Looking at the design of the C377, it seems like it should have been more of
a winner. Why did it flop? Dallas |
It made a poor multi trainer for FBOs because the FAA would not issue
"full" multiengine ratings to students who took their checkrides in it. -Robert |
Just what did the FAA issue then?
![]() wrote in message oups.com... Just what did the FAA issue then? A multi-engine rating limited to centerline thrust. |
A 'centerline only' thrust limitation to the ME rating. |
A 'centerline only' thrust limitation to the ME rating. Not only that, but if you have a regular multiengine rating, you still can't fly the thing unless you get a type rating (or somesuch) for it. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Not true I think.
If you had a multi-engine rating, a normal checkout was FAA approved if I remember correctly. I don't believe the center line thrust rating was mandatory above the regular multi if already held. Dudley Henriques "Jose" wrote in message . com... Just what did the FAA issue then? A 'centerline only' thrust limitation to the ME rating. Not only that, but if you have a regular multiengine rating, you still can't fly the thing unless you get a type rating (or somesuch) for it. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
. com... Not only that, but if you have a regular multiengine rating, you still can't fly the thing unless you get a type rating (or somesuch) for it. Not true. |
Jose wrote:
Just what did the FAA issue then? A 'centerline only' thrust limitation to the ME rating. Not only that, but if you have a regular multiengine rating, you still can't fly the thing unless you get a type rating (or somesuch) for it. Jose "Centerline thrust only" is a limitation, not a priveledge. The 336, 337 and 0-2 did not require a type rating. Dave |
Not correct, at least in the USA. There are some jets that
don't have a Vmca as such because the engines are so close to the centerline and although they have two engines, they don't meet the FAA requirement for issuing an unrestricted multiengine certificate. If you obtain your multiengine certificate in such an airplane you are issued a multiengine rating with the centerline thrust limitation. But as it is a turbojet/12.5 gw, a type rating is required also. The Cessna 337 is lighter than the weight floor for requiring a type rating and it is not a turbojet. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Jose" wrote in message . com... | Just what did the FAA issue then? | A 'centerline only' thrust limitation to the ME rating. | | Not only that, but if you have a regular multiengine rating, you still | can't fly the thing unless you get a type rating (or somesuch) for it. | | Jose | -- | Money: what you need when you run out of brains. | for Email, make the obvious change in the address. |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
