#51
And this is exactly the thread we had a year or so ago, where you said that
you can't put non-certified parts on your production airplane and I said you can. We went round and round for a week, and we finally agreed to disagree. Now you are starting the whole damned thing over again. Jim Some people may not understand and might make and install non-certified parts on their production airplane. It isn't an argument, it is a caution. |
#52
Hey, what cam I say, I'm 60 and don't remember everything.
I also think that it is not legal to install parts willy-nilly on certified airplanes. I don't intend to worry about your thin skin either. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "RST Engineering" wrote in message .. . | And this is exactly the thread we had a year or so ago, where you said that | you can't put non-certified parts on your production airplane and I said you | can. We went round and round for a week, and we finally agreed to disagree. | | Now you are starting the whole damned thing over again. | | Jim | | | | Some people may | not understand and might make and install non-certified | parts on their production airplane. It isn't an argument, | it is a caution. | | |
#53
"RST Engineering" wrote: And this is exactly the thread we had a year or so ago, where you said that you can't put non-certified parts on your production airplane and I said you can. We went round and round for a week, and we finally agreed to disagree. ok, here's my question: Are you saying that I could install any part (certified or uncertified) I want in my cherokee as long as I have an approval basis for the installation? or are you saying that no approval basis of the installation is required? -- Bob Noel Looking for a sig the lawyers will hate |
#54
"RST Engineering" wrote: Again, depends entirely on the situation. Give me a ferinstance with all the particulars. (what particulars do you need?) Case 1: Install a digital OAT probe and display in a cherokee. The part is PMA'd for certain Beech aircraft but not any cherokee Case 2: Install a replacement handle for the seat release in a cherokee. The part was fabricated (by me) from stock laying around the hangar. Case 3: Install new aluminum engine baffling fabricated (by me) from aluminum "scrap". Case 4: Install an instrument light dimmer switch (a simple rehostat (or however it's spelled)) -- Bob Noel Looking for a sig the lawyers will hate |
#55
![]() Case 1: Install a digital OAT probe and display in a cherokee. The part is PMA'd for certain Beech aircraft but not any cherokee I'd consider that a minor modification that can be handled on a logbook entry with an A&P signature. See the last sentence about "instructions for continued airworthiness". Actually, for a part that isn't required for flight, I'd not be worried about whether the part was PMA'd at all. Case 2: Install a replacement handle for the seat release in a cherokee. The part was fabricated (by me) from stock laying around the hangar. 21.303(b)(2) gives the owner or the operator the perogative to manufacture parts for their own aircraft. "manufacturing" does not have to be physically done by you; if you generate the drawings and take them down to the local machine shop for fabrication, you are still the "manufacturer". Again, minor repair UNLESS the installing mechanic can see how a design change from the original part might get tangled up and inadvertently release the seat, in which case it isn't a matter of a major repair; it is simply unairworthy. Case 3: Install new aluminum engine baffling fabricated (by me) from aluminum "scrap". Minor repair under the watchful eye of the engine mechanic. Airworthiness depends on how crappy the scrappy was. Case 4: Install an instrument light dimmer switch (a simple rehostat (or however it's spelled)) Rheostat. If it a replacement for a currently installed rheostat it is a minor repair if the replacement part is form, fit, and function with the old part. If it is a modification, I'd like to see some calculations on how hot it is going to get, what you have done to address the heat generated, whether the part is rated for the calculated wattage, and all that good stuff. If it all calculates out properly, minor modification but with the caveat that a sheet showing "instructions for continued airworthiness" in the aircraft files (i.e how often inspected, what are you inspecting for, and all that stuff). Jim |
#56
"RST Engineering" wrote: iow - the answer to my question was yes, any part can be installed as long as there is an approval basis. Case 1: Install a digital OAT probe and display in a cherokee. The part is PMA'd for certain Beech aircraft but not any cherokee I'd consider that a minor modification that can be handled on a logbook entry with an A&P signature. the approval basis being the A&P signature actually, in my case, it was replacing the original OAT probe, I discussed this with the FSDO prior to the mod and the shop filed a 337. etc -- Bob Noel Looking for a sig the lawyers will hate |
#57
"Jim Macklin" wrote in message
news:g7U_f.2959$8q.2119@dukeread08... Hey, what cam I say, I'm 60 and don't remember everything. It's called "having an Alzheimer Moment"... grin |
#58
or uncertified) I want in my cherokee as long as I have an approval basis for the installation? or are you saying that no approval basis of the installation is required? I actually talked with somebody at my FSDO (CT) about this kind of thing. We were talking about installing a non-certified backup AH. 1: You can't install a non-certified (NC) part as a required part of a certified plane. Thus, the NC gyro can't be your only gyro, or be one in the sacred six position. 2: You can install anything that is not required, so long as the installation meets the approval of the certified mechanic doing the installation and signing off on it. This signoff is essentially saying that the part will not harm the safety or flight charactaristics of the aircraft. Thus you can install a (NC!) CD player that plugs into the cigarette lighter. It can be screwed into the panel, so long as the certificated mechanic signs off on it (saying that it won't, for example, get in the way of flight controls, fall off at a critical moment, and that the installation will withstand the same forces the rest of the airplane is supposed to withstand. 3: He was concerned about connecting directly to the electrical system, because there can be no assurance that it won't be a flight hazard, but IIRC he didn't forbid it. We did not pursue this further because my club went with a certificated unit. YMMV. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
#59
crossposting-snipped
In rec.aviation.piloting, "Jose" wrote in message . com... We did not pursue this further because my club went with a certificated unit. For the cost of a certified CD player, you could supply everyone on the plane with an iPod / MP3 player... The earbuds fit nicely inside the ear cups of a normal aviation headset... |
#60
For the cost of a certified CD player, you could supply everyone...
Yes, but this way if there's a crash, we could sue the artist on the CD that was playing. ![]() It was a backup AH that we installed. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
My plane cost $40 yesterday | Charles Talleyrand | Owning | 12 | November 20th 03 09:17 PM |
Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 12:17 AM |
