SAFE Winch Launching
Old July 12th 09, 10:45 PM posted to rec.aviation.soaring
David Chapman
Default SAFE Winch Launching
I mis typed, ..
the winch is relevant to a good launch, but the pilot is responsible for
the safety,
At 21:30 12 July 2009, David Chapman wrote:
I would love to fly a tension controlled winch we were launhing today
in
to strong head winds increasing rapidly part way up the launch. I can
imagine it is better, but I am not an expert.
Winch safety is mostly in the hands of the pilot, the winch is not
relevant to a good launch, but the trained pilot must be able to react
to
any scenario.
But other nonsense posted here . please help me, ...
A standard car auto gearbox has some magic power to automatically adjust
the torque to the car wheels on reaching a hill, without changing gear,
road speed or engine setting? What magic is that?
David.
At 18:45 12 July 2009, Andreas Maurer wrote:
On Sun, 12 Jul 2009 12:45:08 +0200, Marian Aldenhövel
... yet thousands of clubs in Europe with much, much more winch
experience than any club in the US don't see the need for such a
system.
Some do.
Indceed some do - but very, very few.
If there really was an urgent need we'd have more than a couple of
such winches in Europe by now, don't you agree?
When I was trained as a winch driver I was taught to judge cable
tension
and use that as the input parameter to the control loop. The only way
of
doing that without special sensors is to look at the cable sag. Works
during the main portion of the launch, but is not very accurate of
course.
But sufficiently accurate, isn't it?
Contrary to the believe of some people here it doesn't matter if the
speed during the winch launch is 5 kts faster or slower (although the
perfect speed certainly increases launch height).
I think if the winch, or winch driver, has the means to control
tension
and the pilot controls airspeed winch launches become more efficient
and
even safer. Reports suggest that, I have no experience of my own.
Efficiency? Definitely.
Safety? I doubt it.
I havent't been able to find even one accident report that was caused
by inappropriate power setting by the winch driver, yet there are
comparably many accidents caused by rope breaks or complete power
losses of the winch - things that cannot be prevented by tension
controlled speed.
Also you would propably get much more consistent launch performance
across different conditions and much more important, different
drivers.
Indeed. Nice to have.
Today we get launches like being shot from a carrier deck and the
lumbering wingrunner-testing type all in the same day depending on who
is manning the winch. The first launches of the day, or after a driver
swap, or when conditions change would no longer need to be different
than those by a well-adapted driver.
Typical problem of winch driver training. Once we started to re-train
our winch drivers who had problem scontroling the speed, we got rid of
this problem.
Viele Grüße
Andreas
  #42
Old July 12th 09, 11:30 PM posted to rec.aviation.soaring
Del C[_2_]
If Skylaunches winches are supposed (by Bill Daniels) to be so bad, how
come I got 55knots on the nail (perfect speed) for every winch launch I
did on a Skylaunch today while instructing in a K13 in quite windy, rough
and gusty conditions? No oscillations, no over or underspeeds, no weak
link breaks and no unwanted gear changes.
Derek Copeland
At 21:45 12 July 2009, David Chapman wrote:
I mis typed, ..
the safety,
in
to
any scenario.
adjust
David.
system.
Some do.
tension
of
course.
tension
and
Safety? I doubt it.
controlled speed.
drivers.
who
driver
this problem.
Viele Grüße
Andreas
  #43
Old July 12th 09, 11:45 PM posted to rec.aviation.soaring
bildan
On Jul 12, 3:30*pm, David Chapman
But other nonsense posted here . please help me, *...
That 'magic' is called a torque converter which begins to slip and
multiply torque under increasing load. Stock units can double torque
to the wheels.
Modern transmissions use a torque converter locking clutch allowing an
even greater torque multipication factor after the clutch disengages
under load. The effect can be 4:1 or greater.
For basic info, see: http://en.wikipedia.org/wiki/Torque_converter
In addition, automobile engine torque curves have peak torque lower
than cruise RPM. As the vehicle encounters a load such as a hill, the
torque output actually increases as the RPM is pulled down by the
increasing load. The typical V8 used in glider winches has a torque
peak at about 1800 RPM.
The engine/transmission combination acts in exact opposition to what
is needed in a glider winch.
  #44
Old July 12th 09, 11:53 PM posted to rec.aviation.soaring
bildan
come I got 55knots on the nail (perfect speed) *for every winch launch I
Derek Copeland
I mis typed, *.. *
the safety,
in
to strong head winds increasing rapidly part way up the launch. *I can
to
any scenario.
adjust
David.
system.
Some do.
tension
of
course.
tension
and
Safety? I doubt it.
controlled speed.
drivers.
who
driver
this problem.
Viele Grüße
Andreas
Because you operate at low throttle settings and you have no clue what
turbulent air is. Try flying in the desert sometime.
  #45
Old July 13th 09, 12:01 AM posted to rec.aviation.soaring
bildan
system.
Some do.
When I was trained as a winch driver I was taught to judge cable tension
and use that as the input parameter to the control loop. The only way of
during the main portion of the launch, but is not very accurate of course.
I think if the winch, or winch driver, has the means to control tension
and the pilot controls airspeed winch launches become more efficient and
Safety? I doubt it.
controlled speed.
across different conditions and much more important, different drivers.
this problem.
Viele Grüße
Andreas
By those standards, starting cars with hand cranks was 'adequate' and
electric starters would be 'nice to have'.
In fact, tension control is relatively new technology based on vastly
increased knowledge of winch launch dynamics. It certainly has the
potential to increase safety in those cases where unexpected weather
or a human winch operator creates unexpected conditions.
  #46
Old July 13th 09, 01:30 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
In fact it has the potential to be the most dangerous suggestion ever
encountered in glider winching.
Why is it that for years winches have been developed and used in the UK
and Europe with no real problems and all of a sudden someone comes up
with probably the most moronic suggestion ever and that is that if the
tension on the cable is increased the winch slows down to compensate.
So I leave the ground and the glider starts to rotate to the climb,
increasing the tension on the cable so it slows down. Brilliant, it takes
a real towering intellect to think that one through. I suppose the
explanation will be that there is some clever electronic gizzmo to
compensate. The problem with high technology systems is they do not tend
to be robust and they require regular maintainace to ensure their correct
operation, (MVG Winch is a perfect example, most of the advanced features
don't work) whereas a well trained winch driver can do the necessary
compensation using good old fashioned judgement far more safely.
I would far rather place my trust in a basic winch with a well trained
driver that rely on dubious untried engineering solutions driven by the
unknowing.
Skylaunch, Tost, Supercat and MVG winches perform very well with very few
problems. Skylaunch, or Skylaunch re-engined winches are probably now the
most popular winch in use in the UK. We like them and the many years of
experience that has gone into them.
PS We do not have deserts in the UK, and we don't cancel comps just
because 2 or 3 people don't get away either.
  #47
Old July 13th 09, 02:07 AM posted to rec.aviation.soaring
bildan
increased knowledge of winch launch dynamics. *It certainly has the
and Europe with no real problems and all of a sudden someone *comes up
unknowing.
Don, you have so utterly misunderstood the concept, it's difficult to
start a reply.
A tension controlled winch maintains tension, the pilot controls
speed. He does that in exactly the same way as in free flight - nose
up to slow, nose down to speed up. No matter what he does, the
tension remains at the same high percentage of the weak link
strength. The pilot cannot change the tension, only the speed. The
tension cannot exceed the weak link strength.
It's exactly like an airplane. Rope tension is the equivalent of
thrust. The winch provides the power and the pilot flies the glider.
The beauty is that no mater the turbulence wind layers or thermals,
airspeed remains under the pilots total control.
With an airplane on takeoff, even a powerful one, if you raise the
nose, the airspeed will decrease. If you lower the nose, the airspeed
will increase. It's how it works - hundreds of thousands of times a
day. A tension controlled winch does exactly the same thing.
Airplane pilots understand the concept instantly.
  #48
Old July 13th 09, 08:15 AM posted to rec.aviation.soaring
Derek Copeland[_2_]
David.
Bill Daniels has some very strange ideas as to how an automatic gearbox
works! As far as I am concerned, it is a device to allow a motor vehicle
to move off from rest, to smoothly change gears, and to stop without
stalling the engine, without a driver operated mechanical clutch. It is
not cruise control!
In that changing gear with a mechanical gearbox and clutch would give
dangerous short term losses of power, an automatic gearbox is an essential
component for any winch or towcar.
Derek Copeland
  #49
Old July 13th 09, 09:45 AM posted to rec.aviation.soaring
Dave Martin[_3_]
Bill
The arguments are now in an endless repetative cycle fired by the theories
you propose and the convenient practicalities of the European systems, also
used by older US winches - still in use today.
There is only one solution the challenge is there -- get the winch built
with the new technology and at a competetive price and put it on the
market.
Like new glider technology if it works people will use it.
Sadly much as we would like to do it we cannot change overnight.
Look how long it has taken to get the EB28 technology into a practical
aircraft --- but at what cost and how many of us can actually afford it?
Dave
adjust
David.
not cruise control!
essential
Derek Copeland
  #50
Old July 13th 09, 01:30 PM posted to rec.aviation.soaring
Del C[_2_]
Unless Bill has invented a perpetual motion machine, you can't get more
power out of a mechanical device (such as an automatic gearbox) than you
put in. You can gear that power down to get more torque, but the Skylaunch
winch depends on supplying the right amount of power (related to throttle
setting) for the given glider type and headwind component. The automatic
gearbox is only useful to provide some extra torque at low revs to get the
glider moving at the start of the ground run without stalling the engine.
Derek Copeland
At 22:45 12 July 2009, bildan wrote:
On Jul 12, 3:30=A0pm, David Chapman
But other nonsense posted here . please help me, =A0...
adjust
gear,
to the wheels.
Winch Launching in US john hawkins Soaring 11 June 10th 09 12:18 PM
Winch Launching Rolf Soaring 27 January 7th 09 02:48 AM
Ka8b winch launching Jimmie L. Coulthard Soaring 11 September 9th 08 08:38 AM
Aerotow Fuel Costs & Winch Launching Derek Copeland[_2_] Soaring 2 May 26th 08 03:14 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
