Glide ratio with full brakes and side slip
Old June 11th 16, 04:58 PM posted to rec.aviation.soaring
Default Glide ratio with full brakes and side slip
Charlie: could you explain what the "Snowbird" involves? (And say "hi" to my old friends at HHSC, if they're still there - it's been a long while!)
  #52
Old June 11th 16, 05:45 PM posted to rec.aviation.soaring
Energy management mostly.
Each flight covers 4 items together:
-precision duration (usually multiples of 15 minutes timed to the second)
-touchdown in marked zones, touching before 1st zone is a big point hit, touching further is lessor hits
-stopping at a cone, scored to the inch
-cumulative altitude gain
So, duration 5 seconds off, touchdown in prime zone (no deduction), stopping within 5" of cone and no altitude gain would yield a score of 990 points.
You're allowed 2 flights Friday and 2 flights Saturday, a good year will require averaging high 900's!
HHSC's website should have more info on it, but that's the basics. It really measures energy management and pattern planning, good skills for off airport landings.
Glide Ratio of a King Air? Karen Soaring 3 November 15th 10 07:29 PM
Side slip Jim Naval Aviation 4 December 6th 06 07:18 PM
So you think you have a low glide ratio! COLIN LAMB Soaring 30 January 12th 06 02:47 PM
GPS glide ratio calculations james Soaring 0 May 4th 04 09:00 PM
GPS glide ratio calculations Jason Armistead Soaring 16 September 12th 03 04:50 AM
