Minimum rates of climb/descent for VFR
Old February 15th 08, 02:35 AM posted to rec.aviation.student,rec.aviation.piloting
Bertie the Bunyip[_25_]
Default Minimum rates of climb/descent for VFR
Mxsmanic wrote in
WingFlaps writes:
Only true as long as you don't bust airspace or aircraft operating
limitations...
Are there climb/descent rate restrictions for specific airspaces, for
VFR flights operating without ATC restrictions?
In your world? Nope.
Bertie
  #42
Old February 15th 08, 02:37 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic wrote in
gatt writes:
That's how I viewed the question. The airspace/limits don't
specifically refer to VFR cruise, although cruising under VFR would
still make you subject to broader airspace and operating limits.
So are there general limits for climb and descent rates that apply to
VFR?
I know there are constraints for climbs and descents directed by ATC,
but for climbs and descents initiated by the pilot on his own (which
would usually apply only to VFR, although there are some IFR examples,
too), I can't find a specific maximum or (especially) minimum.
You are an idiot
Bertie
  #43
Old February 15th 08, 03:44 AM posted to rec.aviation.student,rec.aviation.piloting
Michael Ash
In rec.aviation.student Bertie the Bunyip wrote:
Yeah, looks ineresting. Some people are mildly worried they might end
the universe as well.
This is the place, anyway..
http://en.wikipedia.org/wiki/Large_Hadron_Collider
Just in case Bertie's wording has made anyone jumpy, the universe itself
does this sort of thing all the time (high-energy cosmic rays smashing
into things) and it's still around.
Michael Ash
Rogue Amoeba Software
  #44
Old February 15th 08, 03:46 AM posted to rec.aviation.student,rec.aviation.piloting
Michael Ash
In rec.aviation.student Mxsmanic wrote:
gatt writes:
That's how I viewed the question. The airspace/limits don't specifically
refer to VFR cruise, although cruising under VFR would still make you
So are there general limits for climb and descent rates that apply to VFR?
Hasn't this question already been answered? Why are you asking it again?
I know there are constraints for climbs and descents directed by ATC, but for
climbs and descents initiated by the pilot on his own (which would usually
apply only to VFR, although there are some IFR examples, too), I can't find a
Gliders have wildly varying rates of climb and descent, it's extremely
common to maintain 1-200fpm down for very long periods of time, and it's
not too uncommon to maintain very slow ascents for long periods of time
either. This is, of course, perfectly legal, and I'm not aware of any
regulation which only makes this sort of thing legal for the propulsively
challenged.
Michael Ash
  #45
Old February 15th 08, 09:53 AM posted to rec.aviation.student,rec.aviation.piloting
WingFlaps
On Feb 15, 9:19*am, Gig 601XL Builder
WingFlaps wrote:
On Feb 15, 12:31 am, "John" wrote:
No there are no regulations for climb or descent rates for VFR flight.
Err I don't think that's 100% correct but it will do for MX.
Cheers
Please then for my benefit point me to such a regulation.
Certainly. Vne is a limit that must not be exceeded (there are
others). This sets a limit on how fast you can legally descend
(remember pilots must fly within operating limits). You must also not
use ascent or descent rate that put you in conflict with ATC unless
you have got clearance. When NORDO you cannot ascend or descend into
controlled space except as part of a flight plan. The descent rate at
or below 500' must be zero or negative except at an aerodrome or
within a LFZ. You can probably now see other examples. Pilots should
think outside the box ;-)
Cheers
  #46
Old February 15th 08, 09:57 AM posted to rec.aviation.student,rec.aviation.piloting
WingFlaps
On Feb 15, 9:24*am, "John" wrote:
Not to get into the whole parsing argument but for the subset of flight
known as VFR, there are no climb and descent rules that apply only to VFR
flight. *The rules about airspace and operating limits apply to both VFR and
IFR flights.
Except when ascent or descent involves separation maybe?
Cheers
Cheers
  #47
Old February 15th 08, 09:58 AM posted to rec.aviation.student,rec.aviation.piloting
WingFlaps
On Feb 15, 9:32*am, Bertie the Bunyip wrote:
WingFlaps wrote in news:043b8c97-e1d9-463a-9d5f-
*Only true as long as you don't bust airspace or aircraft operating
limitations...
Well, neither one has much to do with a vertical speed limit.
A dive which goes over Vne?
Cheers
  #48
Old February 15th 08, 10:01 AM posted to rec.aviation.student,rec.aviation.piloting
WingFlaps
Technically speaking, it is illegal to descend faster than about 25,000fpm
(needs to be adjusted based on density, since it's give in terms of
indicated airspeed) when below 10,000ft. I doubt too many flights would
need to worry about this limitation.
You've got it! Also Vne is usually a lot slower than that for most GA.
There are other "tricky" examples I can think of.
Cheers
  #49
Old February 15th 08, 10:02 AM posted to rec.aviation.student,rec.aviation.piloting
WingFlaps
flight.
25,000fpm (needs to be adjusted based on density, since it's give in
terms of indicated airspeed) when below 10,000ft. I doubt too many
flights would need to worry about this limitation.
Or climb!
But in fact this can be waived and very frequently is.
Damn jet jockies. :-)))
Cheers
  #50
Old February 15th 08, 10:03 AM posted to rec.aviation.student,rec.aviation.piloting
WingFlaps
On Feb 15, 11:52*am, "Darkwing" theducksmail"AT"yahoo.com wrote:
"WingFlaps" wrote in message
Cheers
You can't descend or climb faster than the speed of sound over most land.
Damn.
Good one, I hadn't thought of that.
Cheers
Descent below MDA -- what would you do? Roy Smith Instrument Flight Rules 50 August 29th 05 12:39 AM
ANR squeal on descent Juan Jimenez General Aviation 13 August 19th 05 10:39 PM
descent below minimums hsm Instrument Flight Rules 82 January 11th 05 06:33 PM
BRS and descent rate Roger Long Piloting 21 May 7th 04 05:34 PM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
