NW_Pilot's Trans-Atlantic Flight -- All the scary details...
Old October 3rd 06, 12:38 PM posted to rec.aviation.piloting
Dylan Smith
Default NW_Pilot's Trans-Atlantic Flight -- All the scary details...
On 2006-10-02, Jay Honeck wrote:
Funny as that may be, Steven *was* very cognizant of how he wrote this
story up, for fear of being flamed by certain members of this group.
Ever since Steven Ames got flamed to a charbroiled crisp over a loose
formation flight (with a CFI as the wing man), I've always had to resist
the temptation to post about the flight of four we did consisting of a
Cessna 140, Cessna 170, Grumman Tiger and Beech Bonanza. So far I've
resisted because I think I'd be trolling if I did that :-)
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old October 2nd 06, 02:46 PM posted to rec.aviation.piloting
Gig 601XL Builder
"Montblack" wrote in message
("Jay Honeck" wrote)
Steven, I'm curious to know what your thought processes were in that dire
situation.
"If I die out here, I'll never hear the end of it from the gang at
rec.aviation."
Truly any pilots version of hell.
Old October 2nd 06, 06:52 AM posted to rec.aviation.piloting
NW_Pilot
"Jay Honeck" wrote in message
again, jay, thanks for being the conduit on this. great stuff.
It's been quite an adventure for Steven. His experiences could fill a
book already, and he's only 30!
dire situation. Stuck in IMC over the North Atlantic, in the dark, no
primary displays, a possible carbon-monoxide leak, a known fuel leak --
I simply can't imagine it getting any worse.
You did a great job keeping everything right-side up, and your head on
straight.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Well, my thoughts were not to panic and keep as calm as i can and think!!
How I kept calm was saying to myself yes it can get much worse!
Old October 3rd 06, 12:24 AM posted to rec.aviation.piloting
Dave S
Welcome home.. glad it worked out safely...
and without sounding high and mighty.. I'm guessing you will pay greater
attention to the fuel system and its architecture in the future...
particularly when aux tanks and injection return lines are involved.
Also.. do everyone else a favor and file a NASA form.. not because of
alleged rule breaking, but because you have discovered a true safety of
flight issue that needs to be addressed.. the sooner the better.. Garmin
needs to have a fault exclusion algorhythm that removes nonsensical
readings from it's decision tree.. rather than causing a software crash..
Dave
Old October 1st 06, 05:50 PM posted to rec.aviation.piloting
Larry Dighera
On 1 Oct 2006 08:33:39 -0700, "houstondan"
wrote in . com:
someone said "a more experienced pilot would have......", well, i think
he did just great.
There's no question Mr. Rhine did the right thing in his case.
Old October 2nd 06, 07:25 AM posted to rec.aviation.piloting
NW_Pilot
"Larry Dighera" wrote in message
wrote in . com:
he did just great.
Thank You, Mr. Dighera
Old October 2nd 06, 06:47 AM posted to rec.aviation.piloting
NW_Pilot
"houstondan" wrote in message
i posted a link at a couple of cessna "type" clubs (c.p.a. and c.p.s.).
i noticed someone did that on an earlier edition so i guessed it was ok
to do that.
he did just great. turned around, got it back on the ground, figured it
out, flew on and made the contract. i think he needs to be
congratulated for doing something really big and doing it well. i'm
about finished reading "the flying north" and i expect any of those
guys would have bought steven a beer and listened to his story.
my airplane budget looks at getting a good harness system, fuel and
engine monitors and enough gas to do some real traveling so i don't
have to worry about a G-1000 any time soon. clearly it is a cautionary
tale about putting too many avionics eggs in one glass basket.
dan
Thank, You
I would feel a bit better about the system if they put manual engine
monitors and fuel qty indicators as a back up the cost to Cessna would not
be much more they have the panel space and would make the newer models safer
with manual back up instruments.
Old October 2nd 06, 11:18 AM posted to rec.aviation.piloting
Matt Whiting
to do that.
dan
Thank, You
I agree. As we've learned and re-learned many times over the years
(Therac-25 and many others), it isn't a good idea to have all of your
eggs in one basket, especially when that basket is made of software! :-)
Matt
Old October 2nd 06, 12:27 PM posted to rec.aviation.piloting
John Theune
to do that.
dan
Thank, You
not be much more they have the panel space and would make the newer
models safer with manual back up instruments.
Matt
Just as people will plead to let the NTSB give a report before you
decide what caused a crash, I think the same thing should be done here.
I'm a software engineer and I've dabbled a little in real time systems
and there are many things that can cause a system to reboot. It might
be a **** poor design or it might be something else. NW_pilot has not
given us enough data to know ( because he did not have the data either )
The biggest problem is Garmin does not issue final reports but in this
cause it may be possible to find out why. I agree that a out of range
fuel sensor should not cause a system reboot. I just went back and
re-read the story and realized that this was not truly a garmin problem.
The modified fuel system caused the problem and those additions are
outside the design envelop of the garmin system. It would appear at
first glance that the condition that caused the problem ( over pressure
in the fuel tank due to excess fuel could not happen in a standard
system and so it was not forseen in the system design) Bottom line is
that this was a modified system and to hold garmin responsible and use
that are a reason not to have advanced avionics is not good idea.
John
Old October 2nd 06, 04:50 PM posted to rec.aviation.piloting
Larry Dighera
On Mon, 02 Oct 2006 11:27:24 GMT, John Theune
wrote in wI6Ug.876$Pk2.497@trnddc08:
Would division by zero be one of them?
It might be a **** poor design or it might be something else. NW_pilot
has not given us enough data to know ( because he did not have the data
either )
Perhaps. Here's what is on Mr. Honeck's web site at the URL he
provided at the beginning of this message thread
http://www.alexisparkinn.com/nwpilot's_tranatlantic_flight.htm:
[Day 2]
After switching to the aircraft fuel (from the ferry tank) strange
things started happening. The 100-gallon ferry tank went dry
after only 7 hours, burning 8 to 9 gallons per hour! Something
just did not add up...
Then, the G1000 started to go nuts, with the fuel indicators
displaying red X's. Next, I received a CO2 detector failure, then
GPS-1 failure!
When the G1000 got done rebooting, I found myself missing my
airspeed indicator and fuel gauges -- and it was now displaying a
bunch of other errors. Assessing my situation, I figured that I
had no fuel gauges, the G1000 is continually rebooting, possible
CO2 in the cabin, AND an apparent fuel leak!
As I grind closer and closer to Narsarsuaq, at about 60 miles out
they send up a rescue chopper, locate me, and guide me in, since
I am unable to make the NDB approach with the G1000 rebooting
itself. (The ADF display is tied to the G1000's HSI.)
[Day 3]
We finally figured out that the instructions for the ferry tank
were not correct, and really need to be changed before the company
installing the tank kills someone.
The problem was the ferry tank's fuel return line was over
pressurizing the aircraft tanks, causing fuel to vent overboard.
To prevent this, what needed to be done was to FIRST run the
aircraft's left tank down till it was almost empty, THEN turn on
the ferry tank.
The instructions with the ferry tank said only to "Climb to
altitude, then switch to the ferry tank and turn off the aircraft
fuel", then run it till the fuel level hits a mark on the ferry
tank's fuel level indicator. These instructions turned out to be
totally incorrect!
Even Cessna engineering was surprised that the FAA had approved
the instructions for the ferry tank setup, because it also caused
the G1000 to go nuts. Apparently the added pressure in the fuel
tanks pushed the floats in the fuel tank up, which got the Garmin
confused, causing an error that made it reboot. The loss of the
airspeed indicator was caused by fuel vapors entering the pitot
tube -- which also caused the CO2 detector failure!
[Day 11]
Then the tach started being erratic, saying that my RPMs were 4000
-- yeah, right! Then it went Red X. OK, Garmin & Cessna, you
need to have better quality control. After everything else that
has happened, this makes me not want to every own a newer model
Cessna, or anything with a G1000.
cause it may be possible to find out why. I agree that a[n] out of range
Perhaps you are correct, but It would seem that there is a lot of
corroborating evidence absent at this time.
Would you care to share the information to which you refer, detailing
the "design envelope of the Garmin system?"
It would appear at first glance that the condition that caused the problem
( over pressure in the fuel tank due to excess fuel could not happen in a standard
Typically wing tanks are filled to the brim of the filler neck.
Presumably that leaves some air trapped in the tank. Without knowing
the exact placement of the fuel vent pipe intake within the tank, it
is difficult to confirm an over pressure condition in this case.
Absent knowledge of how Mr. Rhine came to his "over pressurizing"
conclusion, it is difficult to substantiate it as fact. Might not the
venting fuel have been merely excess fuel draining from the tank as it
was designed to do when the tank is over filled? After all,
presumably it is the same fuel pump operating in both the factory
designed fuel system and the aux fuel system.
Bottom line is that this was a modified system and to hold garmin responsible and use
that are [sic] a reason not to have advanced avionics is not good idea.
Perhaps.
I thought you felt it would be more appropriate to reserve judgment
until more information was available.
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
