Fatal Towplane Accident 5-9-20
Old May 13th 20, 01:43 AM posted to rec.aviation.soaring
Default Fatal Towplane Accident 5-9-20
Your strapped in, closed up, checklist complete, hooked up.............then something stops the launch! It’s hot inside your closed up cockpit and it looks like a several minute delay, so you open up the canopy. How can you insure you latch the canopy again?
Here’s a little trick I’ve used for 48 years....................leave your hand on the canopy latch! May be a little uncomfortable, but your hand on the canopy latch is there to remind you that something must be done, before you are once again READY FOR TAKEOFF.
Just my .02 cents,
JJ
  #52
Old May 13th 20, 01:55 AM posted to rec.aviation.soaring
John I like that little trick
Dan
  #53
Old May 13th 20, 02:05 AM posted to rec.aviation.soaring
2G
Just my .02 cents,
JJ
What part of my solution didn't you guys understand? There's a fairly simply technological solution that circumvents human failings, and that is an automatically actuated tow release. Professional airline pilots which have two pilots in the cockpit with electronic checklists still screw up. If that's the solution I guarantee that towplane upsets will continue to happen.
The tow pilot is in a very vulnerable situation: he/she is totally dependent upon the correct performance of the glider pilot. One towplane upset accident is one too many.
Tom
  #54
Old May 13th 20, 02:13 AM posted to rec.aviation.soaring
Just my .02 cents,
JJ
Tom
Since you seem to have the problem solved, it seems that you have a real opportunity to create a product that will be in demand.
Maybe the first place to start would be a functional specification.
Go for it.
UH
  #55
Old May 13th 20, 02:14 AM posted to rec.aviation.soaring
Great. Design it, build it, test it and get it approved. How hard could it be?
Put up or....
  #56
Old May 13th 20, 02:29 AM posted to rec.aviation.soaring
2G
Put up or....
Yeah, sure. Just send me a million bucks and I will get right on it!
Tom
  #57
Old May 13th 20, 03:11 AM posted to rec.aviation.soaring
Duster[_3_]
Just my .02 cents,
JJ
Jeeeesh.. that suggestion wasn't worth the full 0.2cents; here's a penny rebate back. Take your low-tech ideas somewhere else, like the flat-earth society who'll appreciate numskull ideas. You take us for a bunch of idiots?
...... Okay, well, actually that sounds like a simple, workable solution. We use it on the flap handle when thermalling; a reminder to go neutral or negative when leaving the lift. Any simple ideas to keep us from stall/spinning in?
  #58
Old May 13th 20, 03:36 AM posted to rec.aviation.soaring
Tom
But, but, you said it was simple!
Ideas are cheap. Implementation is a bit more difficult.
Your time isn't worth a million bucks. Your ideas, without the fortitude to back them up are worthless.
  #59
Old May 13th 20, 04:03 AM posted to rec.aviation.soaring
2G
Tom
Mark,
I don't have a dog in the fight: I fly a motorglider: no towplane, no tow pilot, no kiting. And I certainly don't have a towplane. I AM NOT going to develop something for which I have no use. But I AM a degreed graduate engineer and can offer advice for those that wish to take on such a project.
Tom
  #60
Old May 13th 20, 04:43 AM posted to rec.aviation.soaring
Whoopee for you. If you aren't going to develop it, and you have "no dog in the fight," quit pontificating about what somebody else "should do."
Once again, put up or....
I assume your advice will be free to those who wish to take advantage of your genius, as your opinions are so freely offered.
Towplane-Baron accident Jp Stewart Soaring 58 June 11th 18 10:03 PM
Fatal accident in Scotland Ian Soaring 51 September 6th 07 10:55 AM
Another fatal accident Mike the Strike Soaring 0 September 20th 06 11:50 PM
Fatal accident in Italy 2cernauta2 Soaring 1 April 4th 06 05:50 PM
Hawaii Fatal Accident Rocky Rotorcraft 0 July 25th 03 03:01 PM
