#51
Eric,
The vortices at the edges of clouds I am referring to are in the horizontal, though they typically have a significant vertical component as well (otherwise, why bother with them). That's why it is important to view them from directly below. This makes seeing the horizontal component much easier. Observed localized rotation at cloudbase (the only place we can see it) is substantially lower than the rotation rate observed in dust devils. This is expected. As we go up a dust devil, it expands with altitude. Conservation of angular momentum alone will account for a substantial reduction in rate of rotation. As for the rate of rotation of the entire system, I have never measured it. All I can say here and now is that it is slow but observable. Let's, for the sake of argument, say that it moves three times as fast as the minutehand on a clock, that is 18 degrees per minute. (Remember, this is at the edges of the thermal. We would expect increased rotation within a strong core.) If the cloud is 1/4m in diameter, the speed of rotation is about 2 knots. That's a 4 knot differential for a left versus right turn, with corresponding turn radii for a given angle of bank. Granted, the system is turbulent. And there are additional factors that might contribute to large scale rotation such as wind shear, inversion, perhaps even condensation. For argument's sake, let's say that it does rotate, on both large and localized scales. What advantage can we take? How can we detect it? How might we change our approach, entry, and centering techniques to maximize overall rate of climb? These are the questions worth pondering. |
#52
Mike Borgelt wrote in message . ..
Water vapour has a molecular weight of a bit over 18 and dry air a bit more than 28. Water vapour at the same pressure as the air around it is considerably less dense than dry air. More water vapour= more bouyancy. Then again this may have more to do with low spots in the ground. I've always found quarries (holes in the ground)to be excellent lift sources when low. This discussion is fascinating. I've been flying gliders for some 27 years and have read a lot of books on the theory and practice (Moffat, Reichmann, Piggott, etc) and never ran into any reference to this thermal source (or trigger mechanism) - but here we have pilots from three continents describing apparently the same, common, reliable trigger mechanism - all apparently discovered empirically (thats how I found it, that and following Andy around trying to keep up with him ![]() here are experienced pilots heading for a low pond! Same thing with sandy areas - the books say to avoid them like the plague, but the sandy washes here in Arizona are also consistent thermal sources - and like the ponds/tanks, are low discontinuities in the local terrain. In this case, I'm sure it's not the sand that is causing the thermal, my uneducated guess is that the wash channels (or collects) the incipient themal until it gets big and strong enough to break loose. Any Real Smart Guys out there care to give us a serious possible explanation for these effects? - or maybe we need to keep this to ourselves and let the youngsters figure it out for themselves! Got to keep a few tricks in our bags, you know, something about age and experience beating youth and skill... Kirk |
#53
Chris OCallaghan wrote:
For argument's sake, let's say that it does rotate, on both large and localized scales. What advantage can we take? How can we detect it? This will be a problem at the 18 deg/min you proposed. I circle at about 720 deg/min, so the chances of me noticing this while thermalling are probably zero. For the small cloud you mentioned, the "observation time" as I approached it would be something like 30 seconds or less, which corresponds to a 9 degree rotation - hard to discern. Believe me, I have intently watched thousands of cloud bottoms as I approached them, and I have never noticed any large scale rotation. It might be there (like I said, I'll try watching from the ground next time I see a cu), but it isn't obvious. How might we change our approach, entry, and centering techniques to maximize overall rate of climb? These are the questions worth pondering. Asking top competition pilots about this might be a way to start, though I've never heard any of them mention rotation as a factor in their decisions. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#54
![]() age and deception is even better ourselves and let the youngsters figure it out for themselves! Got to keep a few tricks in our bags, you know, something about age and experience beating youth and skill... Kirk |
#55
Most people can't see a minute hand moving, but it moves nonetheless. It's a matter of patience. The problem with observing cloud rotation is that the cloud is constantly changing shape, therefore you cannot time lapse the same way you can when observing vertical development (or determining that a minute hand moves). As noted in my impolite post, you need to spend a half hour on your back. Then we can move on to discussing whether there's any real advantage to be had. I've seen several time-lapse videos of cu. Never noticed (or had pointed out) any rotation. I have seen mesocyclone footage. Very cool. Do you know of any web sites with a clip showing this? Cheers, Shawn |
#56
When low I have always looked for the the point or line where the difference
in ground condition/temperature is likely to trigger uplift ,I have even had the edge of a small cloud shadow that I followed between 300-600ft agl for 10 miles before finally enough warm air was encountered to form a decent enough columm to climb consistantly gary "Kirk Stant" wrote in message om... Mike Borgelt wrote in message . .. Water vapour has a molecular weight of a bit over 18 and dry air a bit more than 28. Water vapour at the same pressure as the air around it is considerably less dense than dry air. More water vapour= more bouyancy. Then again this may have more to do with low spots in the ground. I've always found quarries (holes in the ground)to be excellent lift sources when low. This discussion is fascinating. I've been flying gliders for some 27 years and have read a lot of books on the theory and practice (Moffat, Reichmann, Piggott, etc) and never ran into any reference to this thermal source (or trigger mechanism) - but here we have pilots from three continents describing apparently the same, common, reliable trigger mechanism - all apparently discovered empirically (thats how I found it, that and following Andy around trying to keep up with him ![]() here are experienced pilots heading for a low pond! Same thing with sandy areas - the books say to avoid them like the plague, but the sandy washes here in Arizona are also consistent thermal sources - and like the ponds/tanks, are low discontinuities in the local terrain. In this case, I'm sure it's not the sand that is causing the thermal, my uneducated guess is that the wash channels (or collects) the incipient themal until it gets big and strong enough to break loose. Any Real Smart Guys out there care to give us a serious possible explanation for these effects? - or maybe we need to keep this to ourselves and let the youngsters figure it out for themselves! Got to keep a few tricks in our bags, you know, something about age and experience beating youth and skill... Kirk |
#57
explanation for these effects? - or maybe we need to keep this to ourselves and let the youngsters figure it out for themselves! Got to keep a few tricks in our bags, you know, something about age and experience beating youth and skill... Here's a hand-wavy guess. Whenever you have differences in the land surface - like a pond next to solid ground - the heating is gonna be different. The two differently heated parcels adjacent to each other will tend to stir the air a bit. This can lead to a very local and small-scale convergence which can act as the trigger. The bit of water vapor from the air that was over the pond will help the average buoyancy of the thermal - but I think the moisture effect is secondary to the convergence. I've no data to back this up; just a hunch. But whenever the convergence has been noticable on a thermic day, that's where the best thermals are. Rolf (not a RSG, just guessing) |
#58
On Mon, 29 Dec 2003 02:02:43 GMT, "Casey Wilson"
wrote in Message-Id: : Agreed. Circling direction is more often dictated by other gliders in the thermal than meteorological phenomena and physics. The protocol I was taught was that unless you are first into the thermal, you follow the left or right pattern of the gliders already there. I've never had a preference of right or left. I was taught to turn into whichever wingtip went up. Turning into the rising wing is intuitive, and logical. I'm only able to think of a couple of alternative techniques, but I would expect neither of them to provide superior results. I was also taught that the most efficient technique, that is the highest rate of altitude gain, is in a 45-degree bank turn hopefully "coring" the thermal. That is consistent with what has been written in the past in this newsgroup concerning the optimum bank in a turn-back to the airport maneuver. Up here in the Mojave Desert flying out of IYK, I've been in a couple of 10 Knot thermals but 5 to 6 is the most common. I can't ever remember any kind of cyclonic rotation of any of them. That said, I did once, inadvertantly fly into a dust-devil. I NEVER want to do that again. If I had seen any dust indication that it was there I would definitely have avoided it in the first place. My soaring experience was also in the Mojave Desert, Antelope Valley area around El Mirage and toward the east and west of there. In the summer, dust-devils were as plentiful as columns at the Forum. They visibly marked areas above which the chance of encountering lift was virtually assured. I'd be interested in hearing more about your dust-devil encounter. |
#59
The few I've seen have always been at very low angles, focusing on
vertical development. I've not yet seen anything shot from directly below. Shawn Curry wrote in message hlink.net... Chris OCallaghan wrote: Most people can't see a minute hand moving, but it moves nonetheless. It's a matter of patience. The problem with observing cloud rotation is that the cloud is constantly changing shape, therefore you cannot time lapse the same way you can when observing vertical development (or determining that a minute hand moves). As noted in my impolite post, you need to spend a half hour on your back. Then we can move on to discussing whether there's any real advantage to be had. I've seen several time-lapse videos of cu. Never noticed (or had pointed out) any rotation. I have seen mesocyclone footage. Very cool. Do you know of any web sites with a clip showing this? Cheers, Shawn |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Dover short pilots since vaccine order | Roman Bystrianyk | Naval Aviation | 0 | December 29th 04 12:47 AM |
[OT] USA - TSA Obstructing Armed Pilots? | No Spam! | Military Aviation | 120 | January 27th 04 10:19 AM |
[OT] USA - TSA Obstructing Armed Pilots? | No Spam! | General Aviation | 3 | December 23rd 03 08:53 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
