Blue Angels F-18A Hornet on E-Bay
Old February 14th 04, 10:13 PM
Mr Smith
Thank you for the responses. It appears as if the aircraft
in question, is nowhere near flight worthy at this time.
Just curious though,
What's a typical Vref speed for landing ? (presuming all
ordnance has been expended). And are these numbers something
the pilot calculates himself, or is it given to him ?
Can ACLS be considered helpful at all ? (similar to perhaps
a Category III ILS auto land ?) Does any Hornet driver here
actually trust it ? (and why would you even use it?).
What is the crosswind technique alluded to below ? (in lieu
of the forward sideslip)?
"Doug "Woody" and Erin Beal" wrote in message
There are a couple of "gotchas" in just flying the thing, but nothing a
few
flights wouldn't iron out.
If you've never experienced flight gear, that would be a new treat
(helmet,
mask, torso harness, g-suit).
Since the motors are way in the back (35 or so feet behind you), you'd
have
to get used to the "detached" sensation of flying the jet. There is no
air
noise or airframe feedback with regard to airspeed or engine power setting
whatsoever. The airplane feels the same flying at 180 kts at 30000 feet
as
it does at 550 kts at 500 feet. A good instrument scan is a must.
WRT landings, the HUD makes them pretty easy. On this Lot 6, you may find
single chamber struts which means CV type landing is probably not a good
idea (max trap for single chamber struts was 30,500 lbs vice the 33k UNR
or
34K Restricted for the current F/A-18). Pretty simple stuff to flare a
landing in the Hornet though. I have taken guests into the simulator, and
the ones with some flight time do fairly well at getting it on the runway.
The biggest landing obstacle would be encouraging you NOT using a forward
slip as a crosswind correction--makes the airplane do the funky chicken on
the runway. OBTW, no localizer, ILS, VOR. Either fly TACAN approaches or
PAR in the weather (if you want a precision approach).
--Woody
  #52
Old February 15th 04, 12:15 PM
Doug \Woody\ and Erin Beal
On 2/14/04 4:13 PM, in article , "Mr Smith"
Roughly 125 knots.
Nope. Lots of black boxes fighting to be sync-ed up with the ones on the
carrier. Not many NAS's have the SPN-46/48 (whatever) that is required to
conduct ACLS approaches at the field either. As I remember, Lemoore,
Oceana, and Whidbey have them... Not sure about the rest.
Crab to land and kick out half the crab prior to touch down.
--Woody
few
(helmet,
have
air
as
or
--Woody
  #53
Old February 15th 04, 03:09 PM
Pechs1
Mr Smith- What's a typical Vref speed for landing ? (presuming all
the pilot calculates himself, or is it given to him ? BRBR
You check airspeed for landing vs the AOA but you use 'onspeed AOA', where
airspeed varies with weight, for landings, always the same AOA..15 units for
the F-4.
smith Can ACLS be considered helpful at all ? (similar to perhaps
actually trust it ? (and why would you even use it?). BRBR
In the F-4 and Turkey, I have had Mode 1s to touchdown( I know a contradiction,
Mode 1s are always to touchdown) but they were an emergency procedure. I doubt
any modern aviator relies on this system.
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer
  #54
Old February 15th 04, 03:35 PM
Elmshoot
contradiction,Mode 1s are always to touchdown) but they were an emergency
procedure. I doubtany modern aviator relies on this system
I could never get auto throttles to work right in the A-6 in the Prowler they
were a little better. I tried to do a coupled approach on Sara (90-91) and
ended up with a bolter. The Hornets were doing them all the time they seemed to
have the system and ship tweeked up really well. I think it was mandentory for
the first Hornet down the chute to attempt a Mode 1 as I recall they flew a lot
of them maybe 25% were hooked up.
Sparky
  #55
Old February 15th 04, 08:12 PM
Yofuri
I know A6 power control was problematic from development through fleet
introduction in 1969. The feedback loop with the ASN-54 APC was
inconsistent, and the kinesthetics were unacceptable to the pilot when the
system introduced purposeful glide slope deviations for self-check
monitoring purposes.
The RANGER/CVW-2 deployment in 1969 was the first in which all aircraft
aboard, including the C1A COD and the SH-3's were ACLS-equipped. Mode 1 was
not authorized at that time for any aircraft. The idea was to "get 'em home
safely on a dark and stormy night".
Do Hornets have yaw strings glued to the radome like F-4's did?
Rick
"Elmshoot" wrote in message
they
seemed to
for
a lot
Sparky
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
  #56
Old February 15th 04, 09:11 PM
John R Weiss
"Elmshoot" wrote...
to
lot
I had a total of 4 successful Mode 1 approaches in my career -- 2 each to Kitty
Hawk and Nimitz.
"It's always something; if it's not one thing, it's another..." (Roseanne
Rosannadanna)
Autothrottle excursions, Beacon failure, and autopilot excursions were the 3
predominant failure modes...
  #57
Old February 15th 04, 11:21 PM
John Carrier
Four more than I. While the Turkey had an excellent APCS, I was never
exposed to the "certified" ACLS model. As for the Phantom, got just past
tipover once ... then all hell broke loose.
The F-8 was worthy of a chuckle. The J's were retrofitted with bullseye
needles. To display CL and GS one had to flip a switch from "TACAN" to
"ACLS" ... it reconfigured the ID-249 for the approach. A really good
thing, but hardly ACLS.
R / John
  #58
Old February 16th 04, 03:57 AM
Mike Kanze
Rick,
This was still the case when the Lizards (VA-95) went to sea in 1973 aboard
CORAL MARU. We never flew any "coupled" passes closer in than 1/4 mile.
Mike Kanze
"Asking what a pilot thinks about the FAA is like asking a fireplug what it
thinks about dogs."
- from Bill "Windmill" Young
"Yofuri" wrote in message
was
home
Rick
emergency
they
and
seemed to
mandentory
for
flew
a lot
Sparky
  #59
Old February 16th 04, 02:46 PM
Pechs1
Spn-43(needles) and autothrottles, the way to go in VF-31, last cruise...a
'peek' is worth a thousand 'scans' tho...
Forrestal started asking people to try Mode 1s..Sometimes worked, sometimes an
automatic trip into the penalty box...
P. C. Chisholm
CDR, USN(ret.)
  #60
Old February 17th 04, 02:23 PM
Pechs1
dano- It seems to me that the A-4 might actually be a good candidate for
private ownership. It's relatively small and simple, mostly electrical,
electromechanical and hydraulic I assume (not of the complexity of the
60s, 70s, 80s), single engine BRBR
I think the only 'gotchas' would be slat rigging, which is certainly an art in
itself. A poorly rigged slat could spell disaster.
The other is the ejection seat in the 'E' model, which I would not ever sit in.
Bug Roach's seat failed in the 'E' he was flying, the rocket motor failed and
he hit the tail as he went out. A static test of 10 rocket motors in storage
had 7 failures. I grounded my 'E' models and refused to fly them after that.
Just wrapped them up, took them outta reporting and looked for ways to get them
to D-M.
P. C. Chisholm
CDR, USN(ret.)
Blue Angels Show ramrod48 Military Aviation 6 September 7th 04 10:01 PM
Blue Angels star in air show Otis Willie Military Aviation 9 May 25th 04 05:41 PM
Once again-Threshold, The Blue Angels Experience Pechs1 Naval Aviation 28 February 8th 04 12:22 AM
Blue Angels Video - Is it a Fake? Ken Morano Military Aviation 4 November 18th 03 10:14 PM
Blue Angel's Gear Door Broken? Clay N4AOX Military Aviation 15 October 6th 03 08:01 AM
