#41
#42
On Thu, 08 Jan 2004 05:14:07 GMT, Rick wrote:
wrote: What aircraft would use that setup Rick? I can't imagine how you could drive a prop directly from a turbine engine with no reduction gearing? (or did I misread you?) I think you misread. A turboshaft engine can be used for anything but driving a propeller directly. They are used to power everything from generators and air compressors to ships and water pumps. Some of them, like the GE LM2500 drive the output shaft directly from the power turbine at 3600 rpm so they can be direct coupled to a generator. They do not use a gearbox. Rick The LM2500 definitely has a reduction gear, and is not (in the USN) used to power a generator. In most applications two LM2500 are connected to a common reduction gear. Al Minyard |
#43
On Thu, 08 Jan 2004 05:26:55 GMT, "Gord Beaman" ) wrote:
Rick wrote: wrote: What aircraft would use that setup Rick? I can't imagine how you could drive a prop directly from a turbine engine with no reduction gearing? (or did I misread you?) I think you misread. A turboshaft engine can be used for anything but driving a propeller directly. They are used to power everything from generators and air compressors to ships and water pumps. Some of them, like the GE LM2500 drive the output shaft directly from the power turbine at 3600 rpm so they can be direct coupled to a generator. They do not use a gearbox. Rick Ok, that makes sense as far as it goes...I'm a little surprised at the low speed of that turbine though but then, I'm used to aircraft turbines that rotate much faster, could be something to do with weight requirements though. The other part of your post seems to say that you 'can' drive a prop directly and that's what I was querying actually. Most aircraft turbines driving props rotate at 13,000 - 14,000 RPM and that's much too fast for props so you need reduction gearing. You are right, the LM2500's are geared down, they operate MUCH faster than a ships propeller, which is what they drive. Al Minyard |
#44
Alan Minyard wrote:
The LM2500 definitely has a reduction gear, and is not (in the USN) used to power a generator. In most applications two LM2500 are connected to a common reduction gear. If by "most" you mean the numerical majority, most LM2500 installations are in power generation. A single engine direct drives a generator. Comparatively few of the engines are used for geared marine propulsion systems. Rick |
#45
Rick wrote:
If by "most" you mean the numerical majority, most LM2500 installations are in power generation. A single engine direct drives a generator. Comparatively few of the engines are used for geared marine propulsion systems. Oops, big foot in mouth, just found out there are about 300 more LM2500 engines in military use than civilian power generation. Don't know what percentage of the military installations are geared propulsion though. Probably most of them. Rick |
#46
In article , ] says...
In article , Abe wrote: In article , says... A question-- why haven't any CAS aircrarft been designed with turboprops or the pusher varient (I foreget what you call it)? The Argentinian Pucara is/was a CAS aircraft with turboprops. The Pucara is usually denoted a COIN (Counter insurgency) aircraft. Flying one around a modern battlefield is going to be unhealthy. Absolutely, which demonstrates nicely why turboprops aren't used in CAS aircraft ![]() |
#47
![]() "Abe" wrote in message ... In article , ] says... In article , Abe wrote: In article , says... A question-- why haven't any CAS aircrarft been designed with turboprops or the pusher varient (I foreget what you call it)? The Argentinian Pucara is/was a CAS aircraft with turboprops. The Pucara is usually denoted a COIN (Counter insurgency) aircraft. Flying one around a modern battlefield is going to be unhealthy. Absolutely, which demonstrates nicely why turboprops aren't used in CAS aircraft ![]() Gee, my text indicates there are two mission categories for air support of ground forces--CAS and AI. No mention of "COIN". Which leads me to conclude that COIN is not a mission per se, but more of a "condition set" for missions--the actual missions in support of COIN operations would still be CAS and AI. Brooks |
#48
Rick wrote:
Rick wrote: If by "most" you mean the numerical majority, most LM2500 installations are in power generation. A single engine direct drives a generator. Comparatively few of the engines are used for geared marine propulsion systems. Oops, big foot in mouth, just found out there are about 300 more LM2500 engines in military use than civilian power generation. Don't know what percentage of the military installations are geared propulsion though. Probably most of them. Rick Good man...I have much admiration for a person who, when he finds himself in error, admits it. Good on you sir. -- -Gord. |
#49
#50
Rick wrote:
wrote: who, when he finds himself in error, Thanks, but I am used to it ;-) Rick Yes, I suppose we who do it a lot, deserve less and less credit as time goes on because it becomes easy for us but now if dudley were to ever do it then he'd deserve a purple heart, a ticker-tape parade and a national holiday created for him. Hell, I even saw Rasimus do it recently. Excellent. -- -Gord. |
