Missing flight plans
Old August 5th 06, 08:05 PM posted to rec.aviation.piloting,rec.aviation.owning
Newps
Default Missing flight plans
Mark Hansen wrote:
On 08/04/06 16:33, Newps wrote:
Mark Hansen wrote:
Just to clarify, what I mean is can you show the regulation which states
that ATC is required to begin search and rescue operations if they lose
radio contact with an airplane that was on flight following.
Absolutely. Knock yourself out.
http://www.faa.gov/ATPubs/ATC/index.htm
So, you're answer is "no". Got it. Thanks,
Exactly.
  #52
Old August 6th 06, 04:13 PM posted to rec.aviation.piloting,rec.aviation.owning
Michelle
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message
"Michelle" wrote in message
As to your question, it just seems so "unprofessional" and I think
unprofessional conduct by pilots is a big part of the reason GA has such
a higher accident rate than cars, and private pilots have the highest
rates among their pilot brethren.
How exactly Michelle will filing a VFR flight plan reduce the accident
rate in aircraft? As since you mentioned it, do you file a drive plane
when you drive a car?
Do you always put not only words but entire paragraphs in peoples mouths?
In any case, let's hear it from the real pros (the people that get paid to
fly): How often do you conduct a flight without a flight plan?
How many of you take off without a pretty through pre-flight of the
aircraft.
Here's the point: I never said, or even intimated that not filing a flight
plan caused a crash; the point is the attitude and approach that proc take
that the amateurs do not.
Michelle S.
  #53
Old August 6th 06, 04:15 PM posted to rec.aviation.piloting,rec.aviation.owning
Michelle
"B A R R Y" wrote in message
On Fri, 4 Aug 2006 11:50:54 -0500, "Gig 601XL Builder"
rate
in aircraft?
Not only will it not prevent a single accident,
Please point out where I said it would prevent an accident.
I don't see the value
of a VFR flight plan for other reasons in many cases.
Such as? Please!
Michelle
  #54
Old August 6th 06, 04:18 PM posted to rec.aviation.piloting,rec.aviation.owning
Michelle
"Peter R." wrote in message
a
higher accident rate than cars, and private pilots have the highest rates
Just to clarify, in your opinion, not filing a VFR flight plan is
"unprofessional?"
"Yes", I think so...amongst other behavioral patterns.
Michelle
  #55
Old August 6th 06, 07:38 PM posted to rec.aviation.piloting,rec.aviation.owning
Emily[_1_]
The people who get paid to fly generally are required to fly IFR, so of
course they file flight plans. That argument makes no sense.
  #56
Old August 7th 06, 02:13 PM posted to rec.aviation.piloting,rec.aviation.owning
Gig 601XL Builder
"Mark Hansen" wrote in message
I think B will be of interest.
10-2-5. EMERGENCY SITUATIONS
Consider that an aircraft emergency exists and inform the RCC or ARTCC and
alert the appropriate DF facility when:
NOTE-
1. USAF facilities are only required to notify the ARTCC.
2. The requirement to alert DF facilities may be deleted if radar contact
will be maintained throughout the duration of the emergency.
a. An emergency is declared by either:
1. The pilot.
2. Facility personnel.
3. Officials responsible for the operation of the aircraft.
b. There is unexpected loss of radar contact and radio communications with
any IFR or VFR aircraft.
c. Reports indicate it has made a forced landing, is about to do so, or its
operating efficiency is so impaired that a forced landing will be necessary.
d. Reports indicate the crew has abandoned the aircraft or is about to do
so.
e. An emergency radar beacon response is received.
NOTE-
EN ROUTE. During Stage A operation, Code 7700 causes EMRG to blink in field
E of the data block.
f. Intercept or escort aircraft services are required.
g. The need for ground rescue appears likely.
h. An Emergency Locator Transmitter (ELT) signal is heard or reported.
REFERENCE-
FAAO 7110.65, Providing Assistance, Para 10-1-3.
FAAO 7110.65, Emergency Locator Transmitter (ELT) Signals, Para 10-2-10.
  #57
Old August 7th 06, 03:07 PM posted to rec.aviation.piloting,rec.aviation.owning
Mark Hansen
But the assertion I was questioning was with regard to the loss of radio
communications only. Not coms *and* radar. Paragraph 'B' you quote (below)
is for the loss of *both* comms *and* radar contact.
NOTE-
1. The pilot.
so.
NOTE-
REFERENCE-
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
  #58
Old August 7th 06, 05:56 PM posted to rec.aviation.piloting,rec.aviation.owning
Kyler Laird
Mark Hansen writes:
Actually, ATC is not required to maintain communications with you,
and if you suddenly disappear, they may assume you just went off-
frequency and shut off your transponder (or had a power failure,
etc.). I don't see why they would begin a search and rescue in
this case.
And yet they do. What's up with that?
--kyler
  #59
Old August 7th 06, 11:45 PM posted to rec.aviation.piloting,rec.aviation.owning
Emily[_1_]
Kyler Laird wrote:
Mark Hansen writes:
this case.
And yet they do.
Not always.
  #60
Old August 8th 06, 06:58 AM posted to rec.aviation.piloting,rec.aviation.owning
Anno v. Heimburg
I think I'm having a déjà-vu. Check Msg-Id
and Mark's answer to it.
But I'm glad I'm not the only one who got lost in the course of this
conversation.
Anno.
DUATS & Canadian Flight Plans Andrew Sarangan Piloting 2 November 7th 05 08:51 PM
Third Military-Civil MAC Jan. 18, 2005 Larry Dighera Piloting 37 February 14th 05 03:21 PM
Aerial PHotography Flights 'Required' to File Flight Plans C J Campbell Piloting 15 December 6th 04 02:17 PM
