Real stats on engine failures?
Old November 25th 03, 08:49 PM
Ron Natalie
"Peter Duniho" wrote in message ...
But if you look at the same
question over 2000 hours of operation or one or two decades, I suspect that
lack of maintenance will show up as much more of an issue. The lack of oil
changes alone are likely to be a major problem, never mind the myriad of
fixable problems that would normally be detected during routine maintenance.
Lack of use is the big killer. People base a lot of things on how many hours
in service an engine has, but they accumulate problems while sitting as well.
Old November 26th 03, 01:37 AM
Peter Duniho
hours
well.
Which is why I stipulated both an "hours of operation" and a "calendar time"
measure. Either one is significant, you are correct.
I don't particularly enjoy flying with an engine that's just had some major
work, but I'd sure take that over flying with an engine that's NEVER had ANY
work. And an engine that's gotten a few hours under its belt after
maintenance looks better every flight.
Pete
Old November 26th 03, 02:25 AM
Mike Rapoport
I guess I don't agree. My experience is that maitenance creates many
problems. I agree that the engine will last longer if you change the oil
more frequently but changing the oil doesn't prevent failures. Routine
maitenance doesn't detect impending connecting rod failures, turbo bearing
about the sieze ect. I have seen and heard of too many oil leaks, fuel
leaks, rubbing tubes and various parts coming loose or falling off...all
caused by "maitenance".
MU-2
hlink.net...
You are probably more likely to have an engine failure from maitenance
than
from lack of maitenance.
Cute. But not really all that true, IMHO.
It depends on over how long a period of time you're talking about. If you
mean the instant after some maintenance is done, well sure...it's true
(but
obviously so, and not interestingly so). But if you look at the same
that
oil
maintenance.
Pete
Old November 26th 03, 04:10 AM
Peter Duniho
link.net...
[...] I have seen and heard of too many oil leaks, fuel
Well, granted, the engines on your plane require a much more specialized
maintenance crew than the one Lycoming on mine. But in spite of the very
real possibility of human error during maintenance, as far as I know more
engine failures are prevented by maintenance than are caused by it. I would
be very surprised if you could find statistics to the contrary.
Pete
Old November 25th 03, 06:32 PM
Ash Wyllie
Captain Wubba opined on engine failures snipped
One partial, a bad mag, on a twin in 1400 hours.
-ash
for assistance dial MYCROFTXXX
Old November 25th 03, 10:30 PM
Gene Seibel
2500 hours. No failures where there was fuel in the tanks.
Gene Seibel
Hangar 131 - http://pad39a.com/gene/plane.html
Because I fly, I envy no one.
Old November 26th 03, 03:47 AM
Tom S.
"Tom S." wrote in message news:...
link.net...
http://www.ntsb.gov/NTSB/brief.asp?e...12X20796&key=1
In sum...
"The National Transportation Safety Board determines the probable cause(s)
of this incident as follows:
The failure of a number one cylinder connecting rod bolt due to
under-torquing during engine major overhaul. "
Old November 26th 03, 06:32 PM
Tobias Schnell
750 hrs here (OK, 250 of them in gliders). One impending failure due
to broken shaft seal on the crankcase. The engine did not show oil
pressure any more, but I made it back to the airport with the engine
still running at near idle. It happened on the climbout, about 3000
AGL.
Tobias
V-8 powered Seabee Corky Scott Home Built 212 October 2nd 04 11:45 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
Engine... Overhaul? / Replace? advice please text news Owning 11 February 17th 04 04:44 PM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
