Emergency instrumentation for cloud encounters
Old April 20th 15, 06:55 PM posted to rec.aviation.soaring
Default Emergency instrumentation for cloud encounters
why not have one of these:
http://store-vllhq23n.mybigcommerce....-in-enclosure/
http://store-vllhq23n.mybigcommerce....dback-systems/
This is portable and powers up in seconds in any attitude or flight condition.
Contrary to the label this is a pure yaw rate indicator, plus a slip-skid indicator. It does not behave quite like a "turn coordinator".
There are of course more comprehensive ways to go, but this is a whole lot better than nothing. I'm speaking specifically to those pilots who are currently flying with nothing. We all know that in some circles, partial-panel flying of sailplanes in clouds is, or used to be, considered a perfectly normal thing to do.
Some dual practice under the hood would be extremely beneficial of course. It's crucial to respond to the direction the ASI needle is trending, more than to the actual airspeed indication. This doesn't come intuitively.
Likewise this particular instrument has in my opinion a significant possibility of being read backwards. The fixed aircraft symbol on the front of the device has no significance and in my opinion should be covered up with a blank label, or with some design of the pilot's own creation, so the pilot is not tempted to interpret the instrument like an artificial horizon. which would be backwards. The LED's represent the wingtips of an imaginary aircraft which tips left and right to indicate turning-- not a horizon line.
But I can attest that it works.
The compass-on-a-southerly-heading trick works too, as discussed in a related thread recently. ("In wave, in blue hole at cloud level, hole closes, in IMC, then what?"). But you are utterly and thoroughly hosed if you let the compass swing out of the "sweet spot" that extends for about 45 to 60 degrees on either side of the the due magnetic "south" indication. You had better be established and stabilized on this heading before losing visibility. I'm speaking for mid-latitudes in the northern hemisphere here.
I once had an experience where I was unable to hold heading in a cumulus cloud using GPS + rudimentary turn rate indicator. I was able to keep out of a spiral dive, but not able to hold heading well enough to make good progress out of the cloud. However, I was able to keep the turn rate low enough that I could successfully "capture" a southerly heading and then I switched over to using the compass as my primary instrument, and I was able to hold heading indefinitely. On a southerly heading, the compass actually did a prompter and better job of signalling small heading deviations, than did the rudimentary turn rate indicator. It would be pretty much suicidal to try this without having the turn rate indicator to fall back on in case a spiral dive started to develop due to a strong jolt of turbulence or a wrong control input on the pilot's part.
In thermal conditions, there's no excuse for accidentally getting into clouds, and an untrained pilot is likely to be in a world of hurt. But in the (sometimes) smoother wave environment, I think there's a real case to be made for routinely carrying a turn rate indicator for emergency use. And a freshly packed parachute of course.
S
Old April 20th 15, 08:51 PM posted to rec.aviation.soaring
A few more thoughts after reading the other related thread:
* Have you every watched how the magnetic compass behaves in a turn? Even with a bank angle as shallow as 30 degrees, it's hopeless, especially at low airspeed. Random freeze-ups and reversals in rotation are par for the course. Nonetheless there are specific ways to use it in cloud-- by establishing a southerly heading before entering cloud, or by using another instrument to level the wings before attempting to "capture" the southerly heading via a very shallow turn. Again, these comments are for mid-to-high latitudes in the northern hemisphere.
* Is there really such a thing as an instant-on artificial horizon? Is it instant-on even in a spiral dive? Which models are these? The turn rate indicator I linked to above has an initiation time of less than 5 seconds and is not affected at all by the aircraft's orientation and flight path.
* Re the dirty vs clean question-- I'd vote strongly for "dirty". Anything that creates drag tends to dampen the pitch phugoid. Sudden changes in bank angle-- due to turbulence or wrong pilot control inputs-- pump energy into the pitch phugoid. This is a huge problem when flying "partial panel" in an aircraft with relaxed pitch stability. Drag is your friend even if the G-load at which the airframe breaks is reduced by several G's. If you are pulling more than 3 G's or so in cloud, you are unlikely to be getting the aircraft back under control anyway-- especially if it is clean.
S
Old April 20th 15, 09:05 PM posted to rec.aviation.soaring
Instant on artificial horizons? Yes. Two choices.
The LXNav S80.
The Butterfly Vario.
Both are functioning at all times.
Both are 100% solid state and will not tumble.
Old April 20th 15, 09:12 PM posted to rec.aviation.soaring
7C
The LXNav S80.
The Vaulter - cheaper than either and both excellent and simple
http://wharingtonsmith.com/vaulter.html
Don't forget that none of these instruments are designed for that purpose - if you really need a AH you should buy an AH!
Old April 21st 15, 12:54 AM posted to rec.aviation.soaring
son_of_flubber
The LXNav S80.
http://www.parts4aircraft.com/Files/...ainlarge-1.jpg
http://www.mglavionics.com/html/infinity_singles.html
Old April 21st 15, 03:10 PM posted to rec.aviation.soaring
Dan Marotta
Well said.
My TruTrac is pseudo "instant on" in that, within a second or two, it
shows the turn even when switched on in the turn. It is "rate based"
whatever that means. When a gyro instrument is turned on in a turn it
will erect itself to the vertical g-loading of the aircraft unless it
has some fancy way of telling up from the load experienced. This I know
from partial panel practice whereby the front seat pilot would perform
aerobatic maneuvers while the back seat pilot, under the instrument
hood, would hold the attitude indicator caged. The AI would show level
flight regardless of attitude until the cage knob was released and, when
the aircraft was recovered from its unusual attitude, the AI would show
some strange attitude which was, of course, incorrect.
It would be very interesting to try one of these new digital gyros and
see how it erects in an unusual attitude.
S
Dan Marotta
Old April 21st 15, 03:41 PM posted to rec.aviation.soaring
The TruTrac (or at least some models) is conceptually the same thing as the instrument I linked to. More bucks and a more user-friendly display. I can certainly believe that it is instant-on in any flight attitude. The main display is driven by a 1-axis turn rate gyro, not an AHRS system.
S
Old April 21st 15, 03:45 PM posted to rec.aviation.soaring
I mean "sensor" of course, not an actual gyro.
Old April 20th 15, 11:36 PM posted to rec.aviation.soaring
Thanks for the notes. Don't get me wrong, I think an artificial horizon is a very great thing to have. But, just as a point of conversation, I'd be really be surprised if these things were instant-on in the sense that I was talking about. Surely the guts of the system--the AHRS sensors and processors-- have to be up and running for at least a few tens of seconds before the artificial horizon is needed. And I doubt that those few tens of seconds can take place during a spiral dive. I'd love to be proven wrong-- it would make for a very interesting in-flight video.
Seriously, how long would it take to bring the whole system up from a cold start to accurate functioning during
a) reasonably straight-line flight
b) a spiral dive
I submit that there's some advantage offered to having a self-contained turn rate indicator unit that can be powered up quickly regardless of the glider's flight attitude, as a supplement to whatever AHRS-based artificial horizon may or may not be present.
Sure, it's all a question of how far you want to go. But maybe a vario-incorporated artificial horizon plus a stand-alone instant-on (or rapid-on) turn rate indicator with independent self-contained battery power is a reasonable alternative to a purpose-built artificial horizon instrument, at least for the purpose of strictly emergency use.
Food for thought...
S
Old April 21st 15, 12:41 AM posted to rec.aviation.soaring
waremark
My LX 9000 with v9 is up within 2 or 3 seconds if I switch to a page which shows it while in a thermalling turn. I understand Dynons and other solid state horizons do the same. Why would you ever bring it up when in a spiral dive? I have no reason to doubt that it would perform correctly, but it sounds rather unlikely if equipped with an A-H to enter IMC without having switched it on.
IMC and Cloud encounters - Videos [email protected] Instrument Flight Rules 0 January 3rd 11 01:33 AM
IMC and Cloud Encounters - Videos [email protected] Piloting 0 January 3rd 11 01:33 AM
OT Cloud to cloud lightning - video [email protected] Piloting 0 August 4th 08 01:01 AM
Close encounters of the Cloud kind - Video [email protected] Instrument Flight Rules 1 June 10th 08 01:11 PM
Close encounters of the cloud kind - Video [email protected] Piloting 0 June 9th 08 11:28 PM
