Runway ID
Old October 15th 05, 01:14 PM
Lakeview Bill
Default Runway ID
The original poster got it right with his use of the phrase "Runway ID",
because it is, in fact, an ID based on a number, as opposed to some type of
number.
What is the magnetic heading of Runway 5?
If someone is named "Fred", do you refer to them as "Zero Fred"?
The point is, we are dealing with a "name" which consists of a numeral, as
opposed to an actual number.
The runway is NAMED Runway 5. Why would you prepend a zero to a NAME?
Old October 15th 05, 03:54 PM
Daniel L. Lieberman
AIM 4-2-10 "Directions:
Examples
1. (Magnetic course) 005 .....zero zero five
2. (True course) 050.............zero five zero true
The magnetic heading of Runway 5 is zero five zero.
The discussion of name versus direction reminds me of the discussion by the
Mad Hatter in Through the Looking Glass. It was used in a computer class to
exemplify the difference between something and its name.
"Lakeview Bill" wrote in message
of
number.
Old October 15th 05, 04:32 PM
Lakeview Bill
"The magnetic heading of Runway 5 is zero five zero."
No...
The magnetic heading of Runway 5 can be any heading between 046 and 054.
From the Pilot/Controller Glossary: RUNWAY - ...Runways are normally
numbered in relation to their magnetic direction rounded off to the nearest
10 degrees...
Go to http://www.airnav.com/ and examine some of their airport information
sheets.
For example at KIGQ, with a magnetic variation of 02W (1995), RWY 18 has a
heading of: 182 magnetic, 180 true.
So, it really is best to think of a "runway number" not as a number, but as
a name composed of numeric characters 0-9 plus "L", "R", "C".
"Daniel L. Lieberman" wrote in message
m...
Examples
to
of
number.
as
Old October 15th 05, 04:43 PM
Gary Drescher
nearest
10 degrees...
sheets.
as
If you don't think of the runway number as a number (corresponding to an
approximate heading), then how do you form an expectation about which
direction to fly to enter, say, a downwind leg for a particular runway?
--Gary
Old October 15th 05, 04:54 PM
Lakeview Bill
Good point...
I was dealing with "runway numbers" while communicating, where it probably
is best to think of them as a "name".
But, as you point out, one would want to think of it as a number while
aviating...
nearest
10 degrees...
information
sheets.
a
as
--Gary
Old October 15th 05, 05:06 PM
Gary Drescher
Default Runway ID
but
as a name composed of numeric characters 0-9 plus "L", "R", "C".
Good point...
aviating...
But if you're going to think of runway numbers as names while communicating
but as numbers while aviating, then why not make the same distinction for
the numbers that designate headings, altitudes, airspeeds, etc.?
There are some numbers in aviation that are really just names (airway
designations, aircraft model designations, tail numbers, etc.). But runway
numbers are really numbers.
--Gary
Old October 15th 05, 10:58 PM
Doug Carter
Default Runway ID
Seems most appropiate to simply use the name painted on the end of the
runway.
Old October 16th 05, 12:51 AM
BTIZ
Default Runway ID
I always love it when they have to rename/repaint the runway because the
magnetic heading for the runway changed.. and to the non-informed... no..
the earth did not move to change the runway..
I'm betting some ol'timers out there remember when the leading zero was
painted on... 05
so it was Runway zero five
BT
nearest
10 degrees...
information
sheets.
a
as
--Gary
Old October 16th 05, 02:04 AM
Matt Barrow
Default Runway ID
"BTIZ" wrote in message
news:PBg4f.10452$MN6.7877@fed1read04...
Only in the case of Mayor Daley.
Old October 16th 05, 02:32 AM
Steven P. McNicoll
Default Runway ID
painted on... 05
The real ol' timers remember when runways were numbered sequentially
clockwise from north.
Pilots Slick Piloting 4 November 20th 04 11:21 AM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 05:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Piloting 114 July 22nd 04 05:40 PM
Rwy incursions Hankal Piloting 10 November 16th 03 02:33 AM
