Tire inflation pressure
Old November 7th 03, 03:51 AM
Paul Lee
Default Tire inflation pressure
What is the proper pressure to use with 5.00-5 mains and 10x3.50-4 nose
for a 2250 gross canard plane?
Another related question: both mains tend to loose air slowly - would
be flat after about 3 months sitting. Is this typical or should I get
new tubes?
Paul Lee, SQ2000 canard project: www.abri.com/sq2000
Old November 7th 03, 04:35 AM
Del Rawlins
On 06 Nov 2003 06:51 PM, Paul Lee posted the following:
nose for a 2250 gross canard plane?
new tubes?
Try new valve cores.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old November 7th 03, 06:07 AM
REEI2002
Try Nitrogen instead of air, aviation type rubber tubes leak molecular air.
Nitrogen molecules are larger.
Old November 7th 03, 06:27 AM
Del Rawlins
On 06 Nov 2003 09:07 PM, REEI2002 posted the following:
air. Nitrogen molecules are larger.
Atmospheric air is mostly nitrogen.
Del Rawlins-
Old November 7th 03, 07:05 AM
John E. Carty
"REEI2002" wrote in message
air.
Considering air is 77% Nitrogen, how much difference does this really make
when it comes to seepage of this kind? :-)
Old November 7th 03, 07:19 AM
On Fri, 07 Nov 2003 07:05:24 GMT, "John E. Carty"
:"REEI2002" wrote in message
: Try Nitrogen instead of air, aviation type rubber tubes leak molecular
:air.
: Nitrogen molecules are larger.
:Considering air is 77% Nitrogen, how much difference does this really make
:when it comes to seepage of this kind? :-)
And almost all the rest - Oxygen (21%, atomic weight 32) and Argon
(.94%, atomic weight 40) and Carbon Dioxide (.03%, atomic weight 38)
have larger molecules than Nitrogen (atomic weight, 28)
Old November 7th 03, 01:56 PM
Ron Natalie
"John E. Carty" wrote in message ...
air.
And Oxygen, the next largest component (almost 21%) is even larger. Then
you get down to Argon at 1% (which is bigger yet).
Unless you were previously filling your tires with helium, there isn't much to be gained
on diffusion by this change.
Old November 7th 03, 03:15 PM
Eric Miller
much to be gained
But using helium filled tires ensures squeaky landings!
I suppose you can use grease filled tires too, but it's a lot heavier and
not good for the rubber.
=D
Eric
Old November 7th 03, 02:38 PM
Paul Lee
Yeah... By now after two years, most oxygen molecules should
have leaked out and should have 99% nitro.
"John E. Carty" wrote in message .. .
air.
Old November 7th 03, 11:19 AM
B. B.
new tubes?
Del Rawlins-
Wish I could go as long as 3 months.
I've been informed that AIRCRAFT tubes
are manufactured from GENUINE RUBBER.....
and are porous by their very nature.
I've also been told Michelin tubes leak the least.
Dunno, but wouldn't bet the farm on this rumor.
They_ARE_ expensive.
Try the valve cores, but chances of BOTH
being the cause of you problem is slim to none.
If it doesn't help, at least it's a cheap education.
Barnyard BOb --
Over 50 years of successful flight...
Eat your heart out, BEN HASS. ---
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 03:46 AM
Nosewheel Shimmy and Scalloped Tire Redux, Plus Larry Smith Home Built 2 September 15th 03 04:03 PM
Scalloped Nosewheel Tire Larry Smith Home Built 7 September 12th 03 09:16 PM
Fuel pressure Problems smf Home Built 3 September 7th 03 08:25 PM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 05:18 AM
