Who do you drop a nuclear bunker buster on?
Old June 5th 04, 11:10 PM
Dave Eadsforth
In article , Paul F Austin
writes
"Dave Eadsforth" wrote ...
Jim Yanik wrote
Any deep mine that had a nuclear explosion nearby deep underground would
have it's shafts collapse,or become inaccessible,just as effective as
destroying the WMD itself. They might even flood.
At one point, it was feared that an exploding nuke could send a stream
of VERY hot gasses along tunnels, thus spoiling everyone's day.
However, later modelling (and maybe even testing) revealed that an
underground nuclear explosion in an area containing shafts and tunnels
tends to crush them flat, thus sealing them and saving the rest of the
complex further damage. So, the lesson appeared to be; don't build
caverns, stick to tunnels and shafts.
That's interesting. Do you have a cite for that?
I'm afraid not - it was described in a newspaper article many years ago,
During the underground test
era, in one test the blast doors failed. During a UGT, explosive-powered
doors located a short distance from the bomb chamber close after the prompt
radiation pulse drops off (a few hundred nanoseconds) and before the blast
wave arrives, to preserve the down-hole equipment. In one test, the doors
failed and the VERY hot gasses (and lots of fission fragments) both melted
and contaminated the equipment in the test galleries quite far back from the
bomb chamber.
Was that because the blast hit the tunnel head on? If so, I could
imagine the VERY hot gases etc going straight down the tube. However,
if the complex were built of tunnels that zig-zagged sharply, the nuke
would move enough rock to crush tunnels at 90 degrees to the explosion
and any hot stuff entering a tunnel head on to begin with should be
blocked when a section at 90 degrees to it collapsed.
I still think that earth penetrating nuclear weapons is the triumph of "Wow,
a NUKE" thinking over the realistic limits of what a nuclear weapon can do.
Interesting point...
Cheers,
Dave
Dave Eadsforth
  #42
Old June 6th 04, 03:10 AM
Paul F Austin
"Dave Eadsforth" wrote in message
writes
would
prompt
blast
melted
bomb chamber.
The test galleries for UGTs were layed out herringbone fashion along a main
tunnel. Each test gallery could "see" the nuclear explosion so that the test
articles could be exposed to both thermal and nuclear (the two blur together
somewhat) radiation. The blast doors were build to withstand the
overpressures that the bomb would generate. In the UGT where they failed, it
was the closing mechanism that failed to operate rather than the doors being
breached.
As I understand it, the argument for building penetrating nuclear weapons is
that the weapon will volatilize any agents (chemical or biological) that are
present before they can leak out.. That seems iffy to me. As far as
"crushing" tunnels, there won't be much crushing going on much outside the
facture zone, which for a full yeild B61 (300KT) is about 900 feet radius.
Any bunker more than a few multiples of that distance away will get a
hellacious shock but if competently designed, should remain intact.
Enthusiasts keep ignoring these unpleasant facts and suppose that
ground-penetrating RADAR or some other MagicTech will give the attackers
x-ray glasses so that they can see more or less where the bunkers really
are. Fat chance. I mentioned up-thread that modern tunneling equipment can
drive a shaft 200 feet a day. With a year to prepare, without superb HUMINT
it's all going to be a mystery to the targeters, even with nukes at their
disposal.
  #43
Old June 6th 04, 07:32 AM
Dave Eadsforth
writes
writes
would
prompt
blast
melted
bomb chamber.
So; exposed on purpose. If thin tunnels were zig-zagged like a WWI
trench system with bulkheads between, I guess that might help a bit.
breached.
Bet that annoyed some designer...
Hmm, nuke has to be accurately targeted then - I suppose they might run
to the cost of GPS guidance for this type of bomb...
But the shock of the explosion would cause those bunkers safely beyond
the fracture zone to rock and roll like hell. I read somewhere that the
interior facilities at Cheyenne Mountain were resting on humungous sized
springs - is that the only option for resilience?
disposal.
So, what to we conclude when a country orders a set of tunnelling
equipment, ostensibly to build a metropolitan subway, and then gives up
'because the geology is all wrong' (um, wouldn't that have come out of
the original survey?)? Is the kit sitting in a junkyard - or is it now
underground, doing something else?
Cheers,
Dave
Dave Eadsforth
  #44
Old June 6th 04, 11:20 AM
Paul F Austin
Paul F Austin writes
main
test
together
That's direct nuclear and thermal radiation, more or less direct line of
sight. There's also the fireball, which can expand around corners. I think
that if a nuke is _in_ the bunker with you, that you're in trouble. Blast
doors may contain the effect but life's hard. The problem is to _get_ the
nuke onto the target. Underground targeting is pretty much impossible. There
are some signatures from shallow excavation but they're subject to spoofing
and maskirovka. How many nuclear munitions are you going to be allowed to
use in a hunt n' peck strategy?
it
being
breached.
is
are
radius.
No, it's not so much the accuracy required of the weapons as it is accuracy
in target detection. From Glassstone, "relatively small, heavy, well
designed structures" suffer light damage at 2 1/2 times the apparent crater
radius (2200 feet in this case). This is damage to the bunker itself and not
the contents.
There will be two zones around a nuclear explosion: the area near the
fracture zone where any bunker will collapse and and area around that where
the contents of the bunker won't survive. The outside that, dust trickles
out of the ceiling, everyone hunches their shoulders and then straightens up
and carries on.
Again, from Glasstone, internal equipment will be destroyed by a 7g shock if
not shock mounted and about 60g if it is. The modelling of shocks on
equipment is complex and outside a USENET discussion.
can
HUMINT
disposal.
North Korea for instance doesn't even pretend to be building subways.
They've been tunneling for fifty years and the area near the DMZ (and under
it) is honeycombed with tunnels.
This is a hard problem and one that the puissance of nuclear weapons doesn't
solve.
  #45
Old June 6th 04, 02:58 PM
David Nicholls
For deep hard rock mining you use drilling and blasting techniques
(commercial explosives and BIG drills). This is how the South African gold
mines extract over 130 million tons of rock (and gold ore) every year from
as deep as 4km (2.5 miles) - with plans to go deeper in future. Modern
tunnelling equipement as you discuss only work in soft rock. So you would
have to stop anyone who has access to simple commecial explosives - which is
simple to manufacture.
Da vid
  #46
Old June 6th 04, 09:39 PM
Howard Berkowitz
In article , "Paul F
under
Perhaps if that part of the world calms down, and even reunifies, Korea
will become the dominant world power in mushroom farming.
  #47
Old June 6th 04, 09:43 PM
Tetherhorne P. Flutterblast
"Who do you drop a nuclear bunker buster on?"
Any greasy, finger-eating Arab I can plop my thermonulear greeting
card on.
Libya Returns Nuclear Fuel to Russia Dav1936531 Military Aviation 3 March 17th 04 05:29 PM
About when did a US/CCCP war become suicidal? james_anatidae Military Aviation 96 February 29th 04 03:24 PM
Czechoslovak nuclear weapons? Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) Matt Wiser Military Aviation 25 January 17th 04 02:18 PM
Enola Gay: Burnt flesh and other magnificent technological achievements me Military Aviation 146 January 15th 04 10:13 PM
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) Matt Wiser Military Aviation 0 December 7th 03 08:20 PM
