There was a time when I thought that
	the blackbird could secretly hit 5 on the mach meter--but isn't there solid science agains this? Such as: I don't think the engines have the ability to rev up to such a speed. Maybe the jet fuel itself cannot produce sufficent BTU's (thrust) to propel it that fast, maybe the fuel lines are too small to exceed Mach 3.3 Perhaps the real inhibitor is the lack of enough combustible oxygen to feed the engines to shatter established speed records. I know that the outer metal shell of the jet couldn't sustain the high atmospheric friction. Am I right about all this, or is there OTHER things to consider?  |
owever, the airframe of the SR-71 is stressed for Mach 4.0
	flight. Where did you hear that?  |
Scott Ferrin  wrote in message .  ..
	owever, the airframe of the SR-71 is stressed for Mach 4.0 flight. Where did you hear that? From a credible Beale AFB source. I should mention that Mach 4.0 is beyond the Blackbird's "stability limit" of Mach 3.5. A typical mission for the Blackbird would be Mach 3.2 at 85,000 ft. The aircraft could safely raise the speed from Mach 3.2 to 3.3 and accellerate up to Mach 3.5 (the stability limit)for a limited time. Pushing the aircraft up past 3.5 in an emergency was possible but not recommended. The airframe could handle limited endurance up to Mach 4.0 with the penalty of damaging the aircraft/engines at sustained flight at that speed. The MiG-25 Foxbat had a similar stability limit of Mach 2.83. The lone Foxbat chased by the Israelis up to Mach 3.2 suffered severe damage to the engines as a result of exceeding the stability limit. MiG-25 pilots were instructed not to attempt speeds over Mach 2.5-2.6, with special permission required for emergency dash at Mach 2.80. After that the aircraft could easily still accelerate but the engines would begin to suffer damage. The radar absorbing paint on the SR-71 also acted as a heat sink, lowering the airframe temperature by nearly 100 degrees. It would have been better, however, if the aircraft was painted white overall instead of blue-black. This was proposed at least once (based on the X-15 research) but rejected. Rob  |
On 30 Nov 2003 09:08:15 -0800,  (robert arndt) wrote:
	The radar absorbing paint on the SR-71 also acted as a heat sink, lowering the airframe temperature by nearly 100 degrees. It would have been better, however, if the aircraft was painted white overall instead of blue-black. This was proposed at least once (based on the X-15 research) but rejected. No. The SR-71 is black because that improves its ability to radiate away heat. Remember sigma x T**4? Well, sigma is higher for this black paint than it is for white paint. The X-15 never did any research on white paint. If you're thinking of the white paint used to protect the pink ablative coating on #2, that wasn't there to improve radiation and it burned off very quickly. There was nothing significant about the paint color. Since the X-15 flew a really quick trajectory, rather than cruising at high speeds, color was much less of an issue. It wasn't in the air long enough for radiation to help. (The same is true for the Space Shuttle Orbiter.) However, the SR-71 cruised at high speeds and radiation helped lower the temperature, as you mention. Where do you think the heat absorbed by the paint went? Heat can be conducted into the airframe, convected into the air, or radiated into space. It doesn't just vanish into the molecules of the paint. The surface of the airplane, covered with paint, radiated that heat outward. The heat came from more than just the paint; it also came from the skin and structure. Mary -- Mary Shafer Retired aerospace research engineer  |
			 "robert arndt" wrote in message om... Same here. I live in northern California so I have heard all the stuff coming from Beale AFB and the Mach 3.0-3.5 range seems to be the truth; however, the airframe of the SR-71 is stressed for Mach 4.0 flight. Maybe like the Foxbat this was for emergency only with resulting damage to the engines and a/c. But I see little need for such speed given the Blackbird's height invunerability. What height invulnerability? It worked in the 60's but in todays environment, there are quite a few missiles that could reach out and touch the SR-71.  |
On Sun, 30 Nov 2003 07:21:36 -0500, "Brian"
	wrote: "robert arndt" wrote in message . com... Same here. I live in northern California so I have heard all the stuff coming from Beale AFB and the Mach 3.0-3.5 range seems to be the truth; however, the airframe of the SR-71 is stressed for Mach 4.0 flight. Maybe like the Foxbat this was for emergency only with resulting damage to the engines and a/c. But I see little need for such speed given the Blackbird's height invunerability. What height invulnerability? It worked in the 60's but in todays environment, there are quite a few missiles that could reach out and touch the SR-71. Even back in the day there are some they couldn't ignore. If you counted both sides I'd give the SA-5, Nike Hercules and Bomarc B fair odds.  |
	On Sun, 30 Nov 2003 07:21:36 -0500, "Brian" wrote: "robert arndt" wrote in message . com... Same here. I live in northern California so I have heard all the stuff coming from Beale AFB and the Mach 3.0-3.5 range seems to be the truth; however, the airframe of the SR-71 is stressed for Mach 4.0 flight. Maybe like the Foxbat this was for emergency only with resulting damage to the engines and a/c. But I see little need for such speed given the Blackbird's height invunerability. What height invulnerability? It worked in the 60's but in todays environment, there are quite a few missiles that could reach out and touch the SR-71. Even back in the day there are some they couldn't ignore. If you counted both sides I'd give the SA-5, Nike Hercules and Bomarc B fair odds. Not being able to ignore them (i.e., SA-5), yes. But "fair odds"? I don't think I'd go that far. A tail chase was unlikely to work (it took a great deal of energy to get the SAM up to that altitude, not leaving a lot for subsequent catch up or maneuver). A head-on shot required a targeting system capable of handling the extreme closure velocity along with again leaving enough energy to maneuver to the kill. Possible, but not really likely I'd think. Nike Herc I'd place in the "very lucky shot" category, unless the nuclear warhead version was used (unlikely to say the least), and BOMARC in the "when pigs fly" category (again unless the nuke model was used)--it had the altitude (but only by challenging its capabilities--its ceiling was about 100K), but lacked the energy (it could only do about M 3.0 itself). Brooks  |
| Thread Tools | |
| Display Modes | |
| SR- 71/ Blackbird lore | Larry Dighera | Military Aviation | 28 | July 31st 03 03:20 PM |
| Blackbird lore | Air Force Jayhawk | Military Aviation | 3 | July 26th 03 03:03 AM |
