I can use my Oudie or my Clearnav vario for final glide.
Lately my CNv final glide is 400 feet lower than my Oudie. The Oudie is right. All the setting are the same. I cant correct the CNv. Any idea from other CNv user? Gilles |
Glad nobody died....’final glide’.
Have you checked/compared all the adjustable parameters? Polars, ballast, bugs, units, winds, QNH, etc. R |
On Sunday, September 22, 2019 at 5:18:47 AM UTC-7, wrote:
Glad nobody died....’final glide’. Have you checked/compared all the adjustable parameters? Polars, ballast, bugs, units, winds, QNH, etc. R Also could be margin height, and if the CNv is set up for total energy arrival height (including a pull-up from cruise). Jim |
Le dimanche 22 septembre 2019 07:48:02 UTC-4, s6 a écritÂ*:
I can use my Oudie or my Clearnav vario for final glide. Lately my CNv final glide is 400 feet lower than my Oudie. The Oudie is right. All the setting are the same. I cant correct the CNv. Any idea from other CNv user? Gilles Thank you Margin height is set at 1000 feet. Vario behave as if set at 600 feet. Check all setting, nothing change???? Gilles |
Have you confirmed for each whether or not they are using total energy arrival height, ie including the expected height recovery from pull up to best glide height? That could easily account for a difference of 400 feet.
Is the difference a fixed value regardless of distance to go, rather than a percentage? Have you checked whether the elevation of your arrival airfield is set the same in both devices? |
On Monday, September 23, 2019 at 6:55:24 PM UTC-4, waremark wrote:
Have you confirmed for each whether or not they are using total energy arrival height, ie including the expected height recovery from pull up to best glide height? That could easily account for a difference of 400 feet. Is the difference a fixed value regardless of distance to go, rather than a percentage? Have you checked whether the elevation of your arrival airfield is set the same in both devices? It's either a user set up or database problem. There's no other likely possibility. OT... but using a preset margin is sooooo 1986. Set the margin to zero and let the device tell you your predicted arrival height. If you don't like the numbers you see, do that PIC thing.... T8 |
On Monday, September 23, 2019 at 4:46:00 PM UTC-7, Tango Eight wrote:
On Monday, September 23, 2019 at 6:55:24 PM UTC-4, waremark wrote: Have you confirmed for each whether or not they are using total energy arrival height, ie including the expected height recovery from pull up to best glide height? That could easily account for a difference of 400 feet. Is the difference a fixed value regardless of distance to go, rather than a percentage? Have you checked whether the elevation of your arrival airfield is set the same in both devices? It's either a user set up or database problem. There's no other likely possibility. OT... but using a preset margin is sooooo 1986. Set the margin to zero and let the device tell you your predicted arrival height. If you don't like the numbers you see, do that PIC thing.... T8 snip "OT... but using a preset margin is sooooo 1986" I beg to disagree with you sir. This is YOUR preference and opinion and maybe other's too and that is ok... but, using a safety margin is strictly a personal preference of others and no it does not go out of style like you so imply above.. |
On Monday, September 23, 2019 at 8:54:25 PM UTC-4, 6PK wrote:
On Monday, September 23, 2019 at 4:46:00 PM UTC-7, Tango Eight wrote: On Monday, September 23, 2019 at 6:55:24 PM UTC-4, waremark wrote: Have you confirmed for each whether or not they are using total energy arrival height, ie including the expected height recovery from pull up to best glide height? That could easily account for a difference of 400 feet. Is the difference a fixed value regardless of distance to go, rather than a percentage? Have you checked whether the elevation of your arrival airfield is set the same in both devices? It's either a user set up or database problem. There's no other likely possibility. OT... but using a preset margin is sooooo 1986. Set the margin to zero and let the device tell you your predicted arrival height. If you don't like the numbers you see, do that PIC thing.... T8 snip "OT... but using a preset margin is sooooo 1986" I beg to disagree with you sir. This is YOUR preference and opinion and maybe other's too and that is ok... but, using a safety margin is strictly a personal preference of others and no it does not go out of style like you so imply above.. It was dumb in 1986 too :-). No one arrival height covers all situations. T8 |
I can use my Oudie or my Clearnav vario for final glide. Lately my CNv final glide is 400 feet lower than my Oudie. The Oudie is right. All the setting are the same. I cant correct the CNv. Any idea from other CNv user? Gilles I fly at a busy and some time very busy airfield, so 1000 feet is my arrival height. Still stuck with a faulty CNv!!! Gilles |
On Tuesday, September 24, 2019 at 10:07:43 PM UTC-4, s6 wrote:
Le dimanche 22 septembre 2019 07:48:02 UTC-4, s6 a écritÂ*: I can use my Oudie or my Clearnav vario for final glide. Lately my CNv final glide is 400 feet lower than my Oudie. The Oudie is right. All the setting are the same. I cant correct the CNv. Any idea from other CNv user? Gilles I fly at a busy and some time very busy airfield, so 1000 feet is my arrival height. Still stuck with a faulty CNv!!! Gilles If/when you get serious about figuring this out, you will be doing one of calling Rex, emailing me or providing more information on the ClearNav forum (which I monitor). Evan Ludeman |
Clarence See....final glide | Gregg Leslie[_2_] | Soaring | 2 | December 27th 12 09:52 PM |
Final glide | ppp1 | Soaring | 8 | January 6th 11 02:21 PM |
Final Glide | Roy Clark, \B6\ | Soaring | 1 | December 23rd 10 04:45 PM |
Stretching the Final Glide | vontresc | Soaring | 25 | December 16th 09 10:50 PM |
Final Glide - JD (US) | Roy Clark, B6 | Soaring | 1 | September 19th 07 07:17 AM |
