What is a "Forward Skip"?
Old January 6th 05, 02:40 PM
Gary G
Default What is a "Forward Skip"?
Hi folks - I'm somewhat new to flying.
I heard references to "forward slip" to get rid of altitude on approach.
Can someone give me the 2 sentence (or how ever many is adequate) to
what a forward slip procedure is?
Thanks!
Gary
Old January 6th 05, 02:56 PM
569
Slip into the wind. Add hard right rudder, turn the yoke hard left,
add some forwad pressure. This exposes more of the surface to the
wind, and you're able to loss more altitude, without a noticable gain
in airspeed. Some aircraft prhobit slips with flaps extended, others
make no mention.
Old January 6th 05, 03:44 PM
Edwin Johnson
Also note that some of the older aircraft and some of the present homebuilts
and experimentals had no flaps, so this was the main method of losing
altitude on landing approach if a steep glide path was needed, such as over
obstacles. A good reason this is needed and should be practiced today is in
the event the flaps become inoperative in the case of an engine out or other
emergency.
....Edwin
~ Edwin Johnson ....... ~
http://www.shreve.net/~elj ~
~ "Once you have flown, you will walk the ~
~ earth with your eyes turned skyward, ~
~ for there you have been, there you long ~
~ to return." -- da Vinci ~
Old January 6th 05, 06:33 PM
Stefan
And even others don't have enough forward view, so flying sideways is
the only possibility to see the runway on final.
Stefan
Old January 6th 05, 04:04 PM
Peter R.
Which ones?
Peter
Old January 6th 05, 04:51 PM
569
The Cessna 172R has a placard, "Avoid Slips with Flaps Extended". Now
it says, "avoid". It does not say that you can't do it. There was a
discussion in Flight Training Mag about 6 months ago that talked about
that same thing. In the Cessna 152 I always have full flaps in a slip.
I don;t truely understand why having flaps is a problem in the 172R.
Old January 6th 05, 07:57 PM
Happy Dog
"569" wrote in message news:
The aircraft tends to oscillate on the pitch axis. It's never been shown to
be a hazard though. Just feels a bit weird.
le m
Old January 6th 05, 05:00 PM
Cessna 172M
"Avoid slips with full flap extension"
Peter R. wrote:
Which ones?
Mike Flyin'8
PP-SEL
Old January 6th 05, 05:09 PM
Peter R.
) wrote:
Cessna 172M
Are the words "avoid" and "prohibited" interchangeable?
Peter
Old January 6th 05, 05:19 PM
In the context it is used, and for my level of flying experience, yes they
are interchangeable. I do not know more about the danger of this than
Cessna, so I would prefer to trust what they say. You level of experience
is certainly different that mine, so your decision may be different than
mine.
That is not say that in the event of emergency I would not perform a slip
to land with full flaps if the need dictated.
Peter R. wrote:
) wrote:
Cessna 172M
Mike Flyin'8
PP-SEL
Don't skip that runup! Roger Long Piloting 8 July 8th 04 07:04 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
B-17 forward guin positions zxcv Military Aviation 13 March 16th 04 12:04 AM
Forward Swept Wings Canuck Bob Home Built 16 October 3rd 03 05:50 PM
Honor to those who came forward ArtKramr Military Aviation 51 July 7th 03 11:19 PM
