#41
#42
![]() "Gig 601Xl Builder" wrote in message m... And now with the link... http://www.autofuelstc.com/autofuelstc/pa/ethanol.html Thanks Gig. I missed that page. The problem that I have with some of the reporting is that there isn't much supportive data. To wit: Corrosion of aircraft fuel systems. Specifically what systems and what are the differences in auto that allow them to use the E-10 with apparent immunity? I've heard that the gravity fed fuel systems don't seem to experience the vapor locking and I've never experienced carb ice in any vehicle but my VW. The CAT gage on my Lycoming never gets within a large margin of the yellow zone and even in Canada along side the lakes with temps in all ranges from 20 F to 80 F have I ever encountered any hint of carb ice in my installation. Now with the metal floats in the carburetors, I can't see how alcohol would affect that. Some of the O rings in the gascolators and fuel shut off valves might need changing. I fully expect to lose some power using Supreme with 10% ethanol, but at price differentials exceeding $1.00/ gal? I'm going to get some 10% Ethanol Supreme and put one of my A/C quality fuel lines in it and let it soak. Thanks again for the link. BTW are you going to Oshkosh this year? We will be covering the helicopters down at the Ultralite runway again. Stu |
#43
![]() On Mon, 28 Apr 2008 21:13:16 -0700, "Stuart & Kathryn Fields" wrote: Well it has happened. Local 100LL is $5.60/ gal and is not expected to decrease. Is there anyone out there using Supreme MoGas in a Lycoming 0320 with 8.5:1 compression? If so what ignition timing changes were needed if any? thanks Stu Fields I have an 0-320 clone from ECI 160hp with an Emag Pmag electronic ignition. The ignition has a feature that allows me to switch between maximum advance depending on the fuel being used. I believe it's a 4 degree difference but that's just from memory you might find some usefull information poking around the emagair site. I haven't used any mogas yet cuz I'm in a fuel co-op and right now 100LL is 7 cents a litre cheaper than regular unleaded. |
#44
Stuart & Kathryn Fields wrote:
"Gig 601Xl Builder" wrote in message m... And now with the link... http://www.autofuelstc.com/autofuelstc/pa/ethanol.html Thanks Gig. I missed that page. The problem that I have with some of the reporting is that there isn't much supportive data. To wit: Corrosion of aircraft fuel systems. Specifically what systems and what are the differences in auto that allow them to use the E-10 with apparent immunity? I've heard that the gravity fed fuel systems don't seem to experience the vapor locking and I've never experienced carb ice in any vehicle but my VW. The CAT gage on my Lycoming never gets within a large margin of the yellow zone and even in Canada along side the lakes with temps in all ranges from 20 F to 80 F have I ever encountered any hint of carb ice in my installation. Now with the metal floats in the carburetors, I can't see how alcohol would affect that. Some of the O rings in the gascolators and fuel shut off valves might need changing. I fully expect to lose some power using Supreme with 10% ethanol, but at price differentials exceeding $1.00/ gal? I'm going to get some 10% Ethanol Supreme and put one of my A/C quality fuel lines in it and let it soak. Thanks again for the link. BTW are you going to Oshkosh this year? We will be covering the helicopters down at the Ultralite runway again. Stu The biggest problem IMHO is that it holds water. All the other issues such as it eating the rubber can be dealt with but you can't make Ethanol not hold water. As for OSH this year I don't know. Hopefully about that time I will be finishing up the engine install on my 601XL and since I have waited a while to get the engine (technically I still am waiting)I'm going to be hard pressed to make myself break away from building to make it. But Hell or high water I will be there in 2009 and will be spending quite a bit of time down with the helos because I really want to build a Mosquito. And speaking of the Mosquito. Will those floats on the UL version really float the helo and would the deployable floats from say a Bell 206 qualify the Mosquito to still be flown as a UL? |
#45
Gig 601Xl Builder wrote:
The biggest problem IMHO is that it holds water. All the other issues such as it eating the rubber can be dealt with but you can't make Ethanol not hold water. Turn it around, Gig. Look at it as a safety feature. Ethanol in the fuel might absorb any water in the tanks avoiding an engine failure. Richard -- (remove the X to email) Now just why the HELL do I have to press 1 for English? John Wayne |
#46
cavelamb himself wrote:
Gig 601Xl Builder wrote: The biggest problem IMHO is that it holds water. All the other issues such as it eating the rubber can be dealt with but you can't make Ethanol not hold water. Turn it around, Gig. Look at it as a safety feature. Ethanol in the fuel might absorb any water in the tanks avoiding an engine failure. Richard That's what all those drains are for. My little 601 will have three places designed to get water out of the fuel before it gets sucked in to the engine. |
#47
m... cavelamb himself wrote: Gig 601Xl Builder wrote: The biggest problem IMHO is that it holds water. All the other issues such as it eating the rubber can be dealt with but you can't make Ethanol not hold water. Turn it around, Gig. Look at it as a safety feature. Ethanol in the fuel might absorb any water in the tanks avoiding an engine failure. Richard That's what all those drains are for. My little 601 will have three places designed to get water out of the fuel before it gets sucked in to the engine. Richard's poiint was well worth noting. AFAIK, in automobiles, wich generally have no drains, when a problem of water in the fuel tank is encountered, it is normally resolved by adding alcohol. One of the other alcohols is normally used, because of the beverage tax applied to pure ethanol; but, according to my local mechanic, that gets the car running so that the fuel can be successfully consumed in the normal way. At least in theory, that would result in a slight and temporary reduction in horsepower; but it is hard to imagine a situation where the loss would exceed 5 of 10 percent--even on a carbureted engine. Peter |
#48
"Sliker" wrote in message
... I've got the same engine in my plane, it's an O-320 D2C, but there are other number series with the same compression ratio in the 160hp class. That engine is listed on Peterson's mogas STC site as one that is approved for premium unleaded autofuel. So you shouldn't run into any problems as far as detonation goes, vapor lock is another issue, and is different in each aircraft type. Just the other day a pilot at my local airport said that if the gas has the common 10% ethanol added, it's vapor lock potential goes up a lot. I'm not sure about those facts, but I think it has more to do with fuel system design. Gravity flow systems seem almost immuned to that problem. With wing tanks below the carb, the best setup is to have fuel pumps at the tank "pushing" the fuel to the carb. Rather than the more common setup of the fuel pump in the engine compartment sucking the fuel from the tank. Peterson's website has a good dissertation about homebuilts worth reading, in regards to fuel system design to help prevent vapor lock. Back when the Mogas STCs, or "Autogas STC" as they were then called, were being proposed, tested, and certified; all of these issues and more were quite hotly debated in "Sport Aviation", "AOPA Pilot", "Flying", and I believe "Aviation Maintenance" and "Aviation Consumer", to name just a few. At that time, some of the original researchers were still in good health--who were present when the Av-Gas Mil Spec was first written. At least one of them asserted that there was considerable doubt that the very low vapor presure spec was usefull, and that it was the result of an error at the time; but that there had simply never been a strong enough motivation to change it, since the engines ran well on the fuel as specified. So the bottom line is probably that the REAL problem with adding 10% ethanol to the STCs might be that the automotive fuel formula would subsequently be changed to a greater percentage, or possibly to some other additive or dilutant. Then the entire tedious and costly process would need to be duplicated yet again. Also, just as a reminder, the original motivation was to allow Mogas to be sold by FBOs as a replacement for 80-87 Avgas. The cost it was mainly intended to reduce was the expense and downtime that occurred due to fouled valves and spark plugs--especially in trainers which were commonly operated with full-rich mixture much of the time. Peter |
#49
On Wed, 14 May 2008 14:27:06 -0700, "Stuart & Kathryn Fields"
wrote: "Sliker" wrote in message .. . I've got the same engine in my plane, it's an O-320 D2C, but there are other number series with the same compression ratio in the 160hp class. That engine is listed on Peterson's mogas STC site as one that is approved for premium unleaded autofuel. So you shouldn't run into any problems as far as detonation goes, vapor lock is another issue, and is different in each aircraft type. Just the other day a pilot at my local airport said that if the gas has the common 10% ethanol added, it's vapor lock potential goes up a lot. I'm not sure about those facts, but I think it has more to do with fuel system design. Gravity flow systems seem almost immuned to that problem. With wing tanks below the carb, the best setup is to have fuel pumps at the tank "pushing" the fuel to the carb. Rather than the more common setup of the fuel pump in the engine compartment sucking the fuel from the tank. Peterson's website has a good dissertation about homebuilts worth reading, in regards to fuel system design to help prevent vapor lock. On Mon, 28 Apr 2008 21:13:16 -0700, "Stuart & Kathryn Fields" wrote: Well it has happened. Local 100LL is $5.60/ gal and is not expected to decrease. Is there anyone out there using Supreme MoGas in a Lycoming 0320 with 8.5:1 compression? If so what ignition timing changes were needed if any? thanks Stu Fields Sliker: Thanks for the answer. Most of the rest of the responses ignored my question but assumed that I needed either a course in accounting or fossel fuel economics, or some barroom counseling in an attempt to reduce my grief over the increased fuel prices. I looked into the Peterson site and got a bunch of useful info. I've also found several University studies that have looked into alternative fuels to and including 100% ethanol. More studying is required. Somewhere in my excellent memory that I have limited access to, is an anecdote of some guy who has been using MoGas in his Lycoming equipped Stinson for quite a few years. The ethanol aspect was not discussed and his history certainly started before the ethanol additive. For the very near future I will be mixing Supreme with 100LL until the LL runs out. When I switch to 100% Supreme, I will be hovering my helicopter for a few hours and keeping track of the CHT, EGT, MP etc. Not a safe thing to do. You must have not read the petersen page about not using gas with alcohol added. Thanks again for useful response. stu Roger (K8RI) ARRL Life Member N833R (World's oldest Debonair) www.rogerhalstead.com |
#50
On Wed, 14 May 2008 17:03:17 -0700, "Stuart & Kathryn Fields"
wrote: "Gig 601Xl Builder" wrote in message om... And now with the link... http://www.autofuelstc.com/autofuelstc/pa/ethanol.html Thanks Gig. I missed that page. The problem that I have with some of the reporting is that there isn't much supportive data. To wit: Corrosion of aircraft fuel systems. Specifically what systems and what are the The problem is Alcohol and bare unprotected aluminum don't mix. IOW, Alcohol his highly hygroscopic.(IT not only absorbs water - A little will dissolve liquid water into gas preventing gas line freeze - "DryGas", but is corrosive to Aluminum differences in auto that allow them to use the E-10 with apparent immunity? Automotive fuel systems use steel fuel lines although for E85 they should be using SS lines and tanks, but I doubt any do. Those fuel systems are also living on borrowed time. I've heard that the gravity fed fuel systems don't seem to experience the vapor locking and I've never experienced carb ice in any vehicle but my VW. I'd think a pressure system would be more immune than gravity fed. The CAT gage on my Lycoming never gets within a large margin of the yellow zone and even in Canada along side the lakes with temps in all ranges from 20 F to 80 F have I ever encountered any hint of carb ice in my installation. Now with the metal floats in the carburetors, I can't see how alcohol would affect that. Some of the O rings in the gascolators and fuel shut off valves might need changing. I fully expect to lose some power using Supreme with 10% ethanol, but at price differentials exceeding $1.00/ gal? Some parts in the carb are aluminum or soldered such as the float which is two brass shells soldered together. I'm going to get some 10% Ethanol Supreme and put one of my A/C quality fuel lines in it and let it soak. It takes time. You might run several years without problems. My Deb has bladder tanks (Neoprene impregnated canvas I believe) they would not stand up. The tip tanks are bare fiberglass and resin. They too dislike Alcohol. However the big Continental needs 100 octane. Thanks again for the link. BTW are you going to Oshkosh this year? We will be covering the helicopters down at the Ultralite runway again. Stu Roger (K8RI) ARRL Life Member N833R (World's oldest Debonair) www.rogerhalstead.com |
Pheobus C prices in the US? | [email protected] | Soaring | 3 | January 10th 07 06:15 PM |
Gas Prices | Newps | Piloting | 0 | October 27th 05 09:17 PM |
Fuel prices | Paul kgyy | Owning | 14 | October 19th 05 10:55 PM |
Gas Prices -- Help at last? | Jay Honeck | Piloting | 327 | October 16th 05 01:09 PM |
Gas Prices | Tony | Owning | 19 | April 16th 04 02:38 AM |
