I am troubled by two lines of reasoning that appear persistently both
in this thread and in private emails I have been copied on related to OLC flights. They are troubling to me because they reflect a cultural value that simply invites increased regulation, enforcement actions and restrictions from our federal authorities. The first goes like: "Since the OLC doesn't explicitly say flights must comply with the FARs then the flights don't need to" The second goes like: "Since specific violations of a rule were not enforced correctly in the past then the rule no longer is enforceable." Sadly, this errant reasoning has also appeared in my work at scoring national competitions. So since the absurdness (and counterproductiive impact) of these positions is apparantly NOT evident on its face to all - here is my rant. 1. There are some things in life which "just don't need to be said" because they are so obvious. There is simply no advantage to our sport (and indeed there are clear disadvantages) for our sporting authorities to sanction or even appear to be agnostic to violations of the FARs. Period. 2. It negatively impacts our sport when individuals publicly document that they operate in violation of the FARs (or give the appearance of being outside the FARs without explanation). If participants could be relied on to self enforce and to not submit flights with clear violations (and preemptively provide explanations for anything that could be called into question) it would not be necessary for the sporting authorities to intervene. Of course an occasional inadvertent error will occur; and in that situation, when it is pointed out privately to the individual - good sportsmansihp dictates that the flight be voluntarily withdrawn immediately until adjudicated. 3. It negatively impacts our sport when these same individuals argue publically that FAR violations should not be disqualifying for sporting achievements.(Free speech is not without costs). 4. This OLC is great fun, a great competition and an incredibly valuable learning tool. The last thing we should do (as individuals or organizationally) is behave in ways that call attention to us as a "target rich enforcement opportunity" to the federalies. Further, we should actively work to be publically seen as self-enforcing, which will work to avoid outside enforcement attention. I share the disappointment of the pilots whose otherwise very spectacular flights don't clear the bar - been there and had to forefit the t-shirt. On the other hand it's not like what is at stake is a costarring position under Sharon Stone in "Basic Instinct 3." ![]() So while it may be quite safe on the golf course to shake your 1 iron in the air to protest a passing thunderstorm (since "even God can't hit a 1 iron") it only invites further restrictions and oversight if we do things that present lightning rods for enforcement attention. This just seems so obvious. As a sanctioned participant in the sport we all have an obligation to behave in ways that protect the sport from further outside interference. |
Ian Cant a écrit :
But what about motorgliders with lights and big batteries ? Are they allowed to have longer days than the rest of us ? Not only motorgliders. Any glider with proper equipment can be certified night-VFR and flew OLC flights or records for 50+ hours (BTW there has been world records up to 55 hours half a century before OLC was created ;-) ) BTW, when will SSA check passports and baptism certificate of pilots and crew, in order to prove that those flight logs close to possible terrorism targets were not driven by some islamist fundamuntalists ? Seems that Big Brother is now a soaring pilot :-((( -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Is night cross-country in an adequately-equipped glider
inherently more dangerous than night cross-country in a Cessna ? Each is one failure [loss of lift or loss of engine] away from that dark field. It might be more accurate to say that at night you need to give yourself much wider safety margins than in daylight. Ian At 23:12 12 September 2006, Doug Haluza wrote: Obviously, night cross country in gliders is very dangerous, due to the possibility of an outlanding in a dark field, so I hope we don't have to wait until someone dies to address this. |
I suspect that the chance of loosing lift in a glider is significantly
higher than loosing an engine. I personally do not think it is a good idea to fly at night in a single engine power plane unless you have a full moon and are over very favorable terrain. Mike Schumann "Ian Cant" wrote in message ... Is night cross-country in an adequately-equipped glider inherently more dangerous than night cross-country in a Cessna ? Each is one failure [loss of lift or loss of engine] away from that dark field. It might be more accurate to say that at night you need to give yourself much wider safety margins than in daylight. Ian At 23:12 12 September 2006, Doug Haluza wrote: Obviously, night cross country in gliders is very dangerous, due to the possibility of an outlanding in a dark field, so I hope we don't have to wait until someone dies to address this. |
Mike Schumann wrote:
I suspect that the chance of loosing lift in a glider is significantly higher than loosing an engine. I personally do not think it is a good idea to fly at night in a single engine power plane unless you have a full moon and are over very favorable terrain. In a typical 15M glider, if you can climb to 17,900 ft MSL an hour before sunset (which is not uncommon in the western US), what time will you land if you glide at best L/D to your home airport at 5000 ft MSL? |
Marc Ramsey wrote:
In a typical 15M glider, if you can climb to 17,900 ft MSL an hour before sunset (which is not uncommon in the western US), what time will you land if you glide at best L/D to your home airport at 5000 ft MSL? More than 1:30 later, or more than 0:30 after sunset. Jack |
OK, here's a video of flying aerobatics at night, below
1500' in a multi-engine turbine glider. No multi-engine ticket, no type rating, position lights off, and wingtips on fire...legally! Should have logged it on OLC just to stir the pot a bit ;o) low resolution: http://www.silentwingsairshows.com/video/nightshow.wmv At 06:24 13 September 2006, Bumper wrote: 'Doug Haluza' wrote in message oups.com... Obviously, night cross country in gliders is very dangerous, due to the possibility of an outlanding in a dark field, so I hope we don't have to wait until someone dies to address this. I've flown my previous glider, a Stemme S10-VT, in wave at night. A most beautiful and memorable flight. Fields? Dangerous? I stayed within easy gliding distance of airports with pilot controlled lighting. The Stemme was equipped with the required position and anit-collision (strobe) lights. bumper |
Bob C writes:
OK, here's a video of flying aerobatics at night, below 1500' in a multi-engine turbine glider. No multi-engine ticket, no type rating, position lights off, and wingtips on fire...legally! Should have logged it on OLC just to stir the pot a bit ;o) low resolution: http://www.silentwingsairshows.com/video/nightshow.wmv Not bad, but at that altitude I would have expected the flack to be more accurate. Pretty colours, though. -- Brian Raven |
At 21:54 13 September 2006, Brian Raven wrote:
Bob C writes: OK, here's a video of flying aerobatics at night, below 1500' in a multi-engine turbine glider. No multi-engine ticket, no type rating, position lights off, and wingtips on fire...legally! Should have logged it on OLC just to stir the pot a bit ;o) low resolution: http://www.silentwingsairshows.com/video/nightshow.wmv Not bad, but at that altitude I would have expected the flack to be more accurate. Pretty colours, though. -- Brian Raven What flak? Those are anti-missile flares ;o) If you look close you can see the muzzle flashes from the 2' mortar tubes mounted to the aft fuselage. Bob |
I have been through this process twice. One certified,
one experimental. Check your glider's operating limitations. If it is a certified glider (not experimental), it is probably placarded against night flying. The only way to change that is to place it in experimental category. It will still require an STC (or 337/ field approval, if you can get one). Whelen lights have been put on everything from airliners to fighters, yet it requires a totally new STC for installation on a new make/model. I douby Whelen is interested in this tiny market segment. If it is experimental, your ops limits probably state 'Day VFR only, unless equipped according to 91.205'. They probably also require you to notify FSDO of any major alterations. Adding lights is a major alteration. LEDs are very bright, but also very directional. To meet the angle, color requirements is fairly difficult. Whelen does make LED wingtip lights, but they are fairly expensive. You will also need at least two strobes, and the power supplies to go with them. LEDs won't currently meet the requirements for strobes. Unless your motorglider (Stemme, Katana, Ximango) came factory equipped, or unless someone is paying you to fly at night, probably more trouble than it's worth. Bob C. At 21:00 15 September 2006, Wayne Paul wrote: Mike, It is a Schreder HP-14 kit built sailplane designed in 1966. Dick Schreder won the US Nationals with serial number 1 in 1967. http://www.soaridaho.com/Schreder/HP-14/N4736G.htm Wayne HP-14 N990 '6F' http://www.soaridaho.com/Schreder/N990_Borah_Mt.JPG http://www.soaridaho.com/Schreder 'Mike Schumann' wrote in message link.net... What kind of glider is that? Mike Schumann 'jb92563' wrote in message oups.com... I can think of one way to make a glider more visible with an intensity equal to the sun and draws absolutley NO POWER and requires NO WIRING Check this out! http://www.soaridaho.com/Schreder/HP...LH/N14LH_2.jpg In truth the power it requires is in the buffing, but the results are incredible. The polish to get this is called Nuvite and costs a lot but with outstanding results http://www.perfectpolish.com/ |
| Thread Tools | |
| Display Modes | |
| For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 06:18 AM |
| S-TEC 60-2 audio warning | Julian Scarfe | Owning | 7 | March 1st 04 09:11 PM |
