#51
"Wade Hasbrouck" wrote in message
... If you are overtaking planes, you obviously should have waited longer before making your downwind to base turn... The general rule I was taught for the 172 is, provided you haven't "creeped in on your downwind", once the landing traffic passes your wing tip, you can begin your turn to final and it works out just about right... some times I will wait just a little bit longer just to give a little extra space. One SMALL Correction that I just noticed.... ARRGGHHH my fingers don't always type what I want, as I am "editor type" when it comes to e-mail and news postings (i.e. will write something, not like the wording or someting and edit/wirte it differently...) :-) The "general rule" sentence in the paragraph above should be: "The general rule I was taught for the 172 is, provided you haven't 'creeped in on your downwind', once the landing traffice passes your wing tip, you can begin your turn to BASE, and it works out just about right..." Kind of hard to see landing traffic pass your wingtip while ON base, and if you did, that would probably be a big indication that you just overshot your turn to final... :-) Sorry about the typo... :-) |
#52
"Wade Hasbrouck" wrote:
"The general rule I was taught for the 172 is, provided you haven't 'creeped in on your downwind', once the landing traffice passes your wing tip, you can begin your turn to BASE, and it works out just about right..." That's a pretty good rule of thumb when the two aircraft are flying at similar speeds. It doesn't work when (for example), you're a 172 and the guy on final is a Cub going 10 or 20 kts slower than you. On the other hand, if you're a spam can mixing it up with jet traffic, there's no reason you can't turn base long before your traffic has crossed your wingtip. If you're doing 80 kts on base, and he's doing 130 on final, there's no way you're going to catch him. |
#53
"Roy Smith" wrote in message
... "Wade Hasbrouck" wrote: "The general rule I was taught for the 172 is, provided you haven't 'creeped in on your downwind', once the landing traffice passes your wing tip, you can begin your turn to BASE, and it works out just about right..." That's a pretty good rule of thumb when the two aircraft are flying at similar speeds. It doesn't work when (for example), you're a 172 and the guy on final is a Cub going 10 or 20 kts slower than you. On the other hand, if you're a spam can mixing it up with jet traffic, there's no reason you can't turn base long before your traffic has crossed your wingtip. If you're doing 80 kts on base, and he's doing 130 on final, there's no way you're going to catch him. Yes, I will admit, you do need to be cognisant (sp?) of the types of aircraft are in the pattern, and adjust accordingly, i.e. if you are a 172 and cub is front of you, yes, I would wait a little longer before turning... I am usually about 70 kts on base, and then about 65kts on final. |
#54
Ron Wanttaja writes:
None at our field. Don't know about elsewhere. Speaking of Boeing field, I assumed it was a company field for Boeing. Isn't it? What kind of traffic does it have? It seems oddly placed so close to KSEA. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#55
Wade Hasbrouck wrote:
PWT gets pretty busy too... had some guy cut in front of me on final there... :-) I was following the guy in front of me, heard him call his base turn, saw him turn, heard him call his turn to final turn, saw him turn... and was following him... as I turned final, I heard a guy behind me call his base turn, while on final I heard him call his turn to final, and while looking around thought "well, he must be behind me..." and all of a sudden about 100' in front of me and about 50 - 100' above me was a 172 :-) I then advised on the CTAF "Skyhawk that just turned final... you have another Skyhawk underneath you... ON FINAL!", Watched him for a couple seconds as started to strategize "What should I do?" (student at the time practicing landings by myself), and if he didn't do anything I was going to go-around left of the runway... Couldn't go around on the right as there are skydivers over there now (1/4 west of the airport)... but pretty soon I see flaps starting to go up and he announces he is doing a go-around... :-) Stopped and had lunch after that. :-) Your smiley key is sticking... Matt |
#56
... "Roy Smith" wrote in message ... "Wade Hasbrouck" wrote: "The general rule I was taught for the 172 is, provided you haven't 'creeped in on your downwind', once the landing traffice passes your wing tip, you can begin your turn to BASE, and it works out just about right..." That's a pretty good rule of thumb when the two aircraft are flying at similar speeds. It doesn't work when (for example), you're a 172 and the guy on final is a Cub going 10 or 20 kts slower than you. On the other hand, if you're a spam can mixing it up with jet traffic, there's no reason you can't turn base long before your traffic has crossed your wingtip. If you're doing 80 kts on base, and he's doing 130 on final, there's no way you're going to catch him. Yes, I will admit, you do need to be cognisant (sp?) of the types of aircraft are in the pattern, and adjust accordingly, i.e. if you are a 172 and cub is front of you, yes, I would wait a little longer before turning... I am usually about 70 kts on base, and then about 65kts on final. Other thing I just realized... If I am a 172 with jet traffic (not uncommon at places like Boeing Field), and following the jet... Yes, I don't need to worry about catching him, but do need to be very aware of wake turbulence, and fly final/turn final above his path and touch down past his touch down point, or possibly ask the controller for a different runway or "wait" (a 360 or something)... I haven't had to follow a jet yet... Have been in the other position, where I was landing with Citation right behind me. :-) But do realize there are aircraft (other than jets) that could in the pattern that are faster than me... |
#57
Wade Hasbrouck writes:
I have found spotting traffic in MSFS is unrealistically hard to do, unless you turn on the little red labels for the planes that they have ... I'm pleased to hear that, as I manage to spot only about one aircraft in ten when I'm advised of traffic. Even turning in every which way to look for it doesn't help, and if I find it it rarely seems to be where ATC told me it would be (four o'clock could be anywhere from three to nine). Much easier to spot a Cessna on a 3 mile final to Renton from the Renton downwind in real life than in MSFS. This proably because the traffic in flight sim isn't more than a pixels wide until are basically on top of them. It helps to run at 1600x1200, but it's still hard to make out the shape of the aircraft until it's quite near. I'm not sure what purpose seeing traffic serves in MSFS, anyway, since the simulator doesn't simulate much else having to do with traffic and I have yet to see any real conflicts. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#58
If you are overtaking planes, you obviously should have waited longer before making your downwind to base turn... The general rule I was taught for the 172 is, provided you haven't "creeped in on your downwind", once the landing traffic passes your wing tip, you can begin your turn to final and it works out just about right... some times I will wait just a little bit longer just to give a little extra space. Hmm ... so I go crosswind, downwind, base, final, right? If I'm on the downwind leg, then wouldn't I be turning to base before final? I'm having trouble visualizing this. If I hear "make right downwind," I take this to mean (based on what I've read) that I should join the downwind leg at some point at a 45-degree angle, and that the pattern is one in which all turns are right turns (and thus is to the right of the runway, as seen by someone coming straight in). It has also been my experience that planes in MSFS are unrealistically slow in getting off the runway, as planes would "camp out" for a bit on the runway before leaving it, resulting in a the tower giving a go-around. It was really frustrating, as I know that is not typical in real life. Good. I try to get off the runway quickly myself. Too bad there isn't a Virtual FAA in MSFS that you put on those Virtual Pilot's butts.... They all sound and behave the same. As it is, there's hardly every anyone in the pattern, except maybe for one other aircraft, so one can't easily simulate flying a busy pattern. Then again, given my current lack of skill in flying patterns, there might be bodies and aircraft chunks flying everywhere if I had to negotiate a pattern with other aircraft in it. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#59
"The general rule I was taught for the 172 is, provided you haven't 'creeped in on your downwind', once the landing traffice passes your wing tip, you can begin your turn to BASE, and it works out just about right..." Ah, now I am far less confused! Now, how are you looking at the traffic when you try to check if it has passed your wingtip? Kind of hard to see landing traffic pass your wingtip while ON base, and if you did, that would probably be a big indication that you just overshot your turn to final... :-) I'm very good at undershooting and overshooting final (albeit in a flip-of-the-coin sort of way). I only have difficulty aligning with the runway. And for some reason, I always seem to drift slightly left just as I'm coming up on decision height. I don't know what does this. The engines are usually near idle, so it doesn't seem like it'd be a sudden surge of torque or anything. And it seems improbable that the surface winds are _always_ blowing to the left. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#60
Roy Smith writes:
That's a pretty good rule of thumb when the two aircraft are flying at similar speeds. It doesn't work when (for example), you're a 172 and the guy on final is a Cub going 10 or 20 kts slower than you. Does this mean that you have to know how fast each aircraft can or usually does go, or can you easily tell how fast it is moving just by watching it? -- Transpose mxsmanic and gmail to reach me by e-mail. |
