old December 1st 07, 06:57 PM posted to rec.aviation.piloting
Default Rotax RPMs
On Dec 1, 8:49 am, "Maxwell" wrote:
... On Dec 1, 7:58 am, "Maxwell" wrote:
I don't care if you write a novel and include cad drawing. It's still not
true. YMMV
Maybe you should argue with historical fact instead of novels
or CAD drawings. Might learn something. Here's just one example
from http://www.aopa.org/asf/ntsb/searchResults.cfm?tss=14
MIA07LA028
Narrative Type: NTSB FINAL NARRATIVE (6120.4)
The pilot stated that a few minutes after departing, while at 1,000
snip-
I don't need to research anything Dan, I told you I have experienced it
personally on more than one occasion and found your statement to be false.
Especially in the context that you initially offered it.
Just because your engine has failed completely, and due only to carb ice,
doesn't mean you can't save you bacon with carb heat. Furthermore, a
windmilling engine can be very helpful in supplying the time (and
circulation) required to do so without having to rely on the battery or
starter.
Can I assure everyone that they will ALWAYS be able to clear a frozen carb
with just carb heaT? Hell no. But that has zero to do with the disussion,
WINDMILLING.
So, where do you think the carb heat comes from in a
windmilling engine that has stopped firing because carb ice has
completely iced over the fuel nozzle? Have you ever worked on an
airplane and seen how the carb heat works? Do you think it's electric
or something?
Dan
  #42
Old December 1st 07, 08:50 PM posted to rec.aviation.piloting
Maxwell
Default Rotax RPMs
false.
starter.
carb
WINDMILLING.
or something?
You seem to think that within 10 seconds of loosing power from an carb ice
condition, that the engine and heat exchanger on the exhaust have cooled to
the point that it's impossible for them to deice the carb. And the simply is
not true, and I have proven that many times while actually flying in winter
conditions.
  #43
Old December 1st 07, 09:14 PM posted to rec.aviation.piloting
Default Rotax RPMs
conditions.
You had claimed that you had had a *complete* engine failure. It is
obvious that you did not, and that the thing was still firing enough
to generate some heat. Here's the quote:
If a Lyc or Continental dies due to carb ice, it isn't going to
restart either. It needs air and fuel to generate heat to get the ice
out, and a pilot who lets things deteriorate until the thing is dead
is faced with a forced landing whether it's a direct-drive engine or a
geared engine.
Not true, been there and done it.
Ten seconds is a long time. I am an aircraft mechanic as well as
a CPL and CFI, and I work on those exhaust systems from which the carb
heat is taken. A 172's heat muff is a small open-faced shroud around
one exhaust riser, and collects very little heat. The Lycoming doesn't
need so much, with its carb heated by the hot oil sump. Other
aircraft, especially Continental-powered airplanes, have a shroud
around the muffler; a 150 has two small, stainless-steel mufflers, one
of which supplies carb heat. That muffler is about 14" long and four
inches in diameter and weighs about two pounds. The metal is no more
than .025" thick. Air is passed around it under the shroud all the
time to keep it cool, and when carb heat is applied, that air is
directed to the carb intake insted of being dumped overboard.
If the engine stops firing altogether due to carb ice, that
muffler will cool off so fast it's not funny. It will aready have
cooled greatly if tghe engine was idling for any length of time, and
if carb ice was forming the power loss would just cool it off further.
These aren't automobile exhaust systems with heavy cast manifolds,
where the pipe is minimum .063" and the mufflers are several layers of
sheet steel.
The accident database I pointed out earlier is full of
needless forced landings just because carb ice wasn't understood. So
many folks think it's a threat only in the winter and can't figure out
why it's happening in the summer. It's been experienced at temps as
high as +40°C (100F), with suffficiently high dewpoints. It can happen
down to -20°C, below which all supercooled atmospheric water has
frozen, but some folks have gotten themselves some carb ice by using
the carb heat and melting that moisture, and having it refreeze in the
carb or intake runners. We operate in temps as low as -25°C here but
give up after that. Some commercial operators keep flying down to -40
or lower. The worst icing is found between 0 and +15°C
http://ibis.experimentals.de/images/...omcaassl14.gif
Dan
Dan
  #44
Old December 2nd 07, 12:17 AM posted to rec.aviation.piloting
Maxwell
Default Rotax RPMs
There you go Hemmingway, write us another novel. I don't care, post your SAT
scores. It doesn't change the fact.
I have been there and done, and more than once.
For Morgans ...Rotax (x 2) Montblack Home Built 12 April 28th 06 07:19 AM
Rotax vs. Jabiru Cal Vanize Home Built 30 January 23rd 06 08:15 PM
80 hp Rotax Falke as Tug [email protected] Soaring 4 December 28th 05 10:08 AM
Rotax 912 Preheaters Willard Home Built 2 November 13th 05 12:02 AM
Ellison TBI and ROTAX 582 Bill Elliott Aerobatics 0 December 22nd 03 05:58 PM
