What/how does compression ratio affect an engine?
Old December 10th 07, 11:25 AM posted to rec.aviation.homebuilt
Default What/how does compression ratio affect an engine?
Hi,
So I was fantasizing the other day (as I do quite a bit) about my
latest dream-plane-to-build: an RV-9A. (Note that this is fantasy in
the extreme as I'm not a pilot yet AND I have no money!)
I was thinking of how to power this plane. A Jet-A burning diesel
would be great but that's another story. I spotted an ad for
Superior's XP-series engines in Kitplanes. The website has a great
"build your own engine" feature where you get to change all the bits
and customize the engine.
One of the things you have to choose is compression ratio: 7:1
(150hp), 8.5:1 (160hp), or 9:1 (165hp).
Going for the 7:1 option (from the default 8.5:1) adds $100 to the
price! I'm assuming this is a supply/demand issue.
So my question (finally) is: what is the effect of a higher or lower
compression ratio? I believe TBO for all three engines is still 2000
hours.
- Is there a difference in wear?
- Would maximum power be produced at the same RPM for all three
engines? In other words is there a relationship like (power) =
(compression ratio) x (RPM) such that these engines all operate at the
same RPM? In which case wear would be the same...(?)
For the RV-9A 150hp would be fine. I guess I'm trying to understand
what benefit is to be had by spending the extra $100 to go for the
lower compression pistons. All in my fantasy
Michael
Wing Tape - Does Thickness Affect Performance? ContestID67 Soaring 87 February 1st 07 03:24 PM
Wing Tape - Does Thickness Affect Performance? Charles McLaurin Soaring 2 January 30th 07 06:00 PM
Recent Political Change May Positively Affect GA Larry Dighera Piloting 98 November 13th 06 01:59 AM
How does spar protrusion affect performance Chris Davison Soaring 19 July 13th 04 12:38 AM
Does WiFi affect your choice of FBO? [email protected] General Aviation 8 October 16th 03 07:22 PM
