Stupid hp to thrust question
Old December 5th 03, 01:24 AM
Mark
Default Stupid hp to thrust question
Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a
prop spinning 2300 rpm on a 100 hp motor ?
Old December 5th 03, 01:49 AM
RR Urban
Theoretically speaking -
If the props are identical....
so is the thrust on the test stand.
Barnyard BOb --
If I'm wrong, never mind.
Old December 5th 03, 01:51 AM
Stu Fields
Assuming both engines are producing the same torque at that rpm, then yes.
Torque x RPM = horsepower. Note: the props will not be both the same
diameter and pitch.
Stu Fields
"RR Urban" wrote in message
a
Barnyard BOb --
Old December 8th 03, 05:10 PM
nafod40
To paraphrase the question...
If I put 150 lbs of crap in a 100 lb bag, and 150 lbs of crap in a 150
lb bag, which bag is holding more crap?
Old December 8th 03, 07:32 PM
Russell Kent
OOooooooo..... *SO* close, and yet just off. I think you meant to say:
"If I put 100 lbs of crap in a 100 lb bag, and 100 lbs of crap in a 150 lb bag,
which bag holds more crap?"
Russell Kent
Old December 8th 03, 08:29 PM
Rich S.
"Russell Kent" wrote in message
bag,
That's an easy one - A 150 lb (capacity) bag holds more crap than a 100 lb
(capacity) bag.
I think YOU meant to say, "If I put 100 lbs of crap in a 100 lb bag, and 100
lbs of crap in a 150 lb bag, Which bag contains more crap?"
Rich "150 lbs of crap in a 100 lb bag is known as a 'Blivet'". S.
Old December 8th 03, 09:25 PM
Russell Kent
bag,
(capacity) bag.
Not so fast. If my eyes aren't deceiving me, the only change you made was
"contains" for "holds". English being an exceptionally slippery language, it
seems to me that those terms are synonymous. Makes it rather hard to give a
definitive answer to the original poster's question if we aren't clear on
whether "hold/contains" means "at the moment" or "at maximum capacity", which I
believe is the issue that nafod40 was attempting to illustrate with his
posting. I was only trying to show that nafod40's choice of numbers weren't
quite parallel to the original poster's question.
BTW, there's entirely too much crap in here. :-)
ob. aviation content: My Dad used to drop blivets from the B-52 he flew. :-)
Russell Kent
Old December 9th 03, 01:39 PM
nafod40
My language was carefully chosen with the utmost attention to detail. To
paraphrase Humpty-Dumpty...
"When I use a phrase," Humpty Dumpty said, in rather a scornful tone,
"it means just what I choose it to mean—neither more nor less."
"The question is, " said Alice, "whether you can make words mean so many
different things."
"The question is," said Humpty Dumpty. "which is to be master—that's all."
Old December 8th 03, 08:56 PM
RobertR237
In article , nafod40
writes:
Damn BOb, you sure are full of CRAP! ;-)))))
Bob Reed
www.kisbuild.r-a-reed-assoc.com (KIS Builders Site)
KIS Cruiser in progress...Slow but steady progress....
"Ladies and Gentlemen, take my advice,
pull down your pants and Slide on the Ice!"
(M.A.S.H. Sidney Freedman)
Old December 8th 03, 09:28 PM
Russell Kent
I'm sure NO ONE here, not even the crotchety old fool himself, will deny that BOb
is full of crap (sometimes), *BUT* it was nafod40 whom you (Bob Reed) quoted and
not BOb.
Russell Kent
Stupid super cub question Robert Loer Home Built 9 November 22nd 03 05:28 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
question about EZRocket David O Home Built 6 October 1st 03 06:03 PM
Question on Pulsejets/Ramjets??? DarylG1532 Home Built 3 August 16th 03 03:20 AM
Question - Regarding Canard Pushers... Tilt Home Built 33 August 10th 03 11:07 AM
