#51
At 01:42 30 January 2004, Mark James Boyd wrote:
In article , Todd Pattist wrote: As a matter of interest, how did you handle the request to demonstrate a 'no airbrakes' landing where you needed a forward slip on both base and final? Did you bring the rudder fully through to the opposite side (inside of the turn) to intersperse a coordinated turn between your forward slips? Yep. Exactly. I've used slips in taildraggers extensively, during no-flap demonstrations, and on lots of checkrides. Always interspersed a coordinated turn. Kinda funny to write it here now that I think about it. Just something I haven't done before, I can't really explain why... Ah, power planes, not gliders! Do you not think perhaps we should be differentiating between rudder usage in power plane, and a glider? I started flying originally in gliders, so I dont have any bad habits from power flying, and when I fly powered aircraft, i cant help but fly coordinated all the time. I know that power pilots who make the transition to gliders quite often make fundemental errors due to the power mindset when sat in a glider. What do you think? |
#52
At 07:00 30 January 2004, Marc Ramsey wrote:
Pete Zeugma wrote: We discovered that there was some packaging that prevented the full travel of the airbrake. What do you mean by 'some packaging'? cant remeber the exact details, but it was either packing or a spacer in the control rods at the wing root or in the rods for the airbrake handle. Give val at our club an email (london gliding club) and ask her to get the workshop to give you further detail. After this was removed from our duo it was much better and we no longer have to do side slipping finals. Before this I always thought that the blades did not appear to be fully clear of the wing slot. |
#53
![]() "Marc Ramsey" wrote in message ... Eric Greenwell wrote: If I understand this right: 1) you are coming down more steeply at 70 knots than you did at 60 knots, but it's still not steep enough; 2) and that's because at Truckee, you want to come in _very_ steeply over/near the threshold to avoid the downwash off the end; 3) and at 80 knots, the descent would be steep enough, but you'd be stopping wwaaayyy at the other end. You've got it. The spoilers don't provide a lot of drag, so it takes a bit of distance to burn off the extra 10 to 20 knots before making a normal touchdown. You can fly it on and hit the fine hydraulic brake, but then it will slam down on the nosewheel, making your partners nervous... I've only made a couple of landings at Truckee, so I'm trying to picture the situation. For those who don't know, gliders at Truckee (near Lake Tahoe, elevation 5900 feet) normally use runway 19, which features a cliff-like drop off at the threshold. In the afternoons, the winds are often between 15 and 30 knots right down the runway, which sets up an interesting rotor-like condition just before the threshold, resulting in big sink and a significant wind gradient. We normally try to arrange things on windy days so the turn from base to final is over the numbers. But sometimes, circumstances prevent that, like a Skyhawk put-putting along on final, in which case you want lots of extra energy. Let me just say, if you ever find yourself below the threshold of 19, *push*, then pull at the last moment, and if you're lucky, you'll end up making a very low energy landing right on the numbers... Marc You might mention there are three turnouts (or at least there were). My first landing there, I radioed I'd take the first, but ended up taking the third due to high altitude energy and poor wheel brake;^) Furthermore, there's been more than one incident there. It is better to be high and hot than the alternative. Rocks is hard. Still, a lovely place to fly. Frank Whiteley Colorado |
#54
![]() "Pete Zeugma" wrote in message ... At 04:30 30 January 2004, Marc Ramsey wrote: For those who don't know, gliders at Truckee (near Lake Tahoe, elevation 5900 feet) normally use runway 19, which features a cliff-like drop off at the threshold. How long is your runway? Club I fly fairly often at in Scotland, Deeside GC (Aboyne), has quite wonderful rotor/curlover/wind shear right down to the deck in strong southerlies. It has two thin (5m and 7m ish) parallel runways about 500m long (all figs approx) situated between two ridgelines. There are two windsocks either side of the runways, and in these strong southerlies the socks are generally pointing in opposite directions. I've had many a fast landing there in these conditions, 80-90knots is quite typical. It is common practice to run on all the way to the end of the runway, to keep it clear at all times. Of course, what you forget to mention is that these are airspeeds, not ground speeds. Landing a glider at 90knots ground speed is very exciting! When I flew at Aboyne, there was only one runway, a gravel pit at one end, and stone fence at the other. Landing with rotor over the airfield was _really_ interesting as the ASI didn't settle until about 5 feet off the deck, swinging 30-70kts all the way downwind, base, and final. Radios were important. The one sod with the broken radio flew a right hand circuit when all others were flying left. He ( Open Diamant ) landed behind RAF L-13 (land long!) and in front of K-8(land short!). All three touched down at the same moment and only just behind me. However, four wave flights in a week and Gold altitude (4000ft cloud climb included). What a treat, including the low-levels by the Buccaneers and Jaguars! Frank Whiteley Colorado |
#55
F.L. Whiteley wrote:
You might mention there are three turnouts (or at least there were). My first landing there, I radioed I'd take the first, but ended up taking the third due to high altitude energy and poor wheel brake;^) Use of the first turnout by gliders is now actively discouraged, due to the potential for taking out a towplane or glider in the tie-down area. The second one has been expanded, which is quite helpful. The third one is there, and I use it when necessary, but it is not possible to clear the runway without getting out and pushing. Furthermore, there's been more than one incident there. It is better to be high and hot than the alternative. Rocks is hard. Indeed. Still, a lovely place to fly. That it is. Marc |
#56
At 14:48 30 January 2004, Todd Pattist wrote:
Pete Zeugma wrote: Before this I always thought that the blades did not appear to be fully clear of the wing slot. When blades are fully clear of the wing slot, you have to be certain that air loads will not flex them sufficiently to prevent them from re-entering the wing slot. Thats probably why there is a placarded max rough air speed! Personally I dont touch them above this, unless I am flying in known icing conditions where i crack them open every now and then to make sure they have not frozen (at a speed less than max rough air) I presume the modification you made (if that's what it was) was in accordance with factory recommendations. The problem here was that there was something left in by the manufacturer that prevented full travel. The offending item (which I cant remember exactly) was removed in consultation with Schempp-Hirth by our workshop. I know some Grobs had this problem, and the fix was to limit airbrake throw specifically to prevent the blades from clearing their slots, thereby ensuring they could not lock the brakes open. The problem here was about inefectual power in the brakes as they did not open sufficeintly enough (i think ours only open half their designed throw) hence Marc saying he has to side-slip to get a good decent rate with full brake open. |
#57
Todd Pattist wrote:
... A skidding turn, as you described is the opposite of a slipping turn. The student needs to be taught the difference. If he is doing a slipping turn, the yaw string will be out of the turn, if he's skidding it will be inside the turn. ... This terminology is or was source of a lot of discussions and misconceptions also in France where 2 equivalent terms exists, "glissade" for slip, "dérapage" for skid. So the team responsible for deciding the method and terminology that should be used by all glider instructors decided, after some discussion, that only one term should be used, "dérapage" was the choosed one. During a turn, a slip should be called "dérapage intérieur" (inside skid), a skid "dérapage extérieur" (outside skid). In straight line we speak of "dérapage à gauche" (skid toward left side) or "dérapage à droite" (skid toward right side). This has the advantage of uniformity, any case where the string is not in the middle is called by the same name and the further qualification (inside, outside, left, right) always indicate the side from which the relative wind is coming and the string is going away. |
#58
Pete Zeugma wrote: Before this I always thought that the blades did not appear to be fully clear of the wing slot. When blades are fully clear of the wing slot, you have to be certain that air loads will not flex them sufficiently to prevent them from re-entering the wing slot. Dug out a photo i took on decent in the discus I fly so you can see the extent of full travel of a schempp-hirth airbrake. The blades are clear of the slot, as designed to be. http://uk.f2.pg.photos.yahoo.com/ph/...l?.dir=/glidin g&.dnm=Save0018.jpg link should work, hopefully! I presume the modification you made (if that's what it was) was in accordance with factory recommendations. I know some Grobs had this problem, and the fix was to limit airbrake throw specifically to prevent the blades from clearing their slots, thereby ensuring they could not lock the brakes open. Todd Pattist - 'WH' Ventus C (Remove DONTSPAMME from address to email reply.) |
#59
Judy Ruprecht wrote:
See the US Private & Commercial Glider Practical Test Standards, Area of Operation IV on landings, Task R, Slips to Landings. See also the Soaring Flight Manual and its new FAA-published successor (whose name escapes me). Judy Can't you just reduce the throttle and then desc... Hey WAIT A MINUTE!?!? ....there it is, big as can be, "TURNING SLIPS TO A LANDING"! right there in the PTS. I coulda read it 200 times and never actually seen it. This ain't in that darned airplane PTS. And it wasn't in my training, and it wasn't on any of my checkrides. But now I'll practice and teach it. This is one more tool in my toolbox. Thanks! |
#60
Pete Zeugma wrote:
Ah, power planes, not gliders! Do you not think perhaps we should be differentiating between rudder usage in power plane, and a glider? I started flying originally in gliders, so I dont have any bad habits from power flying, and when I fly powered aircraft, i cant help but fly coordinated all the time. I know that power pilots who make the transition to gliders quite often make fundemental errors due to the power mindset when sat in a glider. What do you think? Absolutely there are subtle differences that get overlooked. Primacy is a factor here. Use of spoilers, wheel brake not at the feet, no stall horn, can't use throttle to descend, actually seeing adverse yaw, etc. All these were probably much harder to learn (unlearn) than if one started as a glider pilot first. And the whole idea of energy management for rollout and taxi was completely new, and the one wheel thing and possibility of groundloop, etc. etc. etc. Absolutely there are bad habits from transition. And catching all of them is unlikely without additional study by the student or new pilot. Instruction and experience only go so far...study and discussion for me seem to take it that extra step... Cheers! Mark |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Puchaz Spinning thread that might be of interest in light of the recent accident. | Al | Soaring | 134 | February 9th 04 03:44 PM |
Puch spin in | Mike Borgelt | Soaring | 18 | January 24th 04 09:29 PM |
Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 01:35 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
