#41
![]() Well, the bit of the envelope you're talking about is the low end of the speed envelope fro every airplane. The coffin corner really only applies to high alt/high speed transonic airplanes. When you climb up above transition and reach th ealtitude where the airplane is mach limited the rules changed. I've attached a diagram of a typical flight envelope showing the constant indicated max/min speeds up to transition where they taper in. The point in dashded lines at the top is the point Bob was talking about where both happen at the same time. To maintain a margin a max altitude dictated by a G is determined. Going to fast or sow or pulling too much G at or near max will result in a buffet and loss of lift, just for starters. I've just reposted this because I've gotten some e-mail complaining that the attachment didn't come through. I'll repost that in alt.binaries.pictures.aviation Bertie |
#42
Where did you come to the conclusion it was correct in both cases? I just
said I am not surprised the term got "high jacked. and it wouldn't be the first time" Meaning, incorrectly. I've just never heard it being used associated with the back of the power curve in 50 years of aviation that's all. Could have missed it. Love to see some real documentation. -- BobF. "Dudley Henriques" wrote in message ... Robert Moore wrote: Dudley Henriques wrote Coffin corner is the area behind the curve where sink rate can't be stopped with power but requires reduction in angle of attack. For a perfect example of an aircraft in coffin corner, see the Edwards AFB accident involving a young AF pilot who got his F100 so deep into coffin corner behind the curve he couldn't recover the airplane; not enough air under him to reduce the angle of attack. He applied full burner but couldn't fly it out on power alone. Reduction of angle of attack was what he needed and he didn't have the room. THIS is the definition of coffin corner and it most certainly IS in the area of reverse command. You're kidding, right? Better stick to light plane flight instructing Dudley. I sure don't see the F-100 pilot anywhere near critical mach speed. THAT was NOT a case of "coffin corner". From Wikipedia, the free encyclopedia Coffin corner (aviation) The coffin corner or Q-Corner is the altitude at or near which an aircraft's stall speed is equal to the critical Mach number, at a given gross weight and G loading. At this altitude the aircraft becomes nearly impossible to keep in stable flight. Since the stall speed is the minimum speed required to maintain level flight, any reduction in speed will cause the airplane to stall and lose altitude. Since the critical Mach number is maximum speed at which air can travel over the wings without losing lift to flow separation and shock waves, any increase in speed will cause the airplane to lose lift, or to pitch heavily nose- down, and lose altitude. The "corner" refers to the triangular shape at the top of a flight envelope chart where the stall speed and critical Mach number lines come together. Some aircraft, such as the Lockheed U- 2, routinely operate in the "coffin corner", which demands great skill from their pilots.[1] From Wikipedia, the free encyclopedia Slow flight Slow flight is a portion of an airplane's performance envelope above the speed at which the plane will stall, but below the aircraft's endurance speed. This part of the performance chart is also known as "the back side of the power curve" because when flying in this area, more power is required in order to go slower and still maintain straight and level flight. A large angle of attack is required in order to maintain the altitude of the aircraft. Bob Moore For God's sake Moore, try actually READING these posts before shooting off your mouth once in a while. Our mutual dislike for each other is legendary by now. As usual, you are beating a dead horse here. Coffin corner is explained in full in several posts above. The use of the term is correct in BOTH instances! -- Dudley Henriques |
#43
Right, right...it is actually controlled by tabs, my slip. Boy, not many
know that either, I'll bet. Anyway, if you pull too hard, they stall, that is won't move, So you have to relax the back pressure almost completely and then pull not so hard the next time. Weird feeling when you are descending, trying to check altitude quickly, and don't know what's happening. -- BobF. "Bertie the Bunyip" wrote in message ... "Bob F." wrote in news ![]() Yes, you learn a lot about Dutch rolls real quick. ...and I did experience a elevator hydraulic cylinder stall once in a 707. That was an experience. Ouch. I didn't know they had hydraulics on the elevator. I thought the 707 was all tab control except the rudder. I had a pitch problem in an A300 at about FL190 once. That was pretty exciting, but since it was the automatics that caused it we were able to disconnnect and get it all back under control. Scared the crap out of us. We thought we had something on the airframe come loose and cause the pitch problems. Nothing else made sense until we got down and maintenence diagnosed the problem. We got a mach buffet recovering (2.5 G) but of course that part of it wasnt too dramatic because of the relatively low altitude. It would have been a different story at 330 ( the 'Bus was not good at altitude) Bertie |
#44
Well, I'll tell you right here and now.
Seems Jack, who already had lots of test hours in the 100 and made a flight to NY already, was preparing for a flight to the air show in England. Bill Allen (president) came on board just before he was about to depart and said. "You know Jack, if you don't want to make a maiden cross Atlantic flight now, it's ok, we don't have to take this plane there." Jack said "It's ok Bill, I don't see any problem in doing so". Bill nodded and walked off the plane but came back a few minutes later and said "Jack, I'm serious, if you feel any reason why you don't want to make the flight, it's ok", Jack looked a little puzzled but said "It's ok Bill, I have no bad feelings at all about it and I feel completely confident it'll be ok" Bill looked at Jack for a few seconds, said nothing and walked of the plane but returned almost immediately and said "Jack, I know you'll do the right thing, but when you get to the air show, please don't roll this airplane !" -- BobF. "Bertie the Bunyip" wrote in message ... "Bob F." wrote in : Bertie, Did your mole ever tell you the story about Jack Waddell when he took the maiden 747-100 flight to Farnborough? Nope don't think he would have known. He operated in some weird way with Boeing. Because he did defense stuff he was isolated. I just meant he knows how all this stuff works. Do tell, though.. bertie |
#45
On Mar 15, 7:10 pm, Dudley Henriques wrote:
Bob F. wrote: "Dragging it in" does not necessarily mean "in in the area of reverse command". It just means that you have added power instead of reducing drag by retracting flaps or gear, etc. "The area of reverse command" is an exteme example. The coffin corner of the back side of the power curve is the extreme. You can add power flaps or no flaps and still be well on the front side of the power curve. Generally speaking, if you are "dragging it in, you are most certainly in the area of reverse command -- Dudley Henriques Wouldn't a more exact definition be that the "region of reversed command" is that condition where induced drag is at its greatest, pitch only controls airspeed, and power only controls altitude? One can "drag in" and airplane and not meet all the aforementioned conditions. The usefulness of this condition is apparent in short field landings. Dan Mc |
#46
Well I only have a few 707 hours like 200, but in the first model there was
a hydraulic system between the elevator and tab. I thought it was on all models. That's all I know about it. This was the model without the Yahoodi. -- BobF. "Robert Moore" wrote in message 46.128... "Bob F." wrote Yes, you learn a lot about Dutch rolls real quick. ...and I did experience a elevator hydraulic cylinder stall once in a 707. That was an experience. Tell us more about that "elevator hydraulic cylinder". I have flown just about every model B-707/720 made and they all had elevators operated by control tabs which were moved by the yoke. No hydraulics what-so-ever, the elevators actually free-floated until the aircraft was moving at a fair speed. The only hydraulic flight controls on the B-707 were the rudder and the flaps and the spoilers. Bob Moore ATP B-707, B-727 PanAm (retired) |
#47
Bertie the Bunyip wrote:
Well, the bit of the envelope you're talking about is the low end of the speed envelope fro every airplane. The coffin corner really only applies to high alt/high speed transonic airplanes. When you climb up above transition and reach th ealtitude where the airplane is mach limited the rules changed. I've attached a diagram of a typical flight envelope showing the constant indicated max/min speeds up to transition where they taper in. The point in dashded lines at the top is the point Bob was talking about where both happen at the same time. To maintain a margin a max altitude dictated by a G is determined. Going to fast or sow or pulling too much G at or near max will result in a buffet and loss of lift, just for starters. I've just reposted this because I've gotten some e-mail complaining that the attachment didn't come through. I'll repost that in alt.binaries.pictures.aviation Bertie If you read my post first mentioning "coffin corner", you will notice I used it as an adjective to describe a "condition" found t the extreme end of the back side of the power curve; this being the "condition" where low altitude and no more power available necessitate a reduction in angle of attack to stop a developing sink rate; a very dangerous situation on any approach. It should be obvious that I never meant to convey that the term "coffin corner" didn't refer to it's classic definition for high altitude critical mach vs stall condition. I will not get into a shouting match with Usenet advasiaries who wish to convey I have no idea what coffin corner is as defined in the aeronautical engineering sense. Good God, I've even heard coffin corner used to define the warnings block on an approach plate! -- Dudley Henriques |
#48
"Bob F." wrote in
: Right, right...it is actually controlled by tabs, my slip. Boy, not many know that either, I'll bet. Anyway, if you pull too hard, they stall, that is won't move, So you have to relax the back pressure almost completely and then pull not so hard the next time. Weird feeling when you are descending, trying to check altitude quickly, and don't know what's happening. i retrained a lot of 707 guys on the 727 and the 'Bus and they had the weirdest way of flying! They'd start to interecept an altitude with thousands of feet to go sometime. They also used to just about have a heart attack if you used the speedbrake. Bertie |
#49
"Bob F." wrote in
: Well, I'll tell you right here and now. Seems Jack, who already had lots of test hours in the 100 and made a flight to NY already, was preparing for a flight to the air show in England. Bill Allen (president) came on board just before he was about to depart and said. "You know Jack, if you don't want to make a maiden cross Atlantic flight now, it's ok, we don't have to take this plane there." Jack said "It's ok Bill, I don't see any problem in doing so". Bill nodded and walked off the plane but came back a few minutes later and said "Jack, I'm serious, if you feel any reason why you don't want to make the flight, it's ok", Jack looked a little puzzled but said "It's ok Bill, I have no bad feelings at all about it and I feel completely confident it'll be ok" Bill looked at Jack for a few seconds, said nothing and walked of the plane but returned almost immediately and said "Jack, I know you'll do the right thing, but when you get to the air show, please don't roll this airplane !" Heh heh. I wonder if anyone has. I know someone who claims to have rolled a Convair 880 9 the FAA's own flying lab) and some Lufty guys tried to roll a 707 and pulled two engines off it ( so the story goes, anyway) The 757 would be a piece of cake to roll if you were so inclined. The sim does some fine aerobatics anyway. Bertie |
#50
Dan wrote in news:a7bc480e-2c0d-44ee-b560-e8d7aaa866a5
@p73g2000hsd.googlegroups.com: On Mar 15, 7:10 pm, Dudley Henriques wrote: Bob F. wrote: "Dragging it in" does not necessarily mean "in in the area of reverse command". It just means that you have added power instead of reducing drag by retracting flaps or gear, etc. "The area of reverse command" is an exteme example. The coffin corner of the back side of the power curve is the extreme. You can add power flaps or no flaps and still be well on the front side of the power curve. Generally speaking, if you are "dragging it in, you are most certainly in the area of reverse command -- Dudley Henriques Wouldn't a more exact definition be that the "region of reversed command" is that condition where induced drag is at its greatest, pitch only controls airspeed, and power only controls altitude? One can "drag in" and airplane and not meet all the aforementioned conditions. The usefulness of this condition is apparent in short field landings. Wel, I don't do it and I bet you ten bucks I can pull off the runway shorter than you. Bertie |
Thinking about stalls | WingFlaps | Piloting | 43 | April 12th 08 09:35 PM |
Stalls?? | Ol Shy & Bashful | Piloting | 155 | February 22nd 08 03:24 PM |
why my plane stalls | Grandss | Piloting | 22 | August 14th 05 07:48 AM |
Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 05:23 PM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
