Circular Runway
Old March 31st 04, 09:58 PM
jsmith
Default Circular Runway
Good article in the recent issue of AIR & SPACE.
A USN pilot got the idea for a circular runway after experiencing an
engine failure and landing on a country road.
He proposed the Navy test the idea. He was killed in an accident, but
someone carried the ball got the testing approved.
The tests were satisfactorily completed with Navy jet fighters at
Goodyear's test track.
A 10,000 foot banked oval works at low and high speeds.
Taladega?
Daytona?
(What are the other Super Speedways?)
Old March 31st 04, 10:18 PM
Cub Driver
Circular (or at least 360-degree) airfields were common at one time.
You put a stake in the center with a windsock on top. The aircraft
landing simply landed into the wind, wherever it was coming from.
Wu Chia Ba airport in Kunming used this arrangement before the
Americans arrived toward the end of 1941.
all the best -- Dan Ford
email: -- put Cubdriver in subject line!
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old March 31st 04, 10:30 PM
Steven P. McNicoll
"Cub Driver" wrote in message
Yes, but that's not what he's talking about. What you're describing is an
"all ways" airfield in which aircraft can land and takeoff in any direction,
but with a straight ground run. He's talking about a runway in a circle
where aircraft use a curvilinear ground track.
Old March 31st 04, 10:42 PM
John Harper
Sounds like an obvious candidate for that wonderful approach
out East with a DME arc right to the MAP...
John
ink.net...
direction,
Old March 31st 04, 10:47 PM
Peter Duniho
I don't think that's what he's talking about. You're right that circular
airfields (always grass, as far as I know) where the pilot could always land
into the wind were common in the early days of aviation.
Sounds to me as though what the original poster is talking about is a paved,
circular track. Sort of the exact opposite of the early circular airfields,
in that rather than always being able to operate in a straight line into the
wind, the pilot would always be assured of having the most difficult type of
landing or takeoff, with a varying crosswind at virtually every point of the
operation (except for one very brief moment), and the requirement that the
airplane be flown in a turn for the entire time.
The only advantages I see are that you never run out of pavement (the runway
is effectively of infinite length) and that you can use the land more
efficiently. However, given how well landing in a straight line seems to be
working out for most of us, I can't imagine the benefits would outweigh the
considerable safety concerns.
Perhaps this was an April Fool's joke that Air & Space Magazine played on
its readers?
Pete
Old April 1st 04, 01:52 AM
jsmith
The theory posited in the article was that one could always land and
takeoff into the wind using a circular runway.
The banked track would counter the crosswind component.
Perfect for aircraft built by Republic Aircraft. ("If they built a
runway around the world at the equator, Republic would build and
airplane to use it.")
its readers?
Old April 1st 04, 02:02 AM
Larry Dighera
On Thu, 01 Apr 2004 00:52:35 GMT, jsmith wrote in
Message-Id: :
That would be true 50% of the time.
Old April 1st 04, 02:26 AM
Steven P. McNicoll
"Larry Dighera" wrote in message
How so?
Old April 1st 04, 07:53 AM
Bob Fry
Larry Dighera writes:
Message-Id: :
Or less. A lot less. The bank needed would depend on the aircraft's
varying speed, in addition to the (variable) wind velocity. The whole
thing sounds like a joke--1 day early.
Peter Duniho
"jsmith" wrote in message ...
Surely you can see how that theory makes no sense. The airplane would only
be pointed into the wind for a very brief moment during a takeoff or
landing.
Actually, I expect the bank is intended to deal with the bank of the
airplane required to produce the constant radius turn required for landing.
There's no way a banked track would "counter the crosswind component",
especially given that the component would be constantly changing throughout
the takeoff or landing.
But it's even worse than that, since the bank of the track will only match
the bank of a given airplane at a given groundspeed, since the aircraft
needs to maintain a constant radius turn. There will still be some degree
of difference between the bank of the airplane and the bank of the track.
Not sure what that has to do with this circular runway. After all, a runway
around the world at the equator would still be straight.
Pete
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 05:40 PM
F15E's trounced by Eurofighters John Cook Military Aviation 193 April 11th 04 03:33 AM
Rwy incursions Hankal Piloting 10 November 16th 03 02:33 AM
Moving violation..NASA form? Nasir Piloting 47 November 5th 03 07:56 PM
