Ventus 2cxa with FES
Old April 14th 14, 09:17 PM posted to rec.aviation.soaring
LZ design
Default Ventus 2cxa with FES
Some photos from 1st public presentation of Ventus 2cxa with FES during Aero 2014
https://picasaweb.google.com/1154794...noredirect= 1
Regards,
Luka
Old April 14th 14, 10:04 PM posted to rec.aviation.soaring
Mike the Strike
Well, that answers the question of how to fit the FES to a glider with a non-circular nose section, like the Discus and Ventus!
I wonder who the intended buyer is, though. Avid racers won't like the extra drag and those attracted to self-launchers won't have enough power. Are there enough folks like me who fly a fair amount of cross-country and who like the idea of a reliable sustainer?
Old April 14th 14, 10:13 PM posted to rec.aviation.soaring
Andy K
This is a big prop. I wonder if they tried to self launch it. I bet the engine is powerful enough and it is all about battery capacity.
Old April 15th 14, 12:11 AM posted to rec.aviation.soaring
Greg Arnold
I wonder if they are using the CG tow hook, or if they have installed a
hook forward of that. I thought that you couldn't have a new glider
with only a CG hook in Europe.
Old April 15th 14, 10:27 AM posted to rec.aviation.soaring
Dne torek, 15. april 2014 01:11:27 UTC+2 je oseba Greg Arnold napisala:
There is a suitable space for a front hook below instrument panel, where is usualy located front battery. This battery is not required anymore.
Regards,
Luka
Old April 15th 14, 10:22 AM posted to rec.aviation.soaring
Dne ponedeljek, 14. april 2014 23:13:19 UTC+2 je oseba Andy K napisala:
You are right, we made a bigger chord of the blade, in order to load motor more. We expect about 26kW of max power, which will be enough even for selflaunch. Battery compartment is designed in a way so that there will be a possibility to install bigger battery pack, which will allow range of 180km of level flight or altitude gain of 2000m!
Old April 14th 14, 10:45 PM posted to rec.aviation.soaring
Ramy[_2_]
I would be interested to know if it can be fitted into an ASW27.
Ramy
Old April 14th 14, 11:19 PM posted to rec.aviation.soaring
Mike the Strike
I suspect that there's not enough ground clearance to self-launch, but a vehicle launch to modest height plus a climb out on the electric motor might work (some weaker self-launchers use this technique, especially at high density altitudes).
No doubt the developers will let us know!
Old April 15th 14, 10:23 AM posted to rec.aviation.soaring
Dne torek, 15. april 2014 00:19:29 UTC+2 je oseba Mike the Strike napisala:
There is enough ground clearence for a selflaunch from concrete runway or smooth grass.
Old April 15th 14, 01:10 AM posted to rec.aviation.soaring
Steve Koerner
From a competition pilot point of view there would have to be a small drag penalty and a weight penalty. But both of those would seem to be pretty small in comparison to the competitive benefit that arises from the ability to stick to the course line and never have to be distracted by the need to deviate towards a landing option. I don't have experience to know, but I'm suspecting that the reliability of the FES might be sufficient that one could drive it straight into the boonies then flip the switch only at the last minute -- wouldn't that be exciting? You certainly can't do that with a gas engine.
AS responds to the latest Ventus 2cxa KevinFinke Soaring 3 March 18th 09 03:45 AM
Ventus 2C W&B - 15M vs 18M [email protected] Soaring 0 March 29th 06 10:20 PM
FS: Ventus C KO Soaring 9 November 5th 05 12:58 AM
FS: Ventus C 17.6 John Shelton Soaring 0 November 16th 04 12:55 AM
FS Ventus C 17.6 John Shelton Soaring 0 November 15th 04 09:10 PM
