#41
"Keith Willshaw" wrote in message ...
"Eunometic" wrote in message ... At a speed of 123mph it was far to slow and suffered form Albatross attacks even with its rear lewis gun. Only the realisation that it could dog fight as well as most fighters saved this scout from being a flop. Which is like saying the only thing that save the Me-109 from being a flop is that it was a good fighter. A decisive advantage in WW1 would have required a speed of 160-170 mph which would be decisevly beyond anything. It would also require a bomb load of over 2200lbs as this would allow large torpoedoes and sticks of bombs and a range of up to 1000 miles for a bomber. Sufficient of these could shift the balance at sea, be able to destroy logistics, bridges, docks, etc and factories I think. I doubt it, as WW2 showed you need much more range and payload than that for the strategic mission. Better aircraft such as the He-111 and Do-17 failed in that role Keith However both these fine aircrat, virtualy invulnerable in the Spanish civil war and against Polish aircraft, had to face of against spitfires and hurricanes. In this hypothetical situation our technology would provide enough of a leap to make them immune to any interception. The performance I mentioned, perhaps the range is a little short, would allow attack as low as 5000 feet with freedom from interception by biplane and with a very low chance of being hit by the AAA of the day. Level bombing at 5000 feet even without computing bomb sights is very accurate and at 1000 feet even moreso. Without the need to attack at night or high altide with low accruracy they would deliver great and accurate destruction. I've heard it said that a squadran of Ju 87 Stukas could do more damage than a squdran of Lancasters as long as they were either escorted or not heavily opposed. |
#42
"Nicholas Smid" wrote in message ...
"Eunometic" wrote in message ... "Keith Willshaw" wrote in message ... "Eunometic" wrote in message om... "Charles Talleyrand" wrote in message I suspect if an engineer of the capability of Hugo Junkers had of produced a light weight air cooled radial for mating with an Junker J1 style airframe an immensly fast and tough aircraft would have resulted. (I would say speeds of 160-170mph). What you are describing is basically the Bristol F2b Fighter of 1918, except that it had a water cooled engine. The type remained in service until 1932 Keith At a speed of 123mph it was far to slow and suffered form Albatross attacks even with its rear lewis gun. Only the realisation that it could dog fight as well as most fighters saved this scout from being a flop. A decisive advantage in WW1 would have required a speed of 160-170 mph which would be decisevly beyond anything. It would also require a bomb load of over 2200lbs as this would allow large torpoedoes and sticks of bombs and a range of up to 1000 miles for a bomber. Sufficient of these could shift the balance at sea, be able to destroy logistics, bridges, docks, etc and factories I think. The Atlantic/Fokker B-8 from 1929/31 pretty much fills that order, top speed of 160 mph, 950 mile range 1600 lb bomb load, steel tube and wood construction. It had 600 hp V-12's, a fair step up from the Liberty but probably not an impossible jump, though you're probably going to have mass production problems. For a fighter you could start with the PW-8, top speed of 171 mph and a 435 hp V-12, structure is wood and fabric and its a bi plane so not too many nasty shocks for the pilots, from 1922/24, one of them flew with a turbocharger, one of the first though building them might be a bit tough, and not really needed for WWI. It would seem to me that the engine and aircraft constructors would be able to quickly produce superior aiircaft with their then current fabrication and knowledge becuase. 1 The vibration and cooling problems they had would be solved by the plans given them. 2 The alloys would have to be made but would have the appropriate properties. 3 Some issues such as fuels and maybe oils (some vegetable oils are superior to synthetics) but 4 I suspect that they engine designes could be adapted for the lower grade fuels but still achieve superior performance. The aircraft would have to be hand made by craftsmen and this would slow down production. 5 Devices such as accurate altimeters and artificial horizons did not yet exist but I believe these shouldn't be to difficult. |
#43
alfred montestruc wrote:
"Keith Willshaw" wrote in message ... "alfred montestruc" wrote in message Point of fact, I am very sure that alloys needed either existed, or reasonable substitutes did. Evidence please Artillery gun tubes of that era. They were (obviously) subjected to high stresses for many thousands of repititions. Obviously the pressures in a gun tube near the breech during fireing of an artillery gun are much larger than in an IC engine that has a peak compression ratio of 10:1 at most. Imagine if you will I take say a 75mm cannon, hone the bore free of rifling, then cut it into 6" section to make cylinders for a radial engine. I can make the engine block out of a ductile iron casting, the pistons, rods, and shaft from forgings of the same alloy as the gun tube is made from. I can then machine fins on the outside of the cylinders and bolt them to the block. See any showstoppers? Weight? We do want to fly, rather than tow, this thing around. What is the thickness of a cannon barrel wall compared to an engine cylinder? What happens to the strength of that cylinder when we reduce its thickness with machined cooling fins? What would the weight of an engine built in this manner be, compared to the engines of the day? They've been making cannons for 600 years. Not certain I'd want one as a cylinder in my truck, let alone a combat aircraft. SMH |
#44
#45
The Horny Goat wrote:
Vietnam certainly demonstrated napalm could be effectively delivered in bomb form though... That was proved (again?) in Korea. I question whether it was available in large enough quantities to cause grief to miles and miles of trench lines. Napalm was available in sufficient quantities to turn targets such as trenches into graves, once we found them. "Shake and bake" also worked on other related targets Napalm was a bit more expensive to apply than the targets and their defenses were to construct, of course. But we solved that problem nicely by avoiding the highest value targets. We became expert at killing trees and dirt in the South, and avoiding ships, port facilities, and dams in the North. Heaven forbid we should destroy the enemy's ability to resist when it is so much more convenient to destroy the environs of our allies. But then war being diplomacy by other means, the so-called "diplomats" had their way, just as they are doing today. Jack |
#46
The Horny Goat wrote in message . ..
On 8 Jun 2004 04:16:21 -0700, (Jack Linthicum) wrote: Flamethrowers need someone on the cold end to run it, IIRC in WWII this was an aiming point for the Japanese who were being assualted by them. Napalm is more fluid, ie runs along trench lines, and less personal, drop it and forget it. If you need a second dose, bring in a second raid. With those large trench complexes it would seem to be a weapon without defense. Vietnam certainly demonstrated napalm could be effectively delivered in bomb form though I question whether it was available in large enough quantities to cause grief to miles and miles of trench lines. You don't have to do miles and miles. Pick one juncture with a command post nearby and hit it for two or three days. You will find Swedish or Netherlands diplomats making telephone calls in Paris and London asking if there isn't some way we could reach a mutual understanding. |
#47
"Charles Talleyrand" wrote in message ...
Lets suppose you get to give a single new airplane design and a single prototype to a participant of World War One. You can offer the Austro-Hungarians the design for a B-52 if you wish. However, that might prove a manufacturing challenge to them (and one can only wonder about their supply of jet fuel). Your goal is to change history. You can hope for a German victory or just that the Allies win faster. It's up to you. So, what design do you offer, remembering that this design must be manufactured, fueled, and armed by the natives? Any such aircraft could, I suggest, have a decisive effect in only two circumstances. One would be if the technology behind it were so difficult for the other participants to knock off that it became and remained dominant for long enough to provide air supremacy. This assumes that air supremacy would have been decisively useful, and I'm not sure it would have been with anything built in 1914-18 (and given that you've used your trump card to achieve the supremacy in the first place). Getting the supremacy sounds like a job for a fighter, eg the Fokker E-I in 1915. Using it decisively sounds like one for a bomber, and if I think about bombers that have had a decisive effect on surface campaigns, I struggle to think of any that did not rely on other factors. Eg the Stuka was arguably a decisive weapon but only if you had the Bf109 to clear its path, and I doubt if you could have built one in 1914-8 anyway. The other circumstance in which the aircraft would be useful is if its availability enabled an attack, or the threat of an attack, that would severely discourage further participation in the war by the attackee. In this context, it seems to me that the best candidate would be an effective long-range torpedo bomber. A version of the Handley-Page 0/400 deployed in Malta, say 24 strong, might have been able to sink Goeben before she escaped to Constantinople in 1914. This in turn might make it more difficult for Germany to get Turkey into the war on her side, thus removing the need for the Triple Entente to fight on an additional front. From the German perspective, a wing of Zeppelin-Staakens deployed in 1914 within range of Scapa Flow might have presented enough of a threat to the Grand Fleet that it would be reluctant to occupy that anchorage. The threat of U-boat attack drove the Grand Fleet back to the west coast of Scotland, so this does not seem improbable. If the threat of severe dreadnought loss was sufficient, it might deter Britain from joining in in the first place, or at least until a countermeasure had been evolved. This would of course have offered Germany a window in which to secure the early defeat of France. This would, though, require a port attack. I doubt whether such a squadron could have executed an effective attack on a fleet at sea. PoW and Repulse were despatched by 50 torpedo bombers carrying larger and more effective torpedoes than Germany possessed in 1914. They were also about 6 times faster than the ships they were attacking. A 1914 60-knot Gotha might have trouble threatening a division of WW1 battlecruisers doing half their own speed. You'd also need a lot of them because if took 50 WW2 era bombers to sink one WW1 BC and one WW2 BB, you'd need still more to offset the fact of fewer less potent hits distributed among many more targets. |
#48
#49
#50
FS: 1988 "Aces High" (Military Airplanes) Hardcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | August 23rd 04 05:18 AM |
Ever heard of Nearly-New Airplanes, Inc.? | The Rainmaker | Aviation Marketplace | 1 | June 23rd 04 05:08 PM |
SMALLL airplanes.. | BllFs6 | Home Built | 12 | May 8th 04 12:48 PM |
FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set | J.R. Sinclair | Aviation Marketplace | 0 | April 12th 04 05:57 AM |
Sport Pilot Airplanes - Homebuilt? | Rich S. | Home Built | 8 | August 10th 03 11:41 PM |
