Class B bust my fault or the controllers ?
Old May 28th 05, 07:39 AM
Antoņio
Default Class B bust my fault or the controllers ?
Today I flew into KBFI (Boeing field) which is class D and has
extentions that underlie the Class B that require close attention to
altitudes and headings so as to stay clear. Today the winds were
favoring 31L (and 31R) and I came in from the west on the Vashon
approach--the most common approach from the west.
I was on a left downwind for 31L and the tower told me I was number
three following an Arrow on about a 2 mile straight in final (Valley
approach?). I acknowledged the traffic, and was waiting for it to come
up on my 9 o'clock before turning base so as to allow enough spacing.
The controller suddenly told me that I was too far south and said
either that I had busted into surface B or was about to. (I never did
clearly hear which).
Unless one turns a fairly close in base here--within about a half mile
or less--you end up in class B surface.
My questions:
1.Assuming I busted B; who is reponsible if the controller asks me to
follow an aircraft that is too far out on a straight in? I mean, I can
reduce speed, s-turn, and the like but I can't turn base until the
aircraft on final is a safe distance away, right?
2.Is the controller supposed to arrange things so that I *can* turn
base and not be in conflict with other aircraft?
3.How would you resolve the problem if it were happening to you ?
Any thoughts would be appreciated...
Antonio
Old May 28th 05, 01:37 PM
My questions:
Antonio
You are always responsible for remaining clear of Class B airspace unless
you receive a clearance to enter Class B airspace. You should be well
aware of the boundaries at a secondary airport like BFI.
Old May 28th 05, 02:05 PM
Doug
Uh, If you are on an IFR flight plan, you don't need to hear "cleared
for Class B". At least that is always the way it has worked for me.
Old May 28th 05, 02:39 PM
Gary Drescher
"Doug" wrote in message
You always need a clearance to be in Class B. But if your IFR clearance
takes you through Class B, then that *is* a clearance to be in Class B, even
if the words "Class B" are not mentioned in the clearance.
--Gary
Old May 28th 05, 03:52 PM
That's correct. But, it doesn't seem this guy was on an IFR flight
plan. I don't find any "Vashon Approach" in my IFR charts for KBFI.
Old May 28th 05, 07:43 PM
Roy Smith
The applicable reg is 91.131(a)(1): "No person may operate an aircraft
within a Class B airspace area except [...] The operator must receive an
ATC clearance from the ATC facility having jurisdiction for that area
before operating an aircraft in that area"
If you are IFR, you have "a clearance". You don't have to specifically be
cleared into the class bravo, you just have to have "a clearance".
Old May 30th 05, 04:20 AM
Guillermo
If you are in IFR clearance you only got to distinguinsh two classes of
airspace: controlled and uncontrolled. You don't need to worry about the
classes of controlled airspace.
Old May 31st 05, 12:35 AM
Well, you do have to worry about equipage to go above FL 240 (DME) and above
290 (RVSM).
Old May 31st 05, 02:09 AM
Guillermo
wrote in message ...
above
290 (RVSM).
I'm not planning on going above FL240 in the C172RG that I fly.
I wish I were flying something that could go that high up
What is RVSM?
Old May 28th 05, 01:44 PM
Howard Nelson
"Antoņio" wrote in message
My questions:
1. Ask the controller to call my base turn.
2. Invest in a Garmin 196 at a minimum
3. File IFR when going into KBFI
4. Not get that close (and boxed in) to class B without permission to enter.
My thoughts in order of preference
Howard
Antonio
Carrying flight gear on the airlines Peter MacPherson Piloting 20 November 25th 04 12:29 AM
World Class: Recent Great News Charles Yeates Soaring 58 March 19th 04 06:58 PM
One Design viability? Stewart Kissel Soaring 41 December 10th 03 03:27 AM
Copyright Š2004-2025 AviationBanter.
