The Swearingen-TEB incident: control issues with twins
Old May 31st 05, 10:54 PM
R.L.
Default The Swearingen-TEB incident: control issues with twins
This is the best latest (Google, 5/31/05, 1700 EDT) on the TEB incident
today.
http://www.northjersey.com/page.php?...ZWVFRX l5Mg==
I heard earlier on NY CBS Radio that the pilot reported "engine trouble" on
approach and that a witness saw the plane making contact with the runway
right-wing-down, almost 90 degrees.
I'm a ASEL primary student. What's the skinny on multi-engine control issues
when one engine fails on approach?
Old May 31st 05, 11:17 PM
My understanding is that the aircraft will tend to roll due to the side
with the failed engine having less lift. My CFI was explaining this to me
some time ago.
Engine failure would require immediate and extreme rudder input and
feathering the props on the failed engine to reduce the drag. He said
something about "Lawn Dart" and that it can happen in a blink of the eye.
issues when one engine fails on approach?
Mike Flyin'8
PP-ASEL
Temecula, CA
http://flying.4alexanders.com
Old June 1st 05, 01:04 AM
Mike Rapoport
some time ago.
Mike Flyin'8
PP-ASEL
Temecula, CA
Maybe someday your CFI will get a multi engine rating and know what he is
talking about.
MU-2
Old June 1st 05, 02:38 AM
Mike 'Flyin'8'
He has multi and ATP.... If you know more then explain... No need for
the negativity without explaination...
On Wed, 01 Jun 2005 00:04:01 GMT, "Mike Rapoport"
some time ago.
Mike Flyin'8
PP-ASEL
Temecula, CA
talking about.
MU-2
Mike Alexander
PP-ASEL
Temecula, CA
See my online aerial photo album at
Old June 1st 05, 04:54 AM
Mike Rapoport
Sorry, I find it difficult to believe that anyone with an ATP or even multi
would say what you attributed to him. Perhaps he was exaggerating? It is
true that an engine loss at *full* power and *low* airspeed requires a lot
of rudder but it is not true that retaining control requires lightning fast
reflexes or that the airplane will become a lawn dart in the "blink of an
eye". It takes most pilots less than 10hrs including the checkride to get a
multi rating so clearly it isn't that difficult or challenging. Naturally,
like anything else there are ways to screw it up. The FAA only certifies
airplanes that can be flown by pilots of "average skill".
As othere have mentioned, losing an engine on approach should be a non
event. There is minimal yaw because the power is set low.
MU-2
ATP
"Mike 'Flyin'8'" wrote in message
me
some time ago.
eye.
Mike Flyin'8
PP-ASEL
Temecula, CA
talking about.
MU-2
Mike Alexander
PP-ASEL
Temecula, CA
Old June 1st 05, 05:45 AM
Mike 'Flyin'8'
On Wed, 01 Jun 2005 03:54:35 GMT, "Mike Rapoport"
Perhaps, or maybe my inexperience and ignorance read that into it...
Either way, what I wrote is exactly the understanding that I walked
away with as an early PP-ASEL student.
It is true that an engine loss at *full* power and *low* airspeed requires a lot
I can see how high power low speed, (such as on climb out) could be
much more dangerous than an engine failure on approach.
Only 10 hours huh... Wow, I may want to check that out. BTW... When
my CFI was talking about this, I thought the lawn dart comment was
kinda funny... in a sick sorta way.
I can't imagine how one could manage to get the airplane so out of
control as to roll it over 180 and nose it in, but I have zero multi
hours too...
Do not know the differences between a single and multi on approach, so
I can not add anything of value. Though you make it sound very
similar to a single in the respect to low power.
Mike Alexander
PP-ASEL
Temecula, CA
Old June 1st 05, 03:04 PM
Matt Barrow
http://www.avweb.com/news/columns/182040-1.html
(References - http://www.avweb.com/news/columns/182041-1.html)
Pelican's Perch #4:
Engine Failure!
May 18, 1998
By John Deakin
Engine failure in a piston twin is no time to be messing with complicated
procedures that some seem to favor. John lays out his straightforward ideas
on how to react to this critical emergency — and explains why in detail.
There's more to it than just "identify, verify, feather" or "dead foot, dead
engine." Once again, the real world requirements that could save your life
may not be well served by some of "the old ways."
File Type: gif clearpixel.gif (43 Bytes, 1 views)
Old June 1st 05, 03:50 PM
An engine loss in a Garrett powered aircraft such as the Swearingen or
MU-2 would be quite noticeable at any power setting.
The Negative Torque Sensor (NTS) on the Garrett TPE331's will dump oil
pressure from the prop dome when the engine flames out. The spring load
on the prop will drive the prop to a high pitch, lower drag
configuration, but does not feather the prop. The pilot must manually
perform this task.
I have been told that in a MU-2 with a four bladed prop, should an
engine quit and the NTS fail, a minimun turn of 90 degress will occur
before the pilot gets the prop feathered. The NTS should be checked
every engine start and is a no go item should it not test properly.
The Searingen Metro, like th MU-2, is a handful of airplane with 2
pilots and 2 engines. One pilot and one engine? ew.......
G. Lee
Old June 1st 05, 04:36 AM
Morgans
Seems to me that if he were close to the field, he should have reduced
throttle on both engines, and put it down, even if it was slightly short of
the runway. Sort it out on the ground.
The old saying is that "a multi with engine failure helps you get to the
scene of the crash, faster," applied in this case. :-(
First rule is "fly the plane." Second rule is "fly the plane."
Old June 1st 05, 05:07 AM
Mike Rapoport
"Morgans" wrote in message
of
I did seem to apply in this case but there is no reason that a turbine multi
cannot be flown on one engine, particularly on approach. There could be
more here than an engine failure. Perhaps a NTS or prop failure.
MU-2
Tactical Air Control Party Airmen Help Ground Forces Otis Willie Military Aviation 0 January 22nd 04 02:20 AM
How much could I get for these back issues? Aaron Smith Home Built 8 December 15th 03 12:07 PM
Flight Simulator 2004 Control Issues SouthBayGuy Simulators 22 November 26th 03 04:31 PM
