#52
On Tue, 23 Dec 2003 02:33:12 GMT, Orval Fairbairn
wrote: In article , Mainlander *@*.* wrote: In article .net, says... Col wrote: On Sun, 21 Dec 2003 20:14:58 GMT, Jerry Springer wrote: Mainlander wrote: In article , says... "Cub Driver" wrote in message m... It's getting awfully crowded down there (or up there, in terms of latitude). No wonder the folks at McMurdo were so unfriendly to the Kiwi who dropped in without enough fuel to reach his destination. Yes, on the other hand they are there as the guests of the taxpayers, and shouldn't be treating Antartica as their own personal fiefdom. Why didn't the Australian government spring to his rescue? By the way they are accountable to taxpayers and shouldn't have to spend thousands of dollars shipping in fuel (he refused to pay for the fuel he was eventually offered) Please show where he refused to pay for fuel?????? It was widely reported Pignut . One other thing why don't you go to this site, read all of the links then come back and tell us where he refused top buy fuel???? I await your answer. http://www.southpolestation.com/news/rv4/rv4.html And that article further reinforces Johansen's stupidity. Quote "Jon filed a flight plan for his trip just before departing, but he kept his South Pole plans secret until the end, knowing that they would not be approved. He claims to have done his homework on Antarctic flying and weather conditions. However, his tires are too small for the ice runway...since he didn't have the oversized low-ground-pressure balloon tires such as used by the Twin Otters, the wheels sank into the snow and he had to get assistance in getting towed off of the active airstrip. And depending on the actual weather conditions, there were several other hard-surface runways he could have diverted to---Patriot Hills, Novo, Rothera, or even Marsh...at any of these he might have had an easier time getting refueled." And the article also states that the NSF people refused him access to meteorological data. Does that sound like a responsible government agency? Again, the NSF et al are not there for general business purposes. Are you aware that the NSF also uses pers from Ice Recon in MD as part of their operation? I doubt whether it would have really understood their charts. Afterall, he wasn't the brightest bulb on the christmas tree was he. Cath |
#53
#54
On Tue, 23 Dec 2003 16:51:25 +0930, David Pears
wrote: On Mon, 22 Dec 2003 23:15:49 GMT, (Bruce Hamilton) wrote: I hope this post doesn't sound impolite or abusive to you, as you obviously wanted to add some data, but the storage constraints on Avgas mean it has to be regularly retested before it can be accepted as fuel for aircraft. Avgas is usually more stable than Mogas, but it still has to be within a current test period. I though gas turbines (as used in aircraft engines) would run on just about any old liquid, as long as it has a hint of hydrocarbon in it? Yes and no, as Air New Zealand discovered. Many gas turbines have other components like fuel pumps that turn out to be quite sensitive to the lubricating properties of the fuel. The lubrication properties of Avgas/Mogas are near nil. Jet A is actually pretty slippery stuff. So while you can burn just about anything in the turbine, you have to make sure that doing so doesn't damage something else... David |
#55
David Pears wrote:
I though gas turbines (as used in aircraft engines) would run on just about any old liquid, as long as it has a hint of hydrocarbon in it? The problem is that turbine fuel ( effectively an aviation kerosine ) has to also satisfy several requirements, both with regard to engine performance and safety. The fundamental ones are flash point ( temperature at which the fuel will give off sufficient vapours to ignite if a flame is applied ) and freezing point ( engines tend to stop when fuel turns to sludge ). Avgas has suitably low freezing point, but the flash point is far lower than the fuel systems on a commercial Jet A1 fuelled airliner are designed to cope with. Military airliners often use a wide cut kerosine with a flash point well below airfield ambients. If a plane is carrying passengers, it's usually running on Jet A1, a narrow cut fuel with a flash point above most airfield ambient temperatures ( 38C ). Flash point is also the easiest method of detecting whether a kerosine has been contaminated by a gasoline. The 1997 explosion of the "empty" centre tank in TWA Flight 800, has reignited interest in fuel flammability issues. Kerosines tend to have more lubricity than gasolines ( higher sulphur and viscosity ) but high pressure hydrotreating and hydrocracking have made fuels "harder" ( less lubricity ), and NZ aviation authorities have convinced other countries to include a lubricity specification in DefStan 91-91 but, AFAIK, it's not yet in the more common ASTM D1655. Note that refractory elements ( silicon, calcium, potassium, vanadium etc ) will erode-deposit on turbine blades, and they are present in higher boiling fractions such as diesel ( which wouldn't pass the freezing point requirement - but is used on ship and power-station gas turbines ). Fuels for gas turbines tend to ensure such elements aren't present, even though falling out of the sky isn't an option, as overhauls are very expensive. There are a whole heap of other criteria for Jet fuels associated with cleanliness, corrosivity, combustion properties, stability and approved additives that mean than commercial aircraft tend to use a well defined narrow cut kerosine fraction. Bruce Hamilton |
#56
![]() "matt weber" wrote in message reply::: I though gas turbines (as used in aircraft engines) would run on just about any old liquid, as long as it has a hint of hydrocarbon in it? Yes and no, as Air New Zealand discovered. Many gas turbines have other components like fuel pumps that turn out to be quite sensitive to the lubricating properties of the fuel. The lubrication properties of Avgas/Mogas are near nil. Jet A is actually pretty slippery stuff. So while you can burn just about anything in the turbine, you have to make sure that doing so doesn't damage something else... David We had Garrett turbines powering 60Hz alternators at the Cooby Creek Tracking Station at Toowoomba in the late 60's and found the FCU's chewing up their internal bearings like crazy until we got an anti-static additive put in the ATK. Electrostatic corrosion. -- JW˛ Norton AntiVirus 2003 installed ************************************ |
#57
Is it so very very hard to admit when one is mistaken?
Bruce wins this one. Yeah, Jerry go ahead and belittle me now. "Jerry Springer" wrote in message nk.net... Jimmy Galvin wrote: Jerry: You have stretched this about as far as possible. Your logic is flawed and you are coming across as just plane silly. Jimmy If you say so Jimmy then it must be true. LOL |
#58
![]() Robert Loer wrote: Is it so very very hard to admit when one is mistaken? Bruce wins this one. Yeah, Jerry go ahead and belittle me now. Is your name Jimmy???? I have not seen you contribute anything to this thread, did I miss your posts somewhere??? I have no problem with Bruce, he believes what he believes and I believe what I believe. We just don't agree. I know Jon and how much planning goes into each of his trips. What do you know Robert other that what you read? It is easy to say what should have, could have been done after it is all over. Should I have said to Bruce that he did not know what he was talking about? NO, that was to strong but I still stand on the armchair quarterback part. At least Bruce was not saying the ridiculous things that were being said here by others like he refused to pay for fuel offered. Once again Robert what is is that I am mistaken about? Jerry "Jerry Springer" wrote in message nk.net... Jimmy Galvin wrote: Jerry: You have stretched this about as far as possible. Your logic is flawed and you are coming across as just plane silly. Jimmy If you say so Jimmy then it must be true. LOL |
#59
![]() "Jerry Springer" wrote in message hlink.net... Robert Loer wrote: Is it so very very hard to admit when one is mistaken? Bruce wins this one. Yeah, Jerry go ahead and belittle me now. Is your name Jimmy???? I have not seen you contribute anything to this thread, did I miss your posts somewhere??? I have no problem with Bruce, he believes what he believes and I believe what I believe. We just don't agree. I know Jon and how much planning goes into each of his trips. What do you know Robert other that what you read? It is easy to say what should have, could have been done after it is all over. Should I have said to Bruce that he did not know what he was talking about? NO, that was to strong but I still stand on the armchair quarterback part. At least Bruce was not saying the ridiculous things that were being said here by others like he refused to pay for fuel offered. Once again Robert what is is that I am mistaken about? Jerry No, his name is Robert. Now Jerry try to follow this. I will explain it step by step. Robert is spelled R, o, b, e, r, t. Jimmy is spelled J, i, m, m, y. Please note that these two names are comprised of 11 letters total. One having 6 letters, the other having 5, and none having been used in both names. I am trying to explain this as logically and clearly as possible. Oops, forgot, you are logically challenged. Well OK how about (sigh) I give up. It is admirable that you are sticking up for your friend but the fact is he screwed up big time and had to depend on others to pull his chestnuts out of the fire. Jimmy |
#60
![]() G.R. Patterson III wrote: Jerry Springer wrote: Is your name Jimmy???? I have not seen you contribute anything to this thread, did I miss your posts somewhere??? Stick it. This is a public forum. You want to communicate privately with Jimmy, use email. Until then, don't bitch if someone else opens up. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." Yes it is a public forum, and isn't wonderful that we each can say and believe what we want? Even you George are welcome to add your "Stick it" comment. :-) That really sheds new light on the subject at hand. I find your tag line interesting. Think about it..... Anyway it is Christmas I am going to celibrate with family. Each of you that think I am so wrong can have the last say on this. Marry Christmas or Happy Holidays, Jerry |
Another C-17 On The Way | John A. Weeks III | Military Aviation | 10 | February 24th 04 05:22 PM |
Grandmother Goes Down at the Pole | BJ | Home Built | 66 | January 13th 04 04:10 PM |
Hotbeef owns the air with his pole vault .... | The Injector | Owning | 0 | December 22nd 03 07:51 PM |
