I don't "know", so pure speculation on my part, but maybe they were trying
to create another visual clue to help prevent this exact type of accident. "C. Massey" wrote in message ... OK... But what I don't understand is why would they have two runways that are the same surface width, but it is listed as a 75 ft runway they way it is marked? It seems to me that if they are the same surface width, they would mark both of them the same usable width. |
![]() "C. Massey" wrote in message news:tVWIg.3722 OK... But what I don't understand is why would they have two runways that are the same surface width, but it is listed as a 75 ft runway they way it is marked? It seems to me that if they are the same surface width, they would mark both of them the same usable width. Probably something as simple as their ongoing maintenance budget. Most planes that can operate in 3500 ft don't need a 150 ft width, and most planes that need this width probably couldn't function on a 3500 ft runway. Couple that with weight bearing capacity limitations, and the Lexington folk probably figured there was no point in continuing to require maintenance and upkeep on the outer areas of the pavement. In fact, I gather from some reports that there hasn't been a great deal of recent maintenance performed on that entire runway. |
Only the area between the with lines is "usable."
"C. Massey" wrote in message ... | | "Ron Lee" wrote in message | ... | 3. Looking at the two runways using google earth, it looks as though the | actual pavement is the same width on both runways in question, but all of | the documents that I have seen show a 75 ft and a 150 ft runway. Why is | this? Someone mentioned the 75 ft runway is actually 150 ft wide, but the | markings make it 75 ft usable. Why would that be? | | Look closely at a picture of Rwy 26 and you will see solid (white?) | lines either side of the centerline that are probably 75 feet apart. | | | | OK... But what I don't understand is why would they have two runways that | are the same surface width, but it is listed as a 75 ft runway they way it | is marked? It seems to me that if they are the same surface width, they | would mark both of them the same usable width. | | | | | --- | avast! Antivirus: Outbound message clean. | Virus Database (VPS): 0635-1, 08/28/2006 | Tested on: 8/29/2006 8:02:18 AM | avast! - copyright (c) 1988-2006 ALWIL Software. | http://www.avast.com | | | |
C. Massey wrote:
OK... But what I don't understand is why would they have two runways that are the same surface width, but it is listed as a 75 ft runway they way it is marked? It seems to me that if they are the same surface width, they would mark both of them the same usable width. They've stopped maintaining the surface along the perimeters as a cost saving measure, so they then demark the interior 75 feet as useable. They are obligated to maintain the useable portion but not the unusable portion. I would imagine at some point in the future Lexington will end up closing the shorter runway entirely just to be free of the expense. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
![]() They legally narrowed the runway using a paintbrush. They only have to maintain and keep up/repave/resurface (if they do it at all) the actual runway (which is listed at 75 feet wide, but is in the middle of the 150 ft wide paved area. Dave C. Massey wrote: OK... But what I don't understand is why would they have two runways that are the same surface width, but it is listed as a 75 ft runway they way it is marked? It seems to me that if they are the same surface width, they would mark both of them the same usable width. --- avast! Antivirus: Outbound message clean. Virus Database (VPS): 0635-1, 08/28/2006 Tested on: 8/29/2006 8:02:18 AM avast! - copyright (c) 1988-2006 ALWIL Software. http://www.avast.com |
lines either side of the centerline that are probably 75 feet apart. That's a good observation by C Massey though. Some of the news reports mentioned that runway 26 was only half as wide as 22, so they questioned how could the pilots not have noticed something that obvious? Well, being that the pavement is actually 150 ft wide, runway 26 was unlit, they probably didn't notice the lines that marked it was only 75 ft usable width. |
"C. Massey" wrote:
1. Is the ATC responsible for making sure the aircraft is on the correct runway? No, the pilot in command is the final authority for the safety of the flight. A pilot has the authority to disregard an ATC instruction if the pilot believes that this instruction will put the aircraft in harm's way. Among the many other responsibilities, ATC does serve as a "check and balance" of sorts, but for some reason this check did not occur on that morning. 2. Aren't there check's that are made from inside the cockpit to assure they are on the correct runway? Yes there are. However, I am not a professional pilot so I am unaware if airlines have written procedures dealing with this. I suspect they do. In the GA world we would compare the directional gyro, compass, or HSI to the known runway heading before departing. 3. Looking at the two runways using google earth, it looks as though the actual pavement is the same width on both runways in question, but all of the documents that I have seen show a 75 ft and a 150 ft runway. Why is this? Someone mentioned the 75 ft runway is actually 150 ft wide, but the markings make it 75 ft usable. Why would that be? Unknown by me, but perhaps the airport purposely did this to assure a distinction between the smaller runway and the larger one. -- Peter |
It is cheaper to only pave and maintain a 75 foot wide
surface, often the original runways in this country were laid down during WWII as military training bases. Wide runways allowed formation take-offs and landings. After the war, the cities were given control of the airport and the city would just pave the center with asphalt over the crumbling concrete. -- James H. Macklin ATP,CFI,A&P "C. Massey" wrote in message ... | | "Andrew Sarangan" wrote in message | oups.com... | I am getting tired of comments like "controller should have warned the | pilots", or "taxiway was confusing", or "runway lights were off" etc.. | One could not find a better example of a pure and simple pilot error. | The runway was clear, the weather was VFR, and the airplane was working | fine. It is highly likely that this was the only airplane maneuvering | at the airport. Even if the controller had cleared him to takeoff on | runway 26, the responsibility would have been on the pilot to decline | that clearance. Yet, a perfectly good airplane was run off the runway | and ploughed into the woods. | | NTSB is investigating whether the pilots had coffee that morning, and | how much sleep they got. This is a futile exercise. Taxiing and | departing from a relatively quiet airport under VFR conditions is an | extremely low workload situation. We are not talking about shooting a | non-precision approach to minimums in a thunderstorm after a full day | of flying. A pilot should be able to do this even if he had partied all | night at the bar. What happened was gross negligence. | | I shudder to think that my wife and baby flew the Comair CRJ only a few | days prior to this accident. Fortunately they are flying back with me | in our trusty GA airplane. I feel a lot better about it than trusting | my family to stupid mistakes that even my students pilots know how to | avoid. I sincerely feel for those who lost loved ones. They have the | right be very angry. I am angry, and I did not lose anything. | | | | I have a question. I will say right off of the bat that I do not have any | pilot ratings, but I do have A&P ratings, so I am somewhat familiar with | FAR's. I am unfamiliar with any SOP's. | | 1. Is the ATC responsible for making sure the aircraft is on the correct | runway? | | 2. Aren't there check's that are made from inside the cockpit to assure they | are on the correct runway? | | 3. Looking at the two runways using google earth, it looks as though the | actual pavement is the same width on both runways in question, but all of | the documents that I have seen show a 75 ft and a 150 ft runway. Why is | this? Someone mentioned the 75 ft runway is actually 150 ft wide, but the | markings make it 75 ft usable. Why would that be? | | | Thanks for your answers... | | | | | --- | avast! Antivirus: Outbound message clean. | Virus Database (VPS): 0635-1, 08/28/2006 | Tested on: 8/29/2006 7:34:06 AM | avast! - copyright (c) 1988-2006 ALWIL Software. | http://www.avast.com | | | |
... 1. Is the ATC responsible for making sure the aircraft is on the correct runway? No, they are not. 2. Aren't there check's that are made from inside the cockpit to assure they are on the correct runway? Yes, there are. There is currently no indication that these pilots failed to make those checks. The most we can assume is that they either had the wrong runway number for their desired takeoff runway, or they failed to *correctly* make the check. It's possible that they actually thought runway 26 was the correct runway, and it's also possible that they knew runway 22 was the correct runway, performed the necessary cross-check to verify the runway, but failed to notice the discrepancy in that cross-check. 3. Looking at the two runways using google earth, it looks as though the actual pavement is the same width on both runways in question, but all of the documents that I have seen show a 75 ft and a 150 ft runway. Why is this? Someone mentioned the 75 ft runway is actually 150 ft wide, but the markings make it 75 ft usable. Why would that be? You've gotten plenty of answers on that one. ![]() Pete |
![]() C. Massey wrote: 1. Is the ATC responsible for making sure the aircraft is on the correct runway? No. But in Canada they do make sure the runway is clean before issuing a take off clearance. They catch many things this way. They are supposed to use the window. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Fact or satirical fiction? | [email protected] | Piloting | 23 | March 28th 06 01:28 AM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
