On Mon, 27 Jul 2009 07:05:39 -0700 (PDT), D Ramapriya wrote:
On Jul 27, 4:47*pm, "vaughn" wrote: One day I had pulled a glider out to the flight line and completed my pre-flight, only to find that the tow pilot was taking a bathroom break. Just to kill time, I wandered over to the tow plane and gave it a casual once-over. *To my shock, I discovered that one of the struts on the horizontal stabilizer was broken loose from its fuselage attachment. *That plane's next flight might have been its last! This one made my day, Vaughan (or is it spelt Vaugn?) Troll fake modesty. You can clearly see his name above. Franklin |
D Ramapriya schreef:
Has any of you has ever discovered something during the pre-flight inspection that necessitated a significant deferrment of your flight plan or a cancelation altogether? Just curious, that's all. -) two springs missing that should have held exhaust pipes together. instructor judged we could fly, though -) fatigue cracks in a bracket that hold the oil cooler. instructor judged we could fly, though -) oil cooler still partially covered for the winter cold on a sunny day in May. instructor judged we could fly, though So no, I never was significantly delayed in my 40 or so hours of tuition, but problems do show up. KA |
jan olieslagers wrote:
-) two springs missing that should have held exhaust pipes together. instructor judged we could fly, though -) fatigue cracks in a bracket that hold the oil cooler. instructor judged we could fly, though -) oil cooler still partially covered for the winter cold on a sunny day in May. instructor judged we could fly, though So no, I never was significantly delayed in my 40 or so hours of tuition, but problems do show up. KA The press-on instructor approach you mentioned reminded me of student touch and goes long ago. After landing, I tried to switch the flaps to up - but they wouldn't move. I was about to pull the throttle - but the CHIEF instructor said, let's press on. He tried the fuse - no go - and up we went - at about 150 FPM.... Brian W |
A few examples of what I've seen so far:
-) two springs missing that should have held exhaust pipes together. instructor judged we could fly, though -) fatigue cracks in a bracket that hold the oil cooler. instructor judged we could fly, though -) oil cooler still partially covered for the winter cold on a sunny day in May. instructor judged we could fly, though Badly frayed cable on the horizontal stabilizer. AI caught it while fueling the aircraft. Showed it to the pilot who decided it would make back home, about 30 miles. AI actually begged his pax to stay behind. At about 200' on take off the cable failed. Aircraft did a complete loop impacting the ground at about a 60 degree angle. Nothing left of the aircraft more than knee high. Engine buried about 2'. Pilot died instantly, but the pax with all broken bones, struggled for help for almost 5 minutes before expiring. For a friend here.... he passed on 3 spinner cracks on a rental 172. One crack was 1 1/2 in long. They (others) continued to fly the aircraft for another week before the spinner was removed. All of these point out the old adage that incompetence is unaware of itself. In the first cases, the instructor "judged we could fly." Was the instructor a mechanic, too, or maybe en engineer, to make the determination that broken or missing parts didn't affect the safety of the aircraft? Designers and manufacturers don't typically spend money on stuff that isn't necessary, and as far as cracks go, they don't usually progress in a linear fashion. They can show up, travel slowly, then the part can fail all at once as the metal ahead of the crack reaches its fatigue point from the work-hardening that results when a crack allows too much flexing. A cracked spinner can kill, and has done so in the past. They've been known to come through the windshield. Frayed cables might be ok for a while or might not, as the instance given clearly demonstrates. Would the pilot of that airplane have suspended himself thousands of feet above the earth using a frayed cable? Probably not, be he did what amounted to the same thing. If we're going to just say "it'll be OK," why bother with the preflight in the first place? There are the Five Hazardous Attitudes: Anti-Authority, Resignation, Invulnerability, Macho, and Impulsivity. Under which one does the "it'll be OK" fit? And if the law requires that the airplane be airworthy before flight but we fly it with obvious defects anyway, where does that fit? See this: http://www.pilotoutlook.com/instrume..._and_antidotes I'll get flamed, for sure, but then you guys can place the flamer somewhere in the Hazardous Attitude scale. Dan |
![]() wrote in message ... A few examples of what I've seen so far: -----------examples snipped for brevity---------- All of these point out the old adage that incompetence is unaware of itself. In the first cases, the instructor "judged we could fly." Was the instructor a mechanic, too, or maybe en engineer, to make the determination that broken or missing parts didn't affect the safety of the aircraft? Designers and manufacturers don't typically spend money on stuff that isn't necessary, and as far as cracks go, they don't usually progress in a linear fashion. They can show up, travel slowly, then the part can fail all at once as the metal ahead of the crack reaches its fatigue point from the work-hardening that results when a crack allows too much flexing. A cracked spinner can kill, and has done so in the past. They've been known to come through the windshield. Frayed cables might be ok for a while or might not, as the instance given clearly demonstrates. Would the pilot of that airplane have suspended himself thousands of feet above the earth using a frayed cable? Probably not, be he did what amounted to the same thing. -----------more snipped---------- Dan Back when there was a coffee shop, that had become a major hang-out for both pilots and mechanics at my local airport, I once deferred a question to a flight instructor who I knew to also be a certified A&E. The questioned was a student pilot and I knew the correct answer; but really thought that it should come from someone properly certified--and was utterly astounded by the avalanche of poppycock that issued forth. I was so doumfounded that I still can not recall the original question--half a dozen years later. So, while I completely agree with your basic premise, I must also suggest that any trust the general knowledge and good sense of a mechanic or engineer should be evaluated as part of the decision whether to accept his opinion or the products of his work! I do know several mechanics who are darned good engineers, even though the don't have engineering degrees, and also a couple of automotive mechanics whose opinions I would gladly trust with regard to aircraft; but they are not all created equal. Peter |
![]() "D Ramapriya" wrote in message ... Has any of you has ever discovered something during the pre-flight inspection that necessitated a significant deferrment of your flight plan or a cancelation altogether? Just curious, that's all. To me personally -- Low oil many times. Birds nests in the engine compartment at least twice. Nav lights out at least twice. Panel lights out at least once. Loose fuel cap on a high wing once. Unacceptable propeller damage on a metal prop once. Most outstanding, years ago during flight training, was all bolts on an outboard flap hinge were backed off about half way. I though the instructor was just setting me up until I saw his response. Worst I have actually witnessed -- Badly frayed cable on the horizontal stabilizer. AI caught it while fueling the aircraft. Showed it to the pilot who decided it would make back home, about 30 miles. AI actually begged his pax to stay behind. At about 200' on take off the cable failed. Aircraft did a complete loop impacting the ground at about a 60 degree angle. Nothing left of the aircraft more than knee high. Engine buried about 2'. Pilot died instantly, but the pax with all broken bones, struggled for help for almost 5 minutes before expiring. There was another story in flying magazine many years ago about someone hired to return a repossessed aircraft from a near by airport. Very cold morning, he just check the oil and sumps. Clearing the end of the runway at about 200 ', he reached for the carb heat. Cabin filled once dormant wasps warmed by the carb heat! Fortunately he had enough presence of mind to quickly open both windows and flooding the cabin with extremely cold air. Made it back to the runway without further incident, but it obviously could have ended much differently. |
On Mon, 27 Jul 2009 14:30:57 -0500, Maxwell wrote:
Badly frayed cable on the horizontal stabilizer. AI caught it while fueling the aircraft. Showed it to the pilot who decided it would make back home, about 30 miles. AI actually begged his pax to stay behind. At about 200' on take off the cable failed. Aircraft did a complete loop impacting the ground at about a 60 degree angle. Nothing left of the aircraft more than knee high. Engine buried about 2'. Pilot died instantly, but the pax with all broken bones, struggled for help for almost 5 minutes before expiring. The guilt you should feel for not stopping both of them. What a cad you are. Franklin |
On Mon, 27 Jul 2009 18:14:03 -0400, Franklin "Franklin
wrote: On Mon, 27 Jul 2009 14:30:57 -0500, Maxwell wrote: Badly frayed cable on the horizontal stabilizer. AI caught it while fueling the aircraft. Showed it to the pilot who decided it would make back home, about 30 miles. AI actually begged his pax to stay behind. At about 200' on take off the cable failed. Aircraft did a complete loop impacting the ground at about a 60 degree angle. Nothing left of the aircraft more than knee high. Engine buried about 2'. Pilot died instantly, but the pax with all broken bones, struggled for help for almost 5 minutes before expiring. The guilt you should feel for not stopping both of them. What a cad you are. Franklin franklin you should be ashamed of yourself. you have no details of the incident other than what maxwell posted so you are not in a position to judge him. you have no idea what condition the cable actually was. if the aircraft was refuelling it made the last flight ok and there is nothing to say that the pilot may have been correct. in this world you are free to make your own choices ...and wear the consequences. when was the last time you flew an aircraft? tragic as it was maxwell isnt to blame. Stealth pilot |
On Tue, 28 Jul 2009 08:50:11 GMT, Stealth Pilot wrote:
On Mon, 27 Jul 2009 18:14:03 -0400, Franklin "Franklin wrote: On Mon, 27 Jul 2009 14:30:57 -0500, Maxwell wrote: Badly frayed cable on the horizontal stabilizer. AI caught it while fueling the aircraft. Showed it to the pilot who decided it would make back home, about 30 miles. AI actually begged his pax to stay behind. At about 200' on take off the cable failed. Aircraft did a complete loop impacting the ground at about a 60 degree angle. Nothing left of the aircraft more than knee high. Engine buried about 2'. Pilot died instantly, but the pax with all broken bones, struggled for help for almost 5 minutes before expiring. The guilt you should feel for not stopping both of them. What a cad you are. Franklin franklin you should be ashamed of yourself. you have no details of the incident other than what maxwell posted so you are not in a position to judge him. you have no idea what condition the cable actually was. if the aircraft was refuelling it made the last flight ok and there is nothing to say that the pilot may have been correct. in this world you are free to make your own choices ...and wear the consequences. when was the last time you flew an aircraft? tragic as it was maxwell isnt to blame. Stealth pilot Stealth pilot, Maxwell's self-admitted failures are easy to read. See, he is not complaining about my pointing out his failures. Why do you? Franklin |
![]() "Franklin " "Franklin wrote in message ... Stealth pilot, Maxwell's self-admitted failures are easy to read. See, he is not complaining about my pointing out his failures. Why do you? Franklin No, I didn't feel the need to comment because you're obviously a dumb ass. |
annual inspections | [email protected] | Soaring | 1 | October 20th 07 01:08 AM |
100 Hour Inspections | Judah | Piloting | 26 | December 1st 06 02:30 PM |
Homebuilt Inspections | john smith | Home Built | 8 | December 25th 04 02:20 PM |
Time Measurement for Inspections | O. Sami Saydjari | Owning | 15 | April 7th 04 05:26 AM |
Pre-buy inspections | Paul Folbrecht | Owning | 12 | March 1st 04 12:27 AM |
