On 18 Jan 2008 03:24:59 GMT, Judah wrote:
New Pilot wrote in news:n9tro39afurstkjapf0rtnc6ppl43not4v@ 4ax.com: Hi folks, Does anyone have any experience of the following or know about it. I recently got a ppl licence and generally are fine doing all the flying type tasks required to safely take off fly and land. One thing that seems to get me every time is if I am for example flying straight and level at 2 or 3 thousand feet (height just as an arbitory figure) and I encounter a crosswind the aircraft slowly but surely starts to yaw as the wind hits the tail fin. this bit I understand but the bit I don't is when this situation happens I feel dizzy and disorientated for a few moments as the view from the window in VFR starts to rotate. I can reduce this by a bit of rudder to stop the rotation and keep the ball in the centre. Is this normal or should I not be flying? thanks I'm not a guru, but I have experienced weathervaning when flying "hands off & feet off" in a direction that was 60* or so against the prevailing wind current. The point about the plane not maintaining coordination is probably about right - certainly you are not "stepping on the ball" (or perhaps more likely as a new pilot, stepping on it too much) and causing a skid or slip, which is probably contributing to your disorientation. Generally speaking, though, the weathervaning that I have experienced has caused a turn that was not very quick, but more progressive and subtle. If you are experiencing an aggressive turn, I have to believe you are not controlling the rudder properly. Otherwise if you are getting dizzy from a simple turn at altitude, I would agree with the others here that you should visit your AME... I can only remember getting dizzy while flying twice. Once when I did my first recovery from unusual attitudes under the hood (I had a pretty aggressive instructor - I think he was doing himmelmans while I was there with my head pointed at the floor), and once when I had just recovered from a cold and had a bit of trouble getting my ears to pop on a relatively aggressive descent - apparently I wasn't as recovered as I thought I was, and when my ears finally did pop, my whole head whooshed for a second. You should not be experiencing dizziness on a regular basis during normal straight-and-level flight nor even in a relatively aggressive turn. Do you have trouble doing short approaches or steep turns? The turning effect seems to happen over about 8 to 10 seconds to turn the aircraft 15 degrees. Once turned it seems to remain stable now pointing in a different direction. I then see that the balance ball is a little off centre. I did try turning the ruddder trim knob to the right and left but it did not seem to have much if any effect. Steep turns 45 degees or more to the right are fine, Have some trouble with turns to the left usually kicks in after one full circuit almost if the fluid in my ears is delayed in some way - Thogh i fight the sensation and can do satisfactory steep turns to the left. maybe having just done a few 45degree turns to the right and then pretty much banking to the left without stopping at the straight and level for a rest may not help. Loosing height quickly is no problem the ears do equalise to the pressure change - gaining height quickly in a worn PA28 does not really happen max = 750 feet/minute thats with just me fueled to tabs and no baggage. |
New Pilot wrote in
news
The turning effect seems to happen over about 8 to 10 seconds to turn the aircraft 15 degrees. Once turned it seems to remain stable now pointing in a different direction. I then see that the balance ball is a little off centre. I did try turning the ruddder trim knob to the right and left but it did not seem to have much if any effect. Sounds awfully slow and consistent to be weathervaning to me. As others have said, weathervaning happens with wind gusts and you'd feel the plane being "pushed" a few degrees left or right as it was happening. More than likely it's a coordination issue. Either the rudder and/or aileron trim is off, or you're letting your feet and fingers do things that your head isn't paying attention to. You're the pilot, man. Control the plane! Watch the ball! Steep turns 45 degees or more to the right are fine, Have some trouble with turns to the left usually kicks in after one full circuit almost if the fluid in my ears is delayed in some way - Thogh i fight the sensation and can do satisfactory steep turns to the left. maybe having just done a few 45degree turns to the right and then pretty much banking to the left without stopping at the straight and level for a rest may not help. Have you tried starting with a left turn? I don't think it's completely outrageous for you to have a momentary queasy sensation as you do the 90* switch (from right 45 to left 45). It doesn't happen to me, but I can see how it might be uncomfortable for some. Loosing height quickly is no problem the ears do equalise to the pressure change - gaining height quickly in a worn PA28 does not really happen max = 750 feet/minute thats with just me fueled to tabs and no baggage. The concept of the short approach is that you're going to be doing an aggressive descent in a 30* bank turn... I'm guessing you may have some "queasiness" issues (my sister has them) and may want to talk to your AME about it. I think your "weathervaning" issues are really just letting yourself be the passenger instead of the pilot. |
The turning effect seems to happen over about 8 to 10 seconds to turn the aircraft 15 degrees. Once turned it seems to remain stable now pointing in a different direction. I then see that the balance ball is a little off centre. I did try turning the ruddder trim knob to the right and left but it did not seem to have much if any effect. Sounds awfully slow and consistent to be weathervaning to me. As others have said, weathervaning happens with wind gusts and you'd feel the plane being "pushed" a few degrees left or right as it was happening. More than likely it's a coordination issue. Either the rudder and/or aileron trim is off, or you're letting your feet and fingers do things that your head isn't paying attention to. You're the pilot, man. Control the plane! Watch the ball! Steep turns 45 degees or more to the right are fine, Have some trouble with turns to the left usually kicks in after one full circuit almost if the fluid in my ears is delayed in some way - Thogh i fight the sensation and can do satisfactory steep turns to the left. maybe having just done a few 45degree turns to the right and then pretty much banking to the left without stopping at the straight and level for a rest may not help. Have you tried starting with a left turn? I don't think it's completely outrageous for you to have a momentary queasy sensation as you do the 90* switch (from right 45 to left 45). It doesn't happen to me, but I can see how it might be uncomfortable for some. Loosing height quickly is no problem the ears do equalise to the pressure change - gaining height quickly in a worn PA28 does not really happen max = 750 feet/minute thats with just me fueled to tabs and no baggage. The concept of the short approach is that you're going to be doing an aggressive descent in a 30* bank turn... I'm guessing you may have some "queasiness" issues (my sister has them) and may want to talk to your AME about it. I think your "weathervaning" issues are really just letting yourself be the passenger instead of the pilot. Thanks for that, could well be just me being a passenger. The nearest to the short approach sometimes is a base leg join where I have to loose 800 feet in a short time and turning. but thats not really agressive. In response to another poster mentioning the UK weather and costs that is absolutly right. weather here has been awful on the south coast and the cost of flying Hire for 1 hour of a PA28 wet is about $250 at loose approximation US dollars Landing fee at my local airport is now $35 Touch and go is $16 and they now charge $16 for a missed approach -they waive that fee if ATC instruct a go around, |
New Pilot wrote in
: Thanks for that, could well be just me being a passenger. The nearest to the short approach sometimes is a base leg join where I have to loose 800 feet in a short time and turning. but thats not really agressive. In response to another poster mentioning the UK weather and costs that is absolutly right. weather here has been awful on the south coast and the cost of flying Hire for 1 hour of a PA28 wet is about $250 at loose approximation US dollars Landing fee at my local airport is now $35 Touch and go is $16 and they now charge $16 for a missed approach -they waive that fee if ATC instruct a go around, Holy cow! That's out of control - charging for a missed approach?!?! Is this a Class B airport or something? What is their justification? How much wear & tear does your Archer cause the runway when it never even touches it! Are they concerned about the downdrafts from the ground effect? I think you should consider moving to the US. Life will be better. Especially in another two or three years... I don't think I ever paid more than $15 for a landing fee in an Archer (or even in a Bonanza, for that matter). And I've only ever heard of one airport in the US where the owner was trying to charge people for touch & goes. And I don't think he does it anymore. But even he wasn't charging for a go-around or missed approach... |
| Thread Tools | |
| Display Modes | |
