COBRA Anti-Sway Coupler
Old September 3rd 20, 07:00 PM posted to rec.aviation.soaring
Default COBRA Anti-Sway Coupler
Anybody have experience in using this? Would it help towing a COBRA trailer with a small car?
Old September 3rd 20, 07:34 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Define 'small car'. Cobra and Avionic trailers are like a rock behind my VW Golf TDI Wagon (relatively small car).
Old September 3rd 20, 08:40 PM posted to rec.aviation.soaring
Small car as in a 2015 VW GTI
Old September 4th 20, 12:39 AM posted to rec.aviation.soaring
I've installed three or four of these on Cobra trailers. Very well made and nicely designed. I put them on both single place and two seat glider trailers. They are pretty effective at controlling sway, even though the customers all tow with full-size pickups or SUVs. It definitely helps when towing with a short wheelbase vehicle.
I can't say how effective they are with something like a VW Golf, (but I consider that to be too small to tow a glider anyway. Maybe the wagon, with the longer wheelbase will work better.) I know they tow with tiny vehicles in Europe, but the glider trailers all have an 80 kph limit over there. Here in the US, 75 mph freeway speeds, crosswinds and passing eighteen wheelers are going to make towing a pretty "sporty" adventure. Keep an eye on the rear view mirror. If the trailer changes lanes, try to stay in front of it ;-)
You do have to use an actual 50 mm ball. A two inch ball is too big for the clamping action and 1 7/8" is too small. Remember that it's unlikely that anyone else will be able to tow your trailer unless they also have a 50 mm ball. Order an un-plated (stainless steel) ball if possible. Chrome plating has a tendency to start flaking off under the clamping loads while turning.. Lubrication is NOT permitted, as it negates the clamping friction that controls sway. Another issue is making sure the ball CANNOT turn and loosen the nut! No matter how much torque you put on the nut, it can still get loose. In Europe, the ball must be welded to the hitch plate. I usually machined a flat spot on the base of the ball just above the threaded shank and welded a piece of steel bar stock to the hitch plate.
Hope this helps.
Old September 4th 20, 01:43 AM posted to rec.aviation.soaring
2G
You do have to use an actual 50 mm ball. A two inch ball is too big for the clamping action and 1 7/8" is too small. Remember that it's unlikely that anyone else will be able to tow your trailer unless they also have a 50 mm ball. Order an un-plated (stainless steel) ball if possible. Chrome plating has a tendency to start flaking off under the clamping loads while turning. Lubrication is NOT permitted, as it negates the clamping friction that controls sway. Another issue is making sure the ball CANNOT turn and loosen the nut! No matter how much torque you put on the nut, it can still get loose. In Europe, the ball must be welded to the hitch plate. I usually machined a flat spot on the base of the ball just above the threaded shank and welded a piece of steel bar stock to the hitch plate.
Hope this helps.
80 kph is about 50 mph. Do that on Nevada's 80 mph freeways and they will be scraping you off some 18-wheeler's grill guard.
Tom
Old September 4th 20, 02:19 AM posted to rec.aviation.soaring
AS
Hope this helps.
Tom
Most modern trailers are exempt from the 80 km/h limitation and are allowed to go 100 km/h. Still not the speed some 18-wheelers do here but a big improvement for the German Autobahn.
Uli
'AS'
Old September 4th 20, 02:12 AM posted to rec.aviation.soaring
Andrzej Kobus
Hope this helps.
Mark, very informative, great post.
Old September 7th 20, 11:10 PM posted to rec.aviation.soaring
GliderCZ
Hope this helps.
I believe it may be important to get a "high profile" ball. These have more clearance between the bottom of the ball and the hitch plate. The anti-sway friction coupler itself is broader across than the typical non-friction coupler, so may hit the hitch plate when the trailer tilts to the side relative to the tow vehicle.
Old September 7th 20, 11:31 PM posted to rec.aviation.soaring
Valid point, but, so far I have not seen any interference issues. Of course, I have only used these on receiver hitches. The hitch plate is only slightly wider than the base of the ball. If it was on a flat, wide surface (like a bumper mount) you might have clearance issues if the vehicle tilts significantly relative to the trailer (or vice versa). I believe the AlKo documentation specifies permissible limits on the angles involved.
Also, many receiver hitches have a significant amount of play between the inserted hitch tube and the receiver. This "slop" can exacerbate sway. I recommend any of these to remove the play:
https://www.etrailer.com/s.aspx?qry=..._Anti%7eRattle
Old September 7th 20, 01:55 PM posted to rec.aviation.soaring
Aldo Cernezzi
I've been towing an Arcus M in Cobra trailer for years, using a compact Ford C-max 1.6 TDCI. Speed limit in Italy is 80kph on highways. Occasionally (as in France where it's legal, let's say), I drove at 125 kph or higher with no problems at all. One must be experienced and use the steering wheel with extreme care. Overtaking semitrailer trucks (they actually drive not any faster than 85 kph GS) requires careful planning and... some cool blood.
please not that European towing bars (except maybe in UK) are very expensive at about 1800 USD with installation, they come to the market only after certification, are installed by few authorised stations, and require a technical inspection by the national authorities before you can hitch anything to it. I've never seen a tow ball coming off a vehicle, not even after 30 years in service.
AFAIK, chains are prohibited in Italy and Europe, as any other accessories which may cause injuries to pedestrians.
ciao,
Aldo Cernezzi
www.voloavela.it
trailer sway mitigation TSM princiar[_2_] Soaring 67 December 26th 19 05:14 PM
AL-KO Cobra Trailer Coupler Keyhole Slot? OHM Ω http://aviation.derosaweb.net Soaring 8 October 23rd 17 10:59 PM
Dual axle sway glider[_2_] Soaring 7 March 2nd 10 04:36 AM
GS antenna coupler [email protected] Home Built 3 July 19th 05 09:40 AM
trailer sway [email protected] Soaring 14 June 19th 05 09:02 AM
