#51
On Sun, 31 Oct 2004 15:51:07 +0100, Stefan wrote:
Olfert Cleveringa wrote: At least for this part of Europe, I think a Diesel in a Robin-like airframe would be a very nice replacement. I don't think so, there are better solutions. This year, in Switzerland, we've carried out serious experiments with those new ultra lights as tow planes, with the allowance and under the supervision of the FOCA. The results were unexpected and spectacular. (For our American friends: I'm not speaking of those flying lawn-movers, but of the new high tech airplanes rated as Ultra Lights in Europe. Look at http://www.remos.com/ and http://www.lightwing.ch/ for two examples.) As I said, the results were astonishing. Powered with a 100 hp Rotax engine, they performed as well if not better than a typical "classic" 180 hp towplane! Even a heavy two seater on wet grass wasn't a problem! Start roll was even shorter, the noise level was much lower (important in Europe), and all with a gas burn of 12l/h instead of 40l/h. (Or similiar, I don't have the exact numbers handy.) Even when high tows lasted a little longer (i.e. 15 instead of 12 minutes), they were much cheaper. We discussed why those planes would perform so well with only 100 hp. We think, there are mainly two reasons. First, as the name says, they are very light. It makes a difference whether the plane weights 1000 kg or 400. Then, "traditional" airplanes fly way too slowly on tow. They are operated far away from their best climb speed, while those ultralights are operated very near best climb speed. But for whatever reason, in Switzerland it is common belief now that those ultra lights are the future of towing. Stefan Stefan, Have they done any tests at high altitude airfields ? My memory of Swiss gliding fields is that they are in valleys, with reasonably low altitude. If I am wrong, please correct me, as my knowledge is fragmentary regarding your lovely country. We have discussed ultralight tow planes, but the consesus seems to be that with high temperatures (40 C is not at all uncommon) the high density altitude will reduce the performance to an unacceptable level. I have also heard some rumours that the high speed Rotax engines don't take kindly to the extended full power operation necessary when towing, and the lifetime is shortened. Can you comment on this please ? Cheers, John G. (Victoria, Australia) |
#52
John Giddy wrote:
Have they done any tests at high altitude airfields ? How high is high enough? Is a 800 meter paved runway at 1328 m (4354 ft) altitude high enough? I took off in a Janus last summer there behind an ultralight. It wasn't 40°C, though. ... regarding your lovely country. You may spare the flattery, I'm not American. ;-) We have discussed ultralight tow planes, but the consesus seems to be that with high temperatures (40 C is not at all uncommon) the high density altitude will reduce the performance to an unacceptable level. We've discussed it, too, and all experts said that it wasn't possible. The experiments showed it was. If you want to know, you must do the experiments in the conditions which are important to you. No way to know otherwise. I have also heard some rumours that the high speed Rotax engines don't take kindly to the extended full power operation necessary when towing, and the lifetime is shortened. Can you comment on this please I've heard all kinds of rumours. No, I can't comment on the lifetime of Rotaxen, sorry. Stefan |
#53
At 00:24 01 November 2004, John Giddy wrote:
........ Stefan, Have they done any tests at high altitude airfields ? My memory of Swiss gliding fields is that they are in valleys, with reasonably low altitude. If I am wrong, please correct me, as my knowledge is fragmentary regarding your lovely country. We have discussed ultralight tow planes, but the consesus seems to be that with high temperatures (40 C is not at all uncommon) the high density altitude will reduce the performance to an unacceptable level. I have also heard some rumours that the high speed Rotax engines don't take kindly to the extended full power operation necessary when towing, and the lifetime is shortened. Can you comment on this please ? Cheers, John G. (Victoria, Australia) John, talk to the South African guys here. At Gariep Dam they use a Samba (Rotax engined microlight) for towing and that is 4000+ft and hot. http://www.gariepgliding.com/airfield_data.htm#space http://aeroklubuo.macroware.cz/Lambadaen.html |
Recruiting students from current student | BoDEAN | Piloting | 3 | April 14th 04 02:31 PM |
For Any East Coast Aero Students / Graduates | Robert11 | General Aviation | 0 | February 3rd 04 12:10 AM |
FAA Investigates American Flyers | SFM | Instrument Flight Rules | 57 | November 7th 03 09:33 PM |
FAA Investigates American Flyers | SFM | Piloting | 64 | November 7th 03 09:33 PM |
Using Excel/Access for your student's records | BoDEAN | General Aviation | 0 | September 29th 03 01:47 AM |
