F35 cost goes up.
Old December 26th 03, 02:14 AM
Pat Carpenter
Default F35 cost goes up.
On Thu, 25 Dec 2003 22:36:13 GMT, "Shchelkunchik"
"Rostyslaw J. Lewyckyj" wrote in message
Scott Ferrin wrote:
Heh, heh. Guess that means there' no way in hell Russia will be able
to afford an equivalent LOL
But Scott,
Conspicuous consumption, is not what it's all about.
Perhaps an equivalent or better, doesn't need to cost
so much ??
What is the problem that needs this gadget to be built?
Perhaps there is/are other solutions!
Rostyk
Surrender? Running away? Those are European solutions.
Hope you aren't including Great Britain in that statement! If so
please apologize forthwith.
When war is suddenly thrust upon you, there is no time to decide about
manufacturing war materials to defend yourself. Perhaps Poland and France,
etc learned something about this earlier?
The US did learn from Pearl Harbor.
The US is always evaluating how to spend its defense dollars. This is one of
the reasons why UAVs and UCAVs are being developed at a feverish pace.
Lots of new things on the horizon like smart bombs that can loister over a
battlefield and return to base if not needed.
UCAVs will be a part of a strike package with many UCAVs flying in the
formation and controlled from a master aircraft. UCAVs will also have A/A
capabilities as well as recon, ecm and ground attack.
Old December 27th 03, 04:49 AM
phil hunt
On 26 Dec 2003 09:41:18 -0800, Jeb Hoge wrote:
(phil hunt) wrote in message ...
On 25 Dec 2003 22:41:36 GMT, Emmanuel.Gustin wrote:
JSF, like TFX before it, is attempting to be a perfect
solution for a set of very diverse problems... Usually
that is more expensive than building three separate
designs.
I always doubted that all three versions of JSF would
go into production. Probably Congress will delete at
least one at some stage, most likely the STOVL version
for the USMC and the RN.
I expect this would **** off the RN somewhat.
If they kill one, it would most likely be the USAF "basic" model.
Maybe, but ditching one would be done for cost purposes, and that's
the cheapest one.
"It's easier to find people online who openly support the KKK than
people who openly support the RIAA" -- comment on Wikipedia
(Email: , but first subtract 275 and reverse
the last two letters).
Old December 27th 03, 07:23 PM
Henry J. Cobb
Peter Kemp peter_n_kempathotmaildotcom@ wrote in message . ..
But it's the only one that can be canceled without leaving a service
without aircraft. The USAF can use the USN version without giving up
too much in performance. Fiddle with the refueling point and presto!
Nope, the most cost effective measure would be to cut the airframe
that will have the fewest built.
Can the F-35C and replace them 1-1 with F-35Bs.
Anyway the Air Force already tried adopting a Navy jet fighter that
didn't have a gun and they don't want to go there again.
-HJC
Old December 27th 03, 07:32 PM
Jim McLaughlin
"Henry J. Cobb" wrote :
SNIPS
Do you mean the F-4 Phantom?
-- Jim McLaughlin
Please don't just hit the reply key.
Remove the obvious from the address to reply.
Old December 27th 03, 09:22 PM
Paul J. Adam
In message , Henry J.
Cobb writes
Yes, it was _embarrassing_ when the Navy was so much more able to turn
"met MiG" into "killed MiG" than the Air Force, even when the Air Force
put guns in their F-4s and the Navy was only using those ineffective,
useless, can't-hit-a-thing "missile" gizmos.
It's a large and extremely complicated subject, but your analysis is
badly off the mark: the F-4 was a very competent aircraft and very few
forces who flew it, regretted doing so: with or without gun fit.
When you have to kill a man, it costs nothing to be polite.
W S Churchill
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
