Seniors USA 2009 Start and Finish notes..... # 711 reporting
Old March 17th 09, 02:09 PM posted to rec.aviation.soaring
Default Seniors USA 2009 Start and Finish notes..... # 711 reporting
What we saw on the new start at the Seniors was in simple
words....works great, will be good for along time. Just a note you
might want to remember. When you leave threw the top, make sure your
flown distance agrees with the distance given you by the scorer. Most
of us found a good thermal, dropped down into the cylinder for our 2
minutes below MSH and then thermaled up in the thermal, staying below
cloud base and left on course.
On the finish. Now, this is for you, Joe the sailplane racers, you
need to slow down before crossing into the finish cylinder at the
minium finish height. Your altimeter will read wrong at the end of the
day and your logger will lag when you cross into the cylinder. We saw
alot of finish penalities of 10 to 30 points because some guys were
coming in at 130 KTS and crossing into the clyinder at what their
altimeter said. Well, we all were warned its best to slow down before
crossing into the cylinder at least 10 seconds before you get their
and don't count on your altimeter to read correctly at the end of the
day. You will lose the fight with the scorer as he uses your logger
and what it reads as your altitude when you finish. He DOESN'T see
your cockpit altimeter when you finish.
That about covers the new start and finish. We had limited internet
coverage here at the Seniors and posting news and information was not
easy. I did try and post the last day information, but I couldn't get
service. My next stop is Perry and hopefully will be able to update my
blog with daily news.
Also, for those who race sports class, new 2009 handicaps need to be
checked. Its best to take your given handicap speed and divide by the
raw speed on your score sheet to see if your handicap is correct. It
might be a tad off because of the weight adjustment, but if its alot
off, either way, bring it to the attention of the scorer. This may be
best by writing down your case as then it will be addressed.
Thermal tight, Soar high, Fly safe. #711 reporting.
Last Day Seniors USA 2009 #711 reporting [email protected] Soaring 0 March 15th 09 02:12 AM
Day 2 Seniors USA 2009 711 reporting. [email protected] Soaring 4 March 13th 09 01:10 AM
Seniors USA 2009 #711 reporting. [email protected] Soaring 1 March 9th 09 02:03 AM
# 2 Day 05 Seniors USA # 711 reporting [email protected] Soaring 2 March 11th 05 07:36 PM
Rules for 1000k with start/finish at midpoint. Andrew Warbrick Soaring 2 August 10th 04 05:04 AM
