![]() Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? -- Peter Lycoming says you can start without preheat down in the teens if you use multiviscosity oil. As others have said, one of the biggest differences from auto use is that aero engines are often flown less frequently so there's less oil hanging around at startup. On the other hand, that's true even in warm weather, though warm oil will be redistributed more quickly. I doubt that you did any harm. Convert all the degrees to Kelvin temps and be comforted :-) |
On 12/20/2007 9:24:28 AM, Paul kgyy wrote:
I doubt that you did any harm. Convert all the degrees to Kelvin temps and be comforted :-) Ha. Thanks, Paul. -- Peter |
On 2007-12-19 12:21:28 -0500, "Peter R." said:
Given any other day, I would have plugged the aircraft back in and scrapped the flight I know what I did has negative long term repercussions on my engine's health I'm sure you must do some analysis in your head to judge the damage inflicted on the engine in this case - otherwise, how could you judge if scrapping a flight is the appropriate thing to do? I'm curious how you quantify the 'long term repercussions'. Have you concluded, for example, that not preheating in this case will: - Reduce the TBO for your engine by 10 hours? - Increase oil consumption by .2 qt/hour? - Increase the risk of a catastrophic in-flight failure by 5%? Clearly those are just some examples, but I would like to understand what you have judged the impact of flying in this case would be. |
A key to lubrication of any aircraft engine is how soon an oil fog can
be established in a crankcase. This takes a while - especially if the oil is thick, as the bearing journal clearances are not that great and the amount of oil thrown from them is minimal given starting oil viscosity and the comparatively low crankcase activity at low rpm. Most of the oil flow generated by that fixed volume oil pump ends up blowing over the relief valve and dropping directly back to the sump, giving the oil little access to the heat of the engine pistons and cylinder heads. There are no features on the rotating machinery that will centrifugally splatter oil blobs onto the cam surfaces. They have to depend on previous operation for lubrication until the fog gets more generally developed. Oil viscosity can easily vary over a 100:1 range between moderately cold start and normal operating values. The leakage from a journal bearing will correspond inversely as that viscosity and directly as the cube of the bearing clearance - which is also compromised by the differential thermal expansion of aluminum vs steel. Remember it isn't the bearings - it is all the expensive surfaces in your engine that are starved in a cold start. And the operating profile is almost always a full takeoff power after only a few minutes of operation. I do agree though that the OP didn't do any substantial damage to his engine since it had been run so recently and since it has Continental's bottom-of-the-crankcase camshaft. |
Peter, this thread has grown way too long and ****y for me to go check if
you already have received this info, so please excuse any duplication. Mike Noel hit on an important factor that did not seem to be followed up on about a difference between aircraft and automobile piston engines. See the papers at http://www.tanisaircraft.com/articlesresearch.html . Stan "Peter R." wrote in message ... This time of year here in the Northeast US I always preheat my Bonanza's IO520 engine with a Tanis heater and an insulated cowling/prop cover as it sits in an unheated t-hangar. The result is that the oil temperature at startup is around 105 degrees F, even if the outside air temperature is as low as -15 degrees F. Monday night I arrived at my t-hangar to discover that at some point during the day the line person accidentally pulled out the plug connecting the Tanis heater to the small extension cord I use to extend the plug to the outside of the cowling cover, so the aircraft had not been preheating. Outside and inside temperatures were both a cold 25 degrees F. Given any other day, I would have plugged the aircraft back in and scrapped the flight but in this case I had an Angel Flight patient waiting in another city for my arrival and I was already late. Thus I made the painful decision to start up the aircraft and allow it to low idle until the oil heated thoroughly. A small consolation is that the engine had been recently filled with fresh Exxon Elite oil. To my relief the aircraft started right up. I know what I did has negative long term repercussions on my engine's health and I have already derived a tool to lock the two cords and prevent this accidental unplugging from happening again. However, this leads me to question the differences between aircraft engines and auto engines: Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? -- Peter |
Stan Prevost wrote:
Peter, this thread has grown way too long and ****y for me to go check if you already have received this info, so please excuse any duplication. Mike Noel hit on an important factor that did not seem to be followed up on about a difference between aircraft and automobile piston engines. See the papers at http://www.tanisaircraft.com/articlesresearch.html . Even more interesting is that Tanis leaves such obsolete information on their web site. Take a magnet to a few car dealerships and see how many engine blocks are cast iron these days... Matt |
On Wed, 19 Dec 2007 12:21:28 -0500, Peter R. wrote:
Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? No because it is entirely unnecessary. -- Remove numbers for gmail and for God's sake it ain't "gee" either! |
![]() "Peter R." wrote in message ... This time of year here in the Northeast US I always preheat my Bonanza's IO520 engine with a Tanis heater and an insulated cowling/prop cover as it sits in an unheated t-hangar. The result is that the oil temperature at startup is around 105 degrees F, even if the outside air temperature is as low as -15 degrees F. Monday night I arrived at my t-hangar to discover that at some point during the day the line person accidentally pulled out the plug connecting the Tanis heater to the small extension cord I use to extend the plug to the outside of the cowling cover, so the aircraft had not been preheating. Outside and inside temperatures were both a cold 25 degrees F. Given any other day, I would have plugged the aircraft back in and scrapped the flight but in this case I had an Angel Flight patient waiting in another city for my arrival and I was already late. Thus I made the painful decision to start up the aircraft and allow it to low idle until the oil heated thoroughly. A small consolation is that the engine had been recently filled with fresh Exxon Elite oil. To my relief the aircraft started right up. I know what I did has negative long term repercussions on my engine's health and I have already derived a tool to lock the two cords and prevent this accidental unplugging from happening again. However, this leads me to question the differences between aircraft engines and auto engines: Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? -- Peter I've been more cautious about rapid heating up of engines since I unfortunately split the engine block of my Jaguar XJ6 4.2 litre that I conclude was caused by immediate rapid driving from -5c being late for an appointment. Guess that expensive incident will always stay in my mind... Mike |
Mike Gilmour wrote:
"Peter R." wrote in message ... This time of year here in the Northeast US I always preheat my Bonanza's IO520 engine with a Tanis heater and an insulated cowling/prop cover as it sits in an unheated t-hangar. The result is that the oil temperature at startup is around 105 degrees F, even if the outside air temperature is as low as -15 degrees F. Monday night I arrived at my t-hangar to discover that at some point during the day the line person accidentally pulled out the plug connecting the Tanis heater to the small extension cord I use to extend the plug to the outside of the cowling cover, so the aircraft had not been preheating. Outside and inside temperatures were both a cold 25 degrees F. Given any other day, I would have plugged the aircraft back in and scrapped the flight but in this case I had an Angel Flight patient waiting in another city for my arrival and I was already late. Thus I made the painful decision to start up the aircraft and allow it to low idle until the oil heated thoroughly. A small consolation is that the engine had been recently filled with fresh Exxon Elite oil. To my relief the aircraft started right up. I know what I did has negative long term repercussions on my engine's health and I have already derived a tool to lock the two cords and prevent this accidental unplugging from happening again. However, this leads me to question the differences between aircraft engines and auto engines: Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? -- Peter I've been more cautious about rapid heating up of engines since I unfortunately split the engine block of my Jaguar XJ6 4.2 litre that I conclude was caused by immediate rapid driving from -5c being late for an appointment. Guess that expensive incident will always stay in my mind... No, that was caused by driving a Jaguar... Matt |
![]() I've been more cautious about rapid heating up of engines since I unfortunately split the engine block of my Jaguar XJ6 4.2 litre that I conclude was caused by immediate rapid driving from -5c being late for an appointment. Guess that expensive incident will always stay in my mind... My guess would be that the very cold temps caused the block to split due to the coolant freezing over night. If it was -5C when you started it, chances are it was much colder at some point in the evening. Common in the upper Midwestern US was to see 70's era cars blow out freeze plugs and/or crack blocks by running no (or too weak) antifreeze. A cold start and immediate run up to high speed should not cause catastrophic failure of a block. Being a Jag, it may have had a badly cast block since new. Their QC ain't the best. Good Luck, Mike |
Differences between automotive & airplane engines | Chris Wells | Home Built | 105 | February 18th 06 11:00 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
LOM engines | buckey | Home Built | 14 | October 30th 03 05:22 PM |
automotive parts on airplane engines | Wallace Berry | Home Built | 15 | September 28th 03 02:55 AM |
Barnyard--- Auto engines | Jerry Springer | Home Built | 10 | August 8th 03 06:38 PM |
