The newer 172's are fuel injected. They will have an engine driven fuel
pump and and electric one. John RST Engineering wrote: "The Visitor" wrote in message ... RST Engineering wrote: The OP said this was a 172. Some are. So I have to ask. Without me having to go to the TCs and do a search, can somebody please tell me what series of 172s were injected? Anyhow, if so it may be linked to a problem in the fuel pump. And again the models of 172s that have fuel pumps? Jim |
A lot of 0-300's in the older 172's have fuel pumps, I am not too sure why
though. Maybe because of the 6 cylinders? Tom "RST Engineering" wrote in message ... "The Visitor" wrote in message ... RST Engineering wrote: The OP said this was a 172. Some are. So I have to ask. Without me having to go to the TCs and do a search, can somebody please tell me what series of 172s were injected? Anyhow, if so it may be linked to a problem in the fuel pump. And again the models of 172s that have fuel pumps? Jim |
I have had an engine quit multiple times in my twin on roll out after
pulling the power back to idle. It ended up being an idle mixture adjustment, not carb ice (fuel injected). The other possibility was sloppy linkage in the throttle, but this was tight, and testing the fuel pressure showed it to be too low at idle. Don't assume it has to be carb ice. |
Carb ice ...
"Jase Vanover" wrote in message ... I had a situation yesterday at the end of my local "just because" flight (you know, one of those where you really have no place to go but the weather is favourable and you just want to go flying). Was flying a rental 172. Took off like a rocket (lightly loaded solo... cold air about freezing), tooled around practicing stalls, steep turns, etc. Headed back to the pattern and did a couple of touch and goes. On my final landing, I declared a full stop, and decided I would practice a short field landing. I cleared the "imaginary" 50 ft. obstacle, dropped the last notch of flaps and cut power... and the engine quit. No issues, because I had the runway made (I didn't even realize that the engine had quit until rolling on the runway... I knew something sounded different, but the prop was still windmilling and I was concentrating on the flare). I rolled out and the prop stopped, and I called traffic (uncontrolled airport) to let them know I was a sitting duck. Checked the primer (locked), mixture (full rich), fuel selector (both... and lots of fuel... I filled up with only just over an hour of flight since), and restarted with no problems and taxied off the runway. Though it turned out to be no danger, I couldn't help but feel a little disconcerted. A low level power off descent away from the airport could have had a more serious outcome, or what if I misjudged and didn't have the runway made when I cut power? I taxied to the maintenance hanger (after being directed there by the FBO via radio notification of the situation), and explained what happened to the maintenance guy. He said that there is a stop on the throttle to keep the idle setting from being too low that probably needed adjustment. Even so, during shutdown (after restarting), idle setting on the throttle was still 800 - 900 RPM, which should be enough to keep the engine running I would think. Anyone else experienced this and can share their thoughts? I'm about a 60 hour pilot, so not much experience. |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Engine failure on takeoff | Greg Copeland | Piloting | 0 | May 11th 04 04:59 PM |
In-Flight Engine Failure | O. Sami Saydjari | Owning | 59 | April 30th 04 08:40 AM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
Engine failure rates poll | Captain Wubba | Piloting | 3 | December 8th 03 02:44 PM |
