Hi Guys,
My father and I were returning to Petaluma (O69), called in on the 45 to downwind and were just about to turn downwind when a flight of three experimentals called in that they were set up for their "overhead entry". They were flying above pattern altitude on the runway heading, proceeded to make a diving 180 turn to downwind, inside our line. Two of them jumped ahead of us, while the third resigned himself to following our Citabria. I guess we really messed up their spectacular approach and possible formation landing... (yawn) So, I'm wondering if their overhead approach to an un-controlled field is "approved"? Petaluma can get pretty busy on weekends, and I feel their grandstanding lead to some concern and un-necessary avoidance manuevering... Harry Shin Citabria N5064K, Sonerai I 'a building |
Harry Shin wrote: So, I'm wondering if their overhead approach to an un-controlled field is "approved"? Descending into a leg of the pattern is generally considered to be less than safe due to the risk of a collision. It's a little less dangerous when the descending aircraft is a high-wing, but it's still frowned upon. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
than safe due to the risk of a collision. It's a little less dangerous when the descending aircraft is a high-wing, but it's still frowned upon. While what you say is true, I have tried the "overhead break" on occasion, and found it to be a very good way to see the entire pattern before entry. It's also a lot of fun. On the other hand, it's always the one you *don't* see that kills you, and ground clutter can make spotting traffic difficult, so descending into the pattern can be dangerous. To reduce this risk, I've tried entering the pattern for this kind of an "overhead break" just 100 or so feet above "normal" pattern altitude. This seemed to be a good compromise, minimized the amount of time spent descending into a possible conflict, while still allowing for a good scan of the whole pattern. Is it still dangerous? I would rate it as mildly more risky than the more standard "entering on a 45," and slightly less risky than a long straight-in. Therefore, I don't use this approach when I know there is other traffic in the pattern. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Jay Honeck" wrote
While what you say is true, I have tried the "overhead break" on occasion, and found it to be a very good way to see the entire pattern before entry. I didn't know that there was any other entry for the first 18 months of my flying life. :-) Bob Moore |
"Jay Honeck" wrote in message news:11_Mb.46583$na.36172@attbi_s04... Descending into a leg of the pattern is generally considered to be less than safe due to the risk of a collision. It's a little less dangerous when the descending aircraft is a high-wing, but it's still frowned upon. While what you say is true, I have tried the "overhead break" on occasion, and found it to be a very good way to see the entire pattern before entry. It's also a lot of fun. In the UK, the standard entry at an uncontrolled field is an overhead join. You arrive above circuit height and then descend on the "dead side", i.e. the opposide side to the downwind. You then fly crosswind to downwind. As Jay said, it's a good way of seeing any traffic that is currently in the circuit. It's also the way to see the windsock. What you don't do is descend into the circuit. Paul |
"Harry Shin" wrote in message ... Hi Guys, My father and I were returning to Petaluma (O69), called in on the 45 to downwind and were just about to turn downwind when a flight of three experimentals called in that they were set up for their "overhead entry". They were flying above pattern altitude on the runway heading, proceeded to make a diving 180 turn to downwind, inside our line. Two of them jumped ahead of us, while the third resigned himself to following our Citabria. I guess we really messed up their spectacular approach and possible formation landing... (yawn) So, I'm wondering if their overhead approach to an un-controlled field is "approved"? Petaluma can get pretty busy on weekends, and I feel their grandstanding lead to some concern and un-necessary avoidance manuevering... Harry Shin Citabria N5064K, Sonerai I 'a building The Overhead Entry is a "standard" procedure, although you don't see 'em much except from the warbird and/or experimental crowd. I followed a long, bitter discussion on this topic on the RV-list (a mail list for RV builders/flyers), and the opinions on using the overhead approach were all over the board, ranging from "We do it all the time and it is very safe" to "It is a very dangerous procedure and should never be used.". In the end, it comes down to common sense. If an overhead entry causes traffic problems with other aircraft in the pattern, it shouldn't be used. Othewise, it is fine (assuming you're keeping your eyes out, using common sense, and all the other caveats that go with flying). KB |
"Harry Shin" wrote: Hi Guys, My father and I were returning to Petaluma (O69), called in on the 45 to downwind and were just about to turn downwind when a flight of three experimentals called in that they were set up for their "overhead entry". They were flying above pattern altitude on the runway heading, proceeded to make a diving 180 turn to downwind, inside our line. Two of them jumped ahead of us, while the third resigned himself to following our Citabria. I guess we really messed up their spectacular approach and possible formation landing... (yawn) So, I'm wondering if their overhead approach to an un-controlled field is "approved"? Petaluma can get pretty busy on weekends, and I feel their grandstanding lead to some concern and un-necessary avoidance manuevering... Harry Shin Citabria N5064K, Sonerai I 'a building It sounds as if the formation leader screwed up. He should have been looking for other traffic and let you go ahead -- even to the point of taking his formation around for another approach. Nor should he have done a "diving break," which impairs his view of other traffic. I regularly fly formation, with overhead breaks to downwind. Rule #1 is that traffic already in the pattern has the right-of-way. Another thing we do is announce our intentions: "White Flight one mile initial, left overhead break," to let others know we are operating. Now, Harry, did YOU announce YOUR entry into the pattern? I realize that it is not required, but it IS good practice. |
"Orval Fairbairn" wrote in message news
Now, Harry, did YOU announce YOUR entry into the pattern? I realize that it is not required, but it IS good practice. Orval, First sentence (!), "My father and I were returning to Petaluma (O69), called in on the 45 to downwind..." (and all other legs as well, FWIW) You formation guys need to pay more attention... Harry |
"Harry Shin" wrote: "Orval Fairbairn" wrote in message news
Now, Harry, did YOU announce YOUR entry into the pattern? I realize that it is not required, but it IS good practice. Orval, First sentence (!), "My father and I were returning to Petaluma (O69), called in on the 45 to downwind..." (and all other legs as well, FWIW) You formation guys need to pay more attention... Harry Harry: If that is your attitude, maybe YOU need to adjust YOUR attitude! If you called the 45, you were NOT in the traffic pattern! Did you pay attention to the frequency? Did the formation call "initial"? I have seen so-called "pattern operations" flying extra wide downwinds and two mile finals -- enough to land several flights of four. Generally, our formation flights keep it in tight and have about ten seconds spacing on landing. BTW, your reference to "spoiling a formation landing" shows you know nothing about formation flying. They came overhead in the break and, as such, would have been landing individually, with one rolling out as the next touched down. |
If that is your attitude, maybe YOU need to adjust YOUR attitude! If you called the 45, you were NOT in the traffic pattern! Did you pay attention to the frequency? Did the formation call "initial"? As I warned in my post, when you (that is, the original poster) start to question the holy right of libertarian pilots to do what they damned well please in the pattern, you are going to get some heated replies. My own policy is this: when there are idiots in the pattern, either take your best shot to get on the ground safely, or go away and land somewhere else. These people have closed minds, and they are flying airplanes that can kill you. My favorite example of this sort of booby was the *instructor* who had his student fly *straight in* to a field where neither had landed before, that was marked "heavy flight training," and that did its training in NORDO aircraft -- and then bawled out the Cub driver on base for not listening to the radio calls! all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
| Thread Tools | |
| Display Modes | |
| VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 06:03 AM |
| Front louvers for Cherokee/Archer overhead vents? | Bob Chilcoat | Owning | 10 | February 3rd 04 11:19 PM |
| Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 10:40 PM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
