Constant speed props
Old June 24th 04, 01:17 PM
GE
Default Constant speed props
I'm taking delivery today of my first aircraft and it had a constant speed
prop. I have only flown fixed props thus far. I want to have as much
understanding of the c-s prop as possible before I get with my instructor. I
understand the basic difference in what the controls do, but I don't really
have a good understanding of the hows and whys of flying with them. Any
general information, explanations, and tips would be greatly appreciated.
Old June 24th 04, 01:30 PM
EDR
In article , GE
Go to www.avweb.com
on the left side of the screen, select COLUMNS
scroll down to find THE PELICAN"S PERCH
there are articles on fuel injection, manifold pressure, constant speed
props, leaning, etc
Everything you ever want to know about operating a high performance
aircraft engine is in those articles.
Old June 24th 04, 04:23 PM
Greg Copeland
On Thu, 24 Jun 2004 12:30:03 +0000, EDR wrote:
In article , GE
Go to www.avweb.com
props, leaning, etc
Great link!
I started reading this
article, http://www.avweb.com/news/columns/186619-1.html, and have a
question. In the Runup section, when he starts to test for proper mag
operation, somethings seems odd there. Can someone help explain that? He
says, "Are the mags working? The leaner the mixture, the more mag drop
you'll see on one mag, and that's normal." He then goes on to say, "The
EGTs should rise on the first single-mag operation, stay there for the
second, then drop again on the return to BOTH. That rise is proof-positive
the entire ignition system is working, and working well, and the leaner
the mixture, the more diagnostic it is."
Can someone help explain the supporting logic there? If both mags are
working properly and you switch to a single mag, why would the EGT go up?
After all, in theory, you're producing less spark and thusly, a slightly
less effecient ignition of the fuel/air. I would of thought that EGT
would stay the same or go down *just slightly* when running off of one
mag. Likewise, if one mag is not working, I would fully expect to see a
big EGT drop for the given problematic mag, which he does agree with.
But, he further asserts that, "If any of them fail to rise or even drop
during single-mag operation, there is a problem with that plug, the wire,
or the mag."
So, why would running on one mag, versus two, always cause higher EGTs?
And why would no rise in EGT indicate a bad mag, wire or plug?
Anyone?
P.S. I cross posted because this seems like good student pilot material
too.
Old June 24th 04, 04:41 PM
Roger Hamlett
"Greg Copeland" wrote in message
news
In article , GE
speed
instructor. I
really
appreciated.
Go to www.avweb.com
props, leaning, etc
Great link!
or the mag."
Anyone?
too.
The key is that with two plugs, the combustion _in the cylinder_ is more
complete, earlier. When one mag cuts, the fuel air mixture still fully
burns, but the burn is continued slightly latter (where it does less work on
the piston). This results in the gas coming out of the exhaust being a
little hotter (in some cases, it may even be still burning).
Best Wishes
Old June 24th 04, 04:55 PM
Greg Copeland
news
In article , GE
speed
instructor. I
really
appreciated.
Go to www.avweb.com
props, leaning, etc
Great link!
or the mag."
Anyone?
too.
Best Wishes
Makes perfect sense! Thanks!
Old June 24th 04, 09:45 PM
CVBreard
I can confirm that an engine running on one mag will show a higher EGT than on
both mags.
I went through the preflight, run-up, took off and during full-power climbout,
I noticed a significantly higher EGT than I was used to.
Startled me until I discovered that in the pre-takeoff mag check I had left the
mag switch on only one mag - I took off and was climbing on a single mag. Duh!
Switching to both mags brought the EGT back down to normal.
Old June 24th 04, 05:08 PM
Dudley Henriques
I don't wish to sound like a smartass here, but what's your problem with
getting a full checkout in this airplane from a competent pilot current
in the aircraft?
It sounds like you might benefit from a bit of complex training here!!!
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/ CFI Retired
For personal email, please replace
the z's with e's.
dhenriquesATzarthlinkDOTnzt
news
In article , GE
constant speed
much
instructor. I
don't really
Any
appreciated.
Go to www.avweb.com
speed
props, leaning, etc
Great link!
He
"The
proof-positive
leaner
up?
slightly
a
drop
wire,
or the mag."
EGTs?
Anyone?
material
too.
Old June 24th 04, 05:21 PM
Greg Copeland
in the aircraft?
Dudley Henriques
I wondered the same thing, but you're replying to the wrong person. I'm a
student and GE posted the original question.
Cheers!
Old June 24th 04, 06:47 PM
Dudley Henriques
I caught that right after I posted it :-) I had cleaned out OE last
night back to four days old and missed the pickup. Thought I had
deleted this but obviously it didn't work!
Anyway.....it looks to me like the IP needs a complete checkout in this
airplane before flying it. His questions just seem way out of line for
someone taking delivery of an airplane they are rated and competent to
fly!
Sorry about the mispost :-)
DH
news
with
current
in the aircraft?
here!!!
Dudley Henriques
I'm a
Cheers!
Old June 25th 04, 01:45 PM
GE
Thanks for your reply, as well as the debate on my actual intentions. "Get
with my instructor" was implying that I will be getting the proper training
in this aircraft from a qualified CFI. I simply wanted to increase my
knowledge prior to that instruction.
"Dudley Henriques" wrote in message
ink.net...
in the aircraft?
Dudley Henriques
the z's with e's.
news
In article , GE
constant speed
much
instructor. I
don't really
Any
appreciated.
Go to www.avweb.com
speed
props, leaning, etc
Great link!
He
"The
proof-positive
leaner
up?
slightly
a
drop
wire,
or the mag."
EGTs?
Anyone?
material
too.
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 04:41 AM
Constant speed prop oil leak DP Piloting 23 April 21st 04 10:15 PM
Why do constant speed power setting charts limit RPM? Ben Jackson Piloting 6 April 16th 04 03:41 AM
Practicing SFLs with a constant speed prop - how? Ed Piloting 22 April 16th 04 02:42 AM
Constant Speed Prop vs Variable Engine Timing Jay Home Built 44 March 3rd 04 10:08 PM
