Oudie gear warning?
Old March 31st 20, 06:51 PM posted to rec.aviation.soaring
Default Oudie gear warning?
Hey all - I just acquired an original Oudie and I have noticed a gear warning in the profile setup. Not mentioned in the manual and the previous 2 owners do not know about it. I have not noticed it trying to get my attention in the pattern either. I will ask Naviter next unless youze can fill me in.
Old March 31st 20, 06:57 PM posted to rec.aviation.soaring
MNLou
You are welcome!
I am one of many who exhorted Naviter to add an altitude based gear warning. It was included in an update, I believe, at the beginning of last year.
It is based on your AGL - about 200m / 660 ft. It knows where you are and it knows the ground level where you took off. If A = B, you get the warning.
It also has a gear warning at altitude to make sure you are "gear up". I can't remember what the logic is behind that. Circling I think.
Anyway, a very useful reminder in the pattern.
Lou
Old March 31st 20, 07:09 PM posted to rec.aviation.soaring
Thanks, I will see if I notice anything.
Old March 31st 20, 08:26 PM posted to rec.aviation.soaring
Scott Williams[_2_]
On Tuesday, March 31, 2020 at 12:57:38 PM UTC-5, MNLou wrote:
You are welcome!
Lou
Is this function added to an IGC with an update?
Scott
Old March 31st 20, 08:57 PM posted to rec.aviation.soaring
Scott Williams[_2_]
You are welcome!
Lou
Scott
Got it, If only I would read the posts in order,
Thanks for the heads up!!
Scott
Old April 1st 20, 05:32 PM posted to rec.aviation.soaring
Dennis Cavagnaro
Where in the settings screens is the gear warning? I don’t have a page that says Profile.
DC
Old April 1st 20, 05:41 PM posted to rec.aviation.soaring
Scott Williams[_2_]
DC
turn on, see you mobile, menu button, settings, next, next, next, misc,
Middle of screen, "before landing... check landing gear
Oudie IGC version 9.17.00 on mine,
Good luck
Scott
Old April 1st 20, 11:12 PM posted to rec.aviation.soaring
NG[_2_]
Old April 6th 20, 03:06 PM posted to rec.aviation.soaring
I finally heard back from Naviter, they confirm it is visual only. Not worth the code! I don't think I will be making the Oudie part of my scan below pattern altitude.
Old April 6th 20, 04:53 PM posted to rec.aviation.soaring
MNLou
Hmmm - that brings up an interesting situation. I am definitely getting an audio warning in addition to the banner warning on the Oudie.
I've got a Flarm - S8 - Oudie set up. Perhaps the audio warning is coming from the S8? I was pretty sure it was coming from the Oudie but if Naviter says not so??????
Lou
Cessna 172 gear warning Paul Kassel Owning 0 March 27th 17 04:29 PM
Gear Warning Gadget Guy Soaring 118 November 30th 05 10:43 PM
Gear Warning Gordon Schubert Soaring 11 November 22nd 05 03:27 AM
Gear Warning Gordon Schubert Soaring 0 November 18th 05 08:22 PM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 08:33 AM
