Tow plane types/mods for high density altitude glider towing
Old August 13th 19, 02:38 AM posted to rec.aviation.soaring
son_of_flubber
Default Tow plane types/mods for high density altitude glider towing
What are your favorite aircraft types (and modifications) for glider towing in high density altitude and/or short runways?
Old August 13th 19, 02:56 AM posted to rec.aviation.soaring
Ag-Cat with Wasp Jr.!
Old August 13th 19, 03:58 AM posted to rec.aviation.soaring
JS[_5_]
Jerry Marshall's 400HP Brave!
He never did get the turbine Brave ready for towing.
Old August 13th 19, 03:15 PM posted to rec.aviation.soaring
Dan Marotta
A 300-hp Ag Wagon works just fine at 9,500' density altitude.Â* Quite
comfortable for the tow pilot, too!
Dan, 5J
Old August 13th 19, 07:22 PM posted to rec.aviation.soaring
Bob Youngblood
Dan, 5J
Our situation here in Florida is quiet different because of our MSL. I have a Pawnee with 180 hp. It does very well for the most part. I also have a 235 Pawnee that is certainly more powerful, but After all is said I would rather have the 180 Pawnee for my personal use. We call it the Yellow Gorilla, and it has done a great job for our club.
Old August 13th 19, 04:01 AM posted to rec.aviation.soaring
AS
I fly a heavy two-seater and have been towed in hot/high locations (DA around 10k') behind a Pawnee 235, CallAir A9, C188 AgWagon and a C185 SkyWagon. All four did a reasonable job with the C188 being the best. I think the Pawnee and definitely the two Cessnas had a constant speed prop and did actually better than the CallAir, which I was told had the most HP. I have no idea if any one of them had turbo-charged engines. A low wing, constant speed prop and lots of uumph seems to be the winning combination.
Uli
'AS'
Old August 13th 19, 03:21 PM posted to rec.aviation.soaring
Dan Marotta
Uli,
It sounds like you're talking about Moriarty.Â* The Pawnee has 260 hp and
a CS prop, the Call Air has 290 hp and a fixed pitch prop, and the Ag
Wagon has 300 hp and a constant speed prop.
The Call Air, with its 94" prop is the noisiest of the bunch with its
supersonic tip speed, but most of the tow pilots don't reduce RPM on the
other two after getting safely airborne, resulting in about as much
noise.Â* I hate to think of all those 10-15 minute tows at full RPM.Â* I
wonder if the 5-minute limit is for RPM or for max power (which isn't
available at our altitudes).Â* When I was towing, I always reduced RPM
after we were both established in climb and I never got any complaints
from glider pilots.
Uli
'AS'
Dan, 5J
Old August 13th 19, 06:27 PM posted to rec.aviation.soaring
AS
On Tuesday, August 13, 2019 at 10:21:41 AM UTC-4, Dan Marotta wrote:
Uli,
from glider pilots.
Uli
'AS'
Dan, 5J
Yep - and Montrose, CO behind a beautiful C185. :-)
Uli
'AS'
Old August 13th 19, 06:39 PM posted to rec.aviation.soaring
And the best towplane "modification" is a highly competent pilot in the tug.
Old August 13th 19, 04:04 AM posted to rec.aviation.soaring
Papa3[_2_]
They used to have 450hp Stearman at Stroudsburg. It wasn't a tow so much as being dragged vertically into the air.
P3
Perlan High Altitude Tow Plane Frank Whiteley Soaring 32 August 25th 18 01:32 PM
Martin B-57 Canberra pics [19/20] - NASA High Altitude Plane.jpg (1/1) Miloch Aviation Photos 0 August 26th 16 12:34 AM
High Altitude simulator accuracy in X-Plane Ghazan Haider Simulators 2 August 16th 05 06:01 PM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 10:48 AM
