#51
I look down the piano hinge line on the left side of the cowl..
Places the nose wheel on the centerline every time.. Well.... every time I have the hinge lined up anyway... ![]() Dave On Sat, 10 Dec 2005 18:45:55 GMT, "Jay Honeck" wrote: This is not just a problem with SE trainers, look at the tires on a Lear or King Air next time you have the chance, it isn't uncommon to see all the tire wear on the co-pilot's side because the Captain does all the landings. Interesting observation, Jim -- thanks. As a new pilot I used to occasionally have trouble landing in a slight crab, even when there was no crosswind. (In fact, it was sometimes worse with NO wind at all.) I cured that problem by consciously aligning the nose and tail of the plane with the runway, not just aligning *me* with the runway. Now, it's second nature, but it took some analysis to figure out what I was doing wrong. It never dawned on me that this was common, and would result in uneven nose-tire wear! |
#52
You can be absolutely certain that the NTSB will find "pilot error".
They always do. It's the contributing factors which will be interesting. ("RST Engineering" wrote) Nope. In my case, they found the root cause to be "improper maintenance", and all this without a copy of the maintenance logbooks or any other maintenance records. Ok, but did they have the twisty ties, chewing gum, duct tape and baling wire from the scene? g No-no, wait. That would have been "improper repair". Yeah, you got jobbed. Montblack |
#53
Jim Macklin wrote:
Someday, the Daley gang will all be in jail, but still, the Not likely. Chicago has a long history of celebrating crooked politicians, not prosecuting them. I see no indication this will change any time soon. Matt |
#54
..Blueskies. wrote:
"Mike Schumann" wrote in message k.net... Landing in BOS in crummy conditions with a tailwind may be OK due to longer runways. Landing with a 9 knot tailwind in a blizard with fair to poor braking on a 6,500' runway was obviously not a good idea. Mike Schumann What did the performance numbers indicate for the conditions the pilot landed in? What was the final approach speed calculated to? What distance was required to stop? Don't know the numbers? You cannot take the stance that this was obviously not a good idea... The fact that the airplane ended up past the end of the runway is sufficient evidence that this landing was not a good idea. How much more evidence does one need? Matt |
#55
RST Engineering wrote:
Nope. In my case, they found the root cause to be "improper maintenance", and all this without a copy of the maintenance logbooks or any other maintenance records. But, Jim, your reputation preceeds you. :-) Matt |
#56
Jim Macklin wrote:
Pilots tend to sit on the left side and not look truly straight ahead, but look a few degrees toward the center of the airplane. A few hours with a taildragger will do wonders to fix this. The cure is to first get an accurate reference point directly in front of the pilot, parallel and off-set from the centerline; This is exactly correct. In my Maule, this point was the upper left mounting screw for the AI. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#57
Braking conditions were apparently reported as fair to poor. I would think
that that would be sufficient to question the wisdom of landing with a tail wind on a relatively short (for commercial jets) runway. Mike Schumann "Morgans" wrote in message ... "Jim Macklin" wrote I stand by my opinion, the pilot made a stupid decision, for what ever reason. I'll bet a contributing factor will be the incorrectly reported braking conditions. -- Jim in NC |
#58
Matt Whiting wrote in message ...
.Blueskies. wrote: "Mike Schumann" wrote in message k.net... Landing in BOS in crummy conditions with a tailwind may be OK due to longer runways. Landing with a 9 knot tailwind in a blizard with fair to poor braking on a 6,500' runway was obviously not a good idea. Mike Schumann What did the performance numbers indicate for the conditions the pilot landed in? What was the final approach speed calculated to? What distance was required to stop? Don't know the numbers? You cannot take the stance that this was obviously not a good idea... The fact that the airplane ended up past the end of the runway is sufficient evidence that this landing was not a good idea. That would certainly be true in a case like Burbank, where it was initially known to have descended twice as steep as normal and crossed the threshold at 200 knots. In this case it sounds good at first glance, but I think it needs to be qualified by "absent other factors such as mechanical failure - brake or thrust reverser problems, etc." Also, the fact that flights had been landing safely shortly before would make your statement a little less certain. In fact, it has now been reported by the pilots that the reversers didn't take effect right away - there was a delay of several seconds. Even the flight attendants noticed it. http://www.chicagotribune.com/news/l...t,1,463663.sto ry?coll=chi-news-hed&ctrack=1&cset=true How much more evidence does one need? I can't answer that, but it sure doesn't take much evidence to cast doubt on the weather as the major factor. - Rick |
#59
your amature analysis is shining through. you obviously have no facts, no knowledge of the aircraft involved, nor any knowledge of SWA procedures.
Quote:
#60
![]() Matt Whiting wrote: The fact that the airplane ended up past the end of the runway is sufficient evidence that this landing was not a good idea. How much more evidence does one need? How about some facts, because now you look stupid. Pilots have reported that the thrust reversers failed to deploy. That will be easily verifiable with the black box. If they don't pop out 10,000 feet wouldn't have been enough runway in that weather. http://www.foxnews.com/story/0,2933,178349,00.html |
