#41
![]() "Bertie the Bunyip" wrote in message ... Veeduber wrote in : On Jan 29, 5:18 am, Bertie the Bunyip wrote: Really? Name a few? Ford, GM, Chrysler, Volvo, Holden, Renault... Volkswagen :-) http://www.gm.com/explore/technology.../specialized/i ndustrial/industrial_engines.jsp Every major automobile manufacturer offers a line of industrial engines. There is also an extensive network of professional over-haul shops that specialize in industrial engines. For 2008 GM is introducing lighter weight Brazilian built utility engines to replace the all-cast-iron models that have been standard since the late 1940's. The world can't run without utility engines for deep-well pumps, air compressors, portable arc welders, orchard sprayers, fork lifts, all manner of farm equipment... Many of these engines are an EXACT match for the Model A but being of modern design, they offer better durability and reduced fuel consumption, typically at less weight. INteresting. The only one I know of commonly used for aviation is that little 2 cyl Onan they put on Quickies. I know some ultralight guys use the little Continental 084s as well. Bertie Not sure whether the little Onan boxer is still in production. Most of the little opposed cylinder flat heads have been replaced with overhead valve Vee-twins. I strongly suspect that the switch to Vee configuration was to fit the new engines within the width of the equipment that the older flat head engines typically powered--but I really don't know with any certainty. I looked for a little info on the Continental O-84 and could only find that it is a 4 cylinder of 21 cubic inches per cylinder. From that, I would expect a power rating of 40 to 50 HP and a weight of 90 to 105 pounds, which would be appropriate for a single seat LSA with a gross weight of 600 to 650 pounds. But, I don't know the actual specs and am curious to learn more. Peter |
#42
On Jan 29, 8:08*pm, "Morgans" wrote:
"William Hung" wrote Why the Jabiru Jim? You probably have noticed that I have no love for Rotax; so that is why #1 - *It isn't a Rotax. #2 - Direct drive, so it eliminates another possible failure point. #3 - It has a realistic HP to weight ratio, so it is not terribly overstressed like Rotax #4 - They have been though some of a learning curve, have had some problems that they admitted to, and actively worked to correct. #5 - They offer some different sizes to fit your needs - another one will be out soon, I believe. *It will be an 8 cylinder, and it plain "looks cool!" #6 - Not many other offerings that are modern engines, not from the ancient Lycoming-Continental gene pool. #7 - Cost is somewhat reasonable. #8 - It isn't a Rotax #9 - It isn't a Rotax #10- It isn't a Rotax I personally will probably go with an auto conversion, but I realize that some people do not have the ability or the desire to do something like that. |
#43
"Peter Dohm" wrote in
: "Bertie the Bunyip" wrote in message ... Veeduber wrote in news:4e7dc1fd-653d-4c18-8e93-601b1a908203 @c4g2000hsg.googlegroups.com: On Jan 29, 5:18 am, Bertie the Bunyip wrote: Really? Name a few? Ford, GM, Chrysler, Volvo, Holden, Renault... Volkswagen :-) http://www.gm.com/explore/technology...es/specialized /i ndustrial/industrial_engines.jsp Every major automobile manufacturer offers a line of industrial engines. There is also an extensive network of professional over-haul shops that specialize in industrial engines. For 2008 GM is introducing lighter weight Brazilian built utility engines to replace the all-cast-iron models that have been standard since the late 1940's. The world can't run without utility engines for deep-well pumps, air compressors, portable arc welders, orchard sprayers, fork lifts, all manner of farm equipment... Many of these engines are an EXACT match for the Model A but being of modern design, they offer better durability and reduced fuel consumption, typically at less weight. INteresting. The only one I know of commonly used for aviation is that little 2 cyl Onan they put on Quickies. I know some ultralight guys use the little Continental 084s as well. Bertie Not sure whether the little Onan boxer is still in production. Most of the little opposed cylinder flat heads have been replaced with overhead valve Vee-twins. I strongly suspect that the switch to Vee configuration was to fit the new engines within the width of the equipment that the older flat head engines typically powered--but I really don't know with any certainty. Yeah, I saw one of those being peddled as an ultrlight engine a few years ago. V twons haven;t done well as airplane engines. I can't recall seeing many installed. I looked for a little info on the Continental O-84 and could only find that it is a 4 cylinder of 21 cubic inches per cylinder. From that, I would expect a power rating of 40 to 50 HP and a weight of 90 to 105 pounds, which would be appropriate for a single seat LSA with a gross weight of 600 to 650 pounds. But, I don't know the actual specs and am curious to learn more. I saw a website about converting them some time ago. There's a slightly smaller twin as well.I know that at least a fw airplanes have been successfully flown behind the 084. there is a guy who sells them new, surplus for only about $800. There's a bit of work to be done to make them usable as an airplane engine, but nothing crazy. Just a prop flange, cut off the ole shroud and mess aroudn with the inlet manifold so the carb isn't in yor windscreen. Bertie |
#44
William Hung wrote in
: On Jan 29, 8:08*pm, "Morgans" wrote: "William Hung" wrote Why the Jabiru Jim? You probably have noticed that I have no love for Rotax; so that is why #1 - *It isn't a Rotax. #2 - Direct drive, so it eliminates another possible failure point. #3 - It has a realistic HP to weight ratio, so it is not terribly overstressed like Rotax #4 - They have been though some of a learning curve, have had some problem s that they admitted to, and actively worked to correct. #5 - They offer some different sizes to fit your needs - another one will be out soon, I believe. *It will be an 8 cylinder, and it plain "looks cool !" #6 - Not many other offerings that are modern engines, not from the ancien t Lycoming-Continental gene pool. #7 - Cost is somewhat reasonable. #8 - It isn't a Rotax #9 - It isn't a Rotax #10- It isn't a Rotax I personally will probably go with an auto conversion, but I realize that some people do not have the ability or the desire to do something like tha t. I do, on both accounts. *I very much enjoy playing with things like perfecting an engine conversion. The plan is to get a conversion rigged up, and make a relatively cheap plywood airboat, and run the hell out of it, while enjoying the time playi ng with a unique boat on the lake. *My thought is that it lives through the gyroscopic loads of rapid hard pounding on a boat, it will survive quite well in an airplane. -- Jim in NC Do you have any particular engine in mind for your conversion? Someone somewhere used a Harley engine. I also have read somewhere of a Yamaha Virago powered airplane and a BMW powered one even. Wel, Steve Wittman used a harley in one of his first homebuilts in something like 1921. he called it the Hardly Ableson and it didn't fly so good! I don't think it's been a very popular engine with homebuilders over the years. Ben a good few bike engines used, though. A few have used BMWs and Moto Guzzis, not to mention various rice burners. The Henderson conversion was popular in the 1930s. Bertie |
#45
"Morgans" wrote in
: "William Hung" wrote Do you have any particular engine in mind for your conversion? Someone somewhere used a Harley engine. I also have read somewhere of a Yamaha Virago powered airplane and a BMW powered one even. A Harley engine looks neat, but I don't like the vibration factor of most of them. Tha'd certanly put me off. I can see it being a weld cracking experience! Bertie |
#46
![]() "Bertie the Bunyip" wrote in message .. . "Peter Dohm" wrote in : "Bertie the Bunyip" wrote in message ... INteresting. The only one I know of commonly used for aviation is that little 2 cyl Onan they put on Quickies. I know some ultralight guys use the little Continental 084s as well. Bertie Not sure whether the little Onan boxer is still in production. Most of the little opposed cylinder flat heads have been replaced with overhead valve Vee-twins. I strongly suspect that the switch to Vee configuration was to fit the new engines within the width of the equipment that the older flat head engines typically powered--but I really don't know with any certainty. Yeah, I saw one of those being peddled as an ultrlight engine a few years ago. V twons haven;t done well as airplane engines. I can't recall seeing many installed. Yeah, the Vee twins look like a poor compromise to me as well--so long as anything better is still available. I would expect a lot more vibration and the crank position is wrong for most designs unless you do a lot of work. I looked for a little info on the Continental O-84 and could only find that it is a 4 cylinder of 21 cubic inches per cylinder. From that, I would expect a power rating of 40 to 50 HP and a weight of 90 to 105 pounds, which would be appropriate for a single seat LSA with a gross weight of 600 to 650 pounds. But, I don't know the actual specs and am curious to learn more. I saw a website about converting them some time ago. There's a slightly smaller twin as well.I know that at least a fw airplanes have been successfully flown behind the 084. there is a guy who sells them new, surplus for only about $800. There's a bit of work to be done to make them usable as an airplane engine, but nothing crazy. Just a prop flange, cut off the ole shroud and mess aroudn with the inlet manifold so the carb isn't in yor windscreen. Bertie I found one web site mentioning them, but not much in the way of pics or data. I'll watch for them as a curiosity. Thanks, Peter |
#47
: "Bertie the Bunyip" wrote in message .. . "Peter Dohm" wrote in : "Bertie the Bunyip" wrote in message ... INteresting. The only one I know of commonly used for aviation is that little 2 cyl Onan they put on Quickies. I know some ultralight guys use the little Continental 084s as well. Bertie Not sure whether the little Onan boxer is still in production. Most of the little opposed cylinder flat heads have been replaced with overhead valve Vee-twins. I strongly suspect that the switch to Vee configuration was to fit the new engines within the width of the equipment that the older flat head engines typically powered--but I really don't know with any certainty. Yeah, I saw one of those being peddled as an ultrlight engine a few years ago. V twons haven;t done well as airplane engines. I can't recall seeing many installed. Yeah, the Vee twins look like a poor compromise to me as well--so long as anything better is still available. I would expect a lot more vibration and the crank position is wrong for most designs unless you do a lot of work. Well, there's one guy who seems to have come up with a solution! I'll make a seperate post wth an attachment. I looked for a little info on the Continental O-84 and could only find that it is a 4 cylinder of 21 cubic inches per cylinder. From that, I would expect a power rating of 40 to 50 HP and a weight of 90 to 105 pounds, which would be appropriate for a single seat LSA with a gross weight of 600 to 650 pounds. But, I don't know the actual specs and am curious to learn more. I saw a website about converting them some time ago. There's a slightly smaller twin as well.I know that at least a fw airplanes have been successfully flown behind the 084. there is a guy who sells them new, surplus for only about $800. There's a bit of work to be done to make them usable as an airplane engine, but nothing crazy. Just a prop flange, cut off the ole shroud and mess aroudn with the inlet manifold so the carb isn't in yor windscreen. Bertie I found one web site mentioning them, but not much in the way of pics or data. I'll watch for them as a curiosity. I thkn there was something like a JN-1 for sale on Barnstormers with one of those on it. I thnk it might have been the same guy Bertie |
#48
Peter Dohm wrote:
"Bertie the Bunyip" wrote in message ... Veeduber wrote in : On Jan 29, 5:18 am, Bertie the Bunyip wrote: Really? Name a few? Ford, GM, Chrysler, Volvo, Holden, Renault... Volkswagen :-) http://www.gm.com/explore/technology.../specialized/i ndustrial/industrial_engines.jsp Every major automobile manufacturer offers a line of industrial engines. There is also an extensive network of professional over-haul shops that specialize in industrial engines. For 2008 GM is introducing lighter weight Brazilian built utility engines to replace the all-cast-iron models that have been standard since the late 1940's. The world can't run without utility engines for deep-well pumps, air compressors, portable arc welders, orchard sprayers, fork lifts, all manner of farm equipment... Many of these engines are an EXACT match for the Model A but being of modern design, they offer better durability and reduced fuel consumption, typically at less weight. INteresting. The only one I know of commonly used for aviation is that little 2 cyl Onan they put on Quickies. I know some ultralight guys use the little Continental 084s as well. Bertie Not sure whether the little Onan boxer is still in production. Most of the little opposed cylinder flat heads have been replaced with overhead valve Vee-twins. I strongly suspect that the switch to Vee configuration was to fit the new engines within the width of the equipment that the older flat head engines typically powered--but I really don't know with any certainty. I looked for a little info on the Continental O-84 and could only find that it is a 4 cylinder of 21 cubic inches per cylinder. From that, I would expect a power rating of 40 to 50 HP and a weight of 90 to 105 pounds, which would be appropriate for a single seat LSA with a gross weight of 600 to 650 pounds. But, I don't know the actual specs and am curious to learn more. Is this it? http://sacramento.craigslist.org/for/554471936.html Looks like this guy has been picking them up surplus for quite a while and flipping them on craigslist. |
#49
![]() "Bertie the Bunyip" wrote in message .. . You have to wonder "why?" Bertei Indeed. It really leaves me speechless. Peter |
#50
"Peter Dohm" wrote in news:k9soj.87574$L%6.20853
@bignews3.bellsouth.net: "Bertie the Bunyip" wrote in message .. . You have to wonder "why?" Bertei Indeed. It really leaves me speechless. Peter Clever use of the gearbox. Wonder how it stand up to the thrust and precessional loads. Bertie |
STOL Plans | M. | Home Built | 52 | August 4th 06 06:47 AM |
Zenith STOL 801 | R.W. Behan | Home Built | 2 | May 24th 06 02:34 PM |
BD-4. wings on a V-6 STOL? | Jim Rodgers | Home Built | 5 | August 31st 05 09:59 PM |
WTB Cessna 150/150 STOL | brewmaster1 | Aviation Marketplace | 0 | March 21st 05 02:30 AM |
206 STOL | DeltaDeltaDelta | Piloting | 11 | December 20th 03 09:39 PM |
